86 Octane WTF? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 04-07-2009, 08:41 PM Thread Starter
JohnnyWalker's Avatar
86 Octane WTF?
I live in El Paso, TX. Never in my life have I seen 86 regular gas. "Super" is 88 and premium is 91. I like to run the 88, but does anyone know what might happen if I go to 86?
JohnnyWalker is offline
post #2 of 11 Old 04-07-2009, 08:51 PM
afoulk's Avatar
slight loss of power or fuel mileage if anything at all. Should be ok though, your knock sensor should sense any pinging and tell the ecu to retard the timing a bit.
SOLD-08 Unlimited X, "jeep green", auto, limited slip, hushpower muffler, Aerotech Interceptor gauge,Powerstroke tranny cooler, skidrow evap skid, AFE Pro 7 filter, Teraflex leveling kit, EVO control arm skids, 15x8 Black Rock 909's, 33" KM2's
afoulk is offline
post #3 of 11 Old 04-07-2009, 09:09 PM
Mule'Con's Avatar
MON & RON ratings are different for each state, but CA has regular unleaded at 87 mon, and it works fine it most vehicles. If your stock, premium or high test is a waste of money. Just make sure you use brand rated fuel most or all of the time, and you can offset with some Costco or RottenRobbie in between.
2008 Red Rock Rubicon Unltd 6spd dual top
Mule'Con is offline
post #4 of 11 Old 04-08-2009, 06:05 AM
You probably won't notice any difference. what is the elevation of el paso? I would say that it is above 2500, so that would probably be the reason.
DO NOT DO BUSINESS WITH SHAFFERS OFFROAD. YOU WILL BE SORRY YOU DID..
igofshn is offline
post #5 of 11 Old 04-09-2009, 11:32 AM
rage344's Avatar
Send a message via Skype™ to rage344
owners manual say to run regular unleaded gas putting in anything rated higher could hurt the system i doubt it but thats what jeep says
Riverraider Rubicon 2 door (under construction)
[QUOTE=priell3;158092] you have the old style with dirty balls.QUOTE]
rage344 is offline
post #6 of 11 Old 04-09-2009, 11:43 AM
Alec W
Guest
Posts: n/a
85 octane is regular gas in Colorado and that all I’ve ever put in all my cars and trucks here. We are at 5000 feet so 86 is probably fine at 2500.
post #7 of 11 Old 04-09-2009, 11:55 AM
gold knight's Avatar
Hmmm.....really, what year is yours? Here's what my '08 manual says.
FUEL REQUIREMENTS
All engines (except 5.7L engines) are designed
to meet all emissions regulations
and provide excellent fuel economy and
performance when using high quality unleaded
“regular” gasoline having an octane
rating of 87. The use of premium
gasoline is not recommended. Under normal conditions,
the use of premium gasoline will not provide a benefit
over high quality regular gasoline, and in some circumstances
may result in poorer performance.
The only mention of damage to the system I could find was from methanol.
EDIT>Oh I just saw you are in California, may be a CA emission thing........
gold knight is offline
post #8 of 11 Old 04-09-2009, 12:12 PM
Where do your information that higher octane will cause damage???? Must be another internet rumor??? Higher octane will not cause damage to you rengine.
igofshn is offline
post #9 of 11 Old 04-09-2009, 03:52 PM
yoda13's Avatar
I have learned the hard way that my Jeep does not like the 86 or 85 octane, elevation or not...so when I am in the mountains, in goes the midgrade...
2007 Jeep Wrangler X, Auto, Hardtop, White, Superchips Flashpaq, 2" OME HD springs, Rusty's Adj. F/R trac-bars, Bilstein Steering Stabilizer, JKS Quicker Disconnects, JKS Rear Swaybar Extensions, PolyPerformance UCAs f/r, Rusty's LCAs f/r, 33x12.5 BFG KM2s, ProComp 15x8 Rockcrawlers, Smitty winch, Body Armor Front Bumper, FLW SS rear bumper, OEM Rubicon Rock Rails, Skid Row Engine and Tranny Skid, Member UFWD & BRC, †John 3:16†
yoda13 is offline
post #10 of 11 Old 04-10-2009, 08:50 AM
rage344's Avatar
Thumbs up
[QUOTE=gold knight;107025]Hmmm.....really, what year is yours? Here's what my '08 manual says.
you are right sir thats what mine says didnt mean to cause an uproar
rage344 is offline
post #11 of 11 Old 04-10-2009, 02:53 PM
No uproar at all (see my prevoius post). I was just asking since I attached a quote directly from my '08 manual pdf which says nothing about damaging the system.
Then I noticed you are in California and figured that CA Emissions must change everything. We're good
