2.5 progressive coils? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 02-06-2012, 11:09 AM Thread Starter
I have the tereflex 3"coils now and would like to find a more comfortable ride as my commute to work is 45 miles each way.
The reason that I want to drop to 2-2.5 is because the jks front and rear Acos system adds a few inches alone.
Any recommendations? Thanks.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #2 of 9 Old 02-06-2012, 11:14 AM
taxman's Avatar
Not sure if progressive coils are going to give you a better ride on the road. I would look into better shock absorbers. I'm using the TF 9550s that came with my TF 2.5" coil lift kit and I find them fairly stiff. I am looking for either Billsteins or Fox with reservoirs and some sort of adjustability to make them softer on the road.
2018 JL Rubicon Unlimited, 6-speed, White
1985 CJ-7, 4-speed, 258 I-6, 3" Springs, 33" BFG AT, Gunmental Gray
taxman is offline
post #3 of 9 Old 02-06-2012, 11:18 AM
PhrogMech46's Avatar
I heard the Rock Krawler progressive springs are awesome. I have Teraflex 2.5 springs and I want to go taller so I think I may go with the Rock Krawler 3.5 springs or Clayton 4.5's. Their springs are competitively priced.
See Garage for Mods
PhrogMech46 is offline
post #4 of 9 Old 02-06-2012, 11:36 AM Thread Starter
I have new bilstein 5100's they made the ride a little better but it still leaves something to be desired.
2008 JK 4Dr Rubicon
Stone white
Painted hard top
Teraflex 3" lift
rob4607 is offline
post #5 of 9 Old 02-06-2012, 12:00 PM
taxman's Avatar
It was my impression (as mistaken as it may be) that progressive rate coils were intended for less compression under heavier loads. For instance, you won't bottom out your progressive rate coils when wheeling with an added 500+ lbs of extra passengers, camping gear, coolers, etc. Linear rate coils would simply compress all the way (as mine have).
I am not aware of any on-road improvement of progressive coils over linear coils when under regular loads. I may be proven wrong here, in which case I will be in the same boat as you. I am also looking for improved on-road manners (hence my previous TF 9550 comment) as well as progressive rate coils since I tend to carry a lot of weight when wheeling with my wife, daughter, a 150lb Great Dane and lots of camping gear.
taxman is offline
post #6 of 9 Old 02-06-2012, 12:39 PM
EMG006's Avatar
I switched my tf 2.5 and their shocks to rk 2.5 and bilstein. Night and day difference to me not as jarring on the road.
I am getting some fox ipfs because I went to taller springs, so need some longer shocks. Will see how those do. I was looking at some adjustables but I don't need remotes plus they are mucho dinero.
River City Offroad
Metal Cloak
EMG006 is offline
post #7 of 9 Old 02-06-2012, 02:19 PM
Sir
Our 2.5" and 3.5" front coil springs are progressive rate coils. The rears are still linear for load stability. We like them and it seems that alot of customers do as well which is most important to us.
Let us know if you have any questions. Good luck with your continued build.
RK
post #8 of 9 Old 02-06-2012, 05:30 PM
austinjeepr's Avatar
I rode in the goat and was totally sold on the progressive rate spring!
They ride like a caddy.
austinjeepr is offline
post #9 of 9 Old 02-06-2012, 06:00 PM
ScaleJK4x4's Avatar
Check out this thread:
Progressive vs. Linear
-Scott S.-
'07 2Dr Silver Rubicon
ScaleJK4x4 is offline
