Headers... have you cracked any? - JKowners.com : Jeep Wrangler JK Forum
View Poll Results: Have you had aftermarket headers crack on your JK?
Yep. shorty style 3 11.54%
Yep. Long tubes 0 0%
Nope. i have headers (long or short) and they are fine 7 26.92%
bacon 17 65.38%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
post #1 of 14 Old 08-14-2012, 11:43 PM Thread Starter
b1pig's Avatar
so, its obvious that the cast manifolds split on about every engine. that said.... have any of you that have upgraded to header had them crack? cracked tube? broken weld?
if so, please explain... and whose header failed?
and for those who are compelled to participate that are still pimpin cracked manifolds.... bacon.
b1pig is offline
post #2 of 14 Old 08-15-2012, 05:13 AM
insanitize's Avatar
70000+ plus miles and no cracked manifolds.
07 Rubi rescue Green
"The previous explanation is based on my historically bad memory of a conglomeration of past experiences and conversations. The opinions above probably have some kernel of truth to them but the details are most likely flawed on some level. Please acquire further help from experts before listening to anything I say."
insanitize is offline
post #3 of 14 Old 08-15-2012, 05:16 AM
Exhaust manifold /= "header"
post #4 of 14 Old 08-16-2012, 11:30 AM
D94R's Avatar
The JBA's on my jeep have cracked where the tubes merge. They were installed and rewelded by the previous owner. The header to downpipe flanges have also been bent to the point of not sealing anymore. Either because the hardware supplied with them was junk and the PO didn't know how to replace those or poor/cheap soft metal was used.
My buddy also has Gibson's that he has had to repair in much the same way, but I can only vote once on this.
D94R is offline
post #5 of 14 Old 08-16-2012, 12:11 PM
Breaker of nice things
merlin4979's Avatar
Nope. Other than a temporary issue with heating the spark plug wires, my JBA shorty headers have been fine. (fixed that problem with some heat socks from Napa.)
That isn't saying that I wouldn't drop them in a second if I had the chance to get a set of long tubes though...
merlin4979 is offline
post #6 of 14 Old 08-17-2012, 06:45 AM
insanitize's Avatar
I was responding to the first line in the OP
post #7 of 14 Old 08-18-2012, 06:24 PM
steve&2jc's's Avatar
Have your headers? I recently installed the flow daddy's and am having a heck of a time getting everything to stay tight so it doesn't leak.
07 Rubi Unlimited , 4.5 clayton longarm, 37" Maxxis treps, AtoZ fabrication, Genright, and Polyperformance
steve&2jc's is offline
post #8 of 14 Old 08-19-2012, 12:37 AM Thread Starter
b1pig's Avatar
only prob i've had was the collector flange bolts backing off because they're non-locking. whpony reused the stock bolts and nuts off the manifolds with good results so far.
if you're having probs with yours contact Rusty's and tell them. i think its just a poor hardware choice. but for anyone down the line to get better results, those of us who do have issues should speak up.
b1pig is offline
post #9 of 14 Old 08-19-2012, 05:08 PM
I replaceed the bolts with some grade 8 ones and lockwashers today. Hopefully this will solve that issue.
post #10 of 14 Old 08-19-2012, 06:20 PM
merlin4979's Avatar
I had a similar problem from using the stock bolts. I was tightening them on a weekly basis until I was able to snag some grade 8 bolts. They haven't moved since.
post #11 of 14 Old 08-19-2012, 07:21 PM
FireTrail741's Avatar
How long and thread info please? Thanks! Mine come loose all the time.
My fuel mileage has turned to shit and my exhaust note is considerably louder. I have not had an opportunity to check for cracks yet. I have tightened my bolts a few times already.
FireTrail741 is offline
post #12 of 14 Old 08-19-2012, 08:10 PM
My mileage went to shit too. I believe its from the exhaust leaks at the collector flange. Darn computer is trying to compensate for what the O2 sensors are telling it and it should be better when it's not leaking. I'm keeping an eye on it.
post #13 of 14 Old 08-20-2012, 08:41 AM
merlin4979's Avatar
Can't remember exactly what size bolts. I just took one off, drove the 1/2 mile to Ace hardware, and matched the same size to some new gr.8 bolts and locking flange nuts.
post #14 of 14 Old 08-20-2012, 10:46 PM
D94R's Avatar
For the guys with the bolts backing out; is it just the collector flange or the head flange bolts too?
I have cranked my bolts in my warped header collector flanges to the point of resealing them, but I get a continuous Cat Efficiency code.
Originally it was both banks, but now it's bank2 consistently. I can clear it, then it will come back on in roughly 30-50 miles. So either I can't get it to seal completely on the driver side, the head flange need tightened, or its cracked where I can't see it (again). Hrmph.
Maybe I should just buy new headers to start out fresh and fix the "problems" these ones have and see if my codes come back. Then get the dealer to replace the cat(s) before the 80,000 mile warranty is up....
D94R is offline
