2011 gets a new engine? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 04-08-2009, 01:12 PM Thread Starter
Grant211's Avatar
Exclamation 2011 gets a new engine?
After reading the link in this thread
https://www.jkowners.com/forum/showth...651#post106651
"The standard engine is a new flexible-fuel 3.6-liter V-6 engine. The 3.6-liter V-6 engine is a completely new, state of the art design with double overhead camshafts (DOHC) and a high-pressure die-cast aluminum cylinder block in a 60-degree configuration. It has Variable-Valve Timing (VVT) and delivers 280 horsepower (209 kW) and 260 lb.-ft. of torque (353 N•m) @ 4,800 rpm, compared with the 2009 Grand Cherokee’s 3.7 liter’s 210 hp and 235 lb-ft of torque — yet, it improves fuel economy up to 11%."
Does this mean the JK's will get a new 3.6 engine in 2011/2012? Sounds like it to me!
Grant211 is offline
post #2 of 22 Old 04-08-2009, 01:14 PM
Openly Hostile
I'd love 70 more horsepower.
Jason
SDMF is offline
post #3 of 22 Old 04-08-2009, 01:15 PM
oz97tj's Avatar
I just read that article and thought the same thing. I hope they put it in there seeing as we will never likely get a v8.
oz97tj is offline
post #4 of 22 Old 04-08-2009, 01:33 PM
LowRider's Avatar
This from the allpar site.
Size Line Cars
3.0 V6 Base
Premium
Direct Injection
MDS
Export models (four different varieties are apparently planned though volume will probably be low)
3.3 V6 VVT Sebring, Avenger, Minivans
3.3 V6 Direct Injection Challenger, Charger, Minivans, Grand Cherokee, Durango, Aspen
3.3 V6 DI/HEV Sebring, Avenger, 300, Minivans
3.3 V6 MDS Sebring, Avenger, Minivans
3.6 V6 VVT Multiple models
3.6 V6 Direct Injection Ram, Wrangler
3.6 V6 MDS Challenger, Charger, 300, Minivans, Grand Cherokee, Durango, Aspen
3.6 V6 HEV Minivans
3.6 V6 PZEV Sebring, Avenger, Minivans
4.0 V6 Base (no VVT) marine use
4.0 V6 Premium, MDS, no VVT marine use
4.7 V8 VVT Ram, Charger, 300, Dakota, Grand Cherokee, Durango, Aspen
LowRider is offline
post #5 of 22 Old 04-08-2009, 01:34 PM
thaduke2003's Avatar
Yeah- the new Phoenix engine looks to be making some healthy changes throughout the entire Chrysler spectrum. I don't think it'll be too much of a torquer, but more of a nice all around engine. More of an on-road engine, by design- Mark W.
thaduke2003 is offline
post #6 of 22 Old 04-08-2009, 01:42 PM
oz97tj's Avatar
i'm going to go out on a limb and say it can't be much more of a "on road engine" than our 3.8 from the minivans.
It has to be better than what we have.
oz97tj is offline
post #7 of 22 Old 04-08-2009, 01:43 PM
Hah- touche This is true- the 3.8 is an appliance at best. The Phoenix series looks to be a PROPER V6 with lots of very nice touches, no OHV 12 valve POS 3.8L Mark W.
post #8 of 22 Old 04-08-2009, 01:56 PM
oz97tj's Avatar
http://www.allpar.com/mopar/phoenix-engines.html
Good read on the new engines. It does mention, like already posted, that they could be used in the wrangler, but it also states the 3.8 will live until 2014. It just doesn't state what it will live in.
oz97tj is offline
post #9 of 22 Old 04-08-2009, 02:05 PM
idrivejeep's Avatar
The only part of the new engine I don't like is the MDS. I know the technology has been around for years. I'm just not convinced of it's effectiveness when the JK is modified with suspension and larger wheels, where more power/torque is constantly needed to push through the extra drag.
"Chrysler wrote that: “The new Phoenix of V-6 engines will feature cylinder deactivation (MDS)...the engine will operate efficiently on three cylinders when less power is needed, and in V-6 mode when more power is needed. This optimizes fuel economy when V-6 power is not required – without sacrificing vehicle performance or capability." click for more info.
idrivejeep is offline
post #10 of 22 Old 04-08-2009, 02:08 PM
oz97tj's Avatar
The MDS only kicks in when there isn't a load. In other words, when it's idling or coasting it would drop to 3 cylinders.
City driving, idling on the trail. I think it would be good. I don't see where it could hurt anyway.
oz97tj is offline
post #11 of 22 Old 04-08-2009, 02:08 PM
LowRider's Avatar
According to the list that I posted the wrangler won't get MDS. Their is different versions of the same engine.
LowRider is offline
post #12 of 22 Old 04-08-2009, 02:12 PM
oz97tj's Avatar
I just read on another website that it'll make the 280 hp at 6400 rpm! eek.
And torque peak will be at 4800 rpm. With a max rpm of 7200 rpm.
At least it's said to make 90 percent of it's peak power from 1600 to 6400 rpm, so it should be too bad.
http://scoop.chrysler.com/2009/04/08...rand-cherokee/
oz97tj is offline
post #13 of 22 Old 04-08-2009, 02:12 PM
I doubt they'd put MDS in the Wrangler- the system doesn't work quickly enough to be mated with a manual transmission, so it certainly wouldn't be in most Wranglers. In the auto's, who knows? It's all conjecture for now- Mark W.
post #14 of 22 Old 04-08-2009, 02:28 PM
lohchief's Avatar
Screw a new gas engine...gimme a diesel
lohchief is offline
post #15 of 22 Old 04-08-2009, 02:29 PM
Broncojohn's Avatar
That's what I was wondering. If it doesn't make the torque at lower RPM's people are still going to complain.
Broncojohn is offline
post #16 of 22 Old 04-08-2009, 05:12 PM
backroadman81's Avatar
Maybe with this new motor when you put performance mods on you will gain noticable hp and tq. The only way to get something really noticable now is putting in a V-8. or falling off a cliff...Great accelaration then.
backroadman81 is offline
post #17 of 22 Old 04-09-2009, 04:01 AM
Agreed on the diesel- as long as they could make the throttle response/mapping acceptable, that'd be a GREAT Wrangler. Plus you could always get more power and MPG out of a diesel. My worry would be that some jackass would put smokestacks on a Wrangler- yuck! Or people on the trail spewing black smoke everywhere- that'd shut us out of a lot of places because some redneck thinks it's COOL- idiots... Mark W.
post #18 of 22 Old 04-09-2009, 12:21 PM
oz97tj's Avatar
A diesel would be way cool. Imagine the torque...
The problem is with all the emissions stuff that is required. It would raise the price considerably, and hurts that fuel economy.
In other words, as much as I'd love a diesel, I'm thinking a good running gas engine would be a better option.
oz97tj is offline
post #19 of 22 Old 04-09-2009, 12:25 PM
lohchief's Avatar
I'll take the diesel,the increased cost to buy,and live happily ever after in the land of torque.
lohchief is offline
post #20 of 22 Old 04-09-2009, 01:15 PM
Oz- a diesel would IMPROVE fuel economy, dude. Especially since it would likely have enough torque to get the darn Wrangler out of its own way on stock tires, unlike the 3.8, so real-world mileage would also improve, although for the rock crawlers, it might get a bit worse- ya never know! Mark W.
post #21 of 22 Old 04-09-2009, 01:19 PM
lohchief's Avatar
I had the 2.8L crd libby that we got rid of last year,loved the engine/trans,hated the rest of it though.Mileage and power was nothing short of awesome and I will get another diesel (wrangler this time) just as soon as I can.After having one,it's a no-brainer.
lohchief is offline
post #22 of 22 Old 04-09-2009, 03:50 PM
yoda13's Avatar
either engine will be an improvement over what we have now...
2007 Jeep Wrangler X, Auto, Hardtop, White, Superchips Flashpaq, 2" OME HD springs, Rusty's Adj. F/R trac-bars, Bilstein Steering Stabilizer, JKS Quicker Disconnects, JKS Rear Swaybar Extensions, PolyPerformance UCAs f/r, Rusty's LCAs f/r, 33x12.5 BFG KM2s, ProComp 15x8 Rockcrawlers, Smitty winch, Body Armor Front Bumper, FLW SS rear bumper, OEM Rubicon Rock Rails, Skid Row Engine and Tranny Skid, Member UFWD & BRC, †John 3:16†
yoda13 is offline
