Modern Deisel Jeep conversions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 89 Old 02-02-2012, 10:16 PM Thread Starter
ezfriday's Avatar
Diesel Engine Conversion Contenders
1. 4bt
2. Duramax v8
3. BMW
4. TDI / Volswagon (might catch a little hell but good info and some badass engineering)
5. Powerstroke 2.8L ... 6.0L ... 6.4L
6. ...
Since the Bruiser thread sort of opened the door for a discussion on better suited diesel conversions I'm re-threading this with a more suitable title.
Bruiser is being set aside ... for now.
Got fairly "Bruised" over that one... Watta tasty Poop sandwich that one was... ... ...
jdemonto suggested the TDI which sounds promising. There is an informative emissions article at
http://www.myturbodiesel.com/1000q/D...AQ-VW-Audi.htm
Originally Posted by jdemonto View Post
How about a TDI conversion more modern,fuel effecient and lighter 330lbs!
http://www.hpamotorsports.com/tdiconversions.htm
ALASHA offered an intriguing BMW possibility. Looking into this.
Innovation in my mind are these new diesels that are smaller, lighter, more efficient and produce alot more power than the 4BT (check out the new BMW diesels in the 3 series as example)
I'm not vehicularly racist (or of any other sort) however I would like to explore domestic alternatives. What possibilities are there with a Powerstroke 6.0L or 6.4L?
Regardless of your personal disposition toward diesel conversions and smog do's & don'ts ... please try to keep the bashing to a minimum. This thread is intended to be constructive not destructive.
Forrest Grumpy
: "Life is like a box of dark chocolates. You never know what your going to get. But when you do, you find you don't like it anyway! "
JK's Rule! 2007 Sahara Hesco Supercharged ~TOYO M/T 35's ~ FabFours ~ 3" Teraflex Premium Shorty Lift~ ...
ezfriday is offline
post #2 of 89 Old 02-02-2012, 10:20 PM
Slow and Low
Co4Lo's Avatar
Fair enough...
I'm putting a jacked up ******* with a manual trans in mine. More info after EJS.
Co4Lo is offline
post #3 of 89 Old 02-02-2012, 10:24 PM
jeeperjkj's Avatar
If there's anything I know about Ford diesels... it's stay away... stay FAR away from that 6.0L. The holy grail would be the 2003 7.3L (or the new 6.7L, but that's a LONG shot).
jeeperjkj is offline
post #4 of 89 Old 02-02-2012, 10:24 PM
Trail Concepts Hmfic
jdemonto's Avatar
You need to be thinking smaller as any funk size truck diesel is way to big for the jk packaging. Domestically a guy in Canada imports a 2.8 powerstroke Ford light duty diesel.
Jd
602-314-5356 or
jdemonto is offline
post #5 of 89 Old 02-02-2012, 10:26 PM
jeeperjkj's Avatar
Canada = domestic? I always thought domestic meant American...
post #6 of 89 Old 02-02-2012, 11:00 PM
jdemonto's Avatar
Its not Canadian is a Euro Diesel made by International for Ford. Currently there are no light duty diesels produced in the states. Event the little 2.8 Crd Jeep liberty was from Vm Motori...Italy!
Originally Posted by Co4Lo View Post
Research the dimensions of the Duramax(LBZ) V8. Will fit nicely.
I know but think about the drive-train that needs to be upgraded!
Jason
602-314-5356 or
jdemonto is offline
post #7 of 89 Old 02-02-2012, 11:06 PM
jdemonto's Avatar
http://www.eastcoastrover.com/ECR4powerstroke.html
More info on the 2.8 PS
Jason
602-314-5356 or
jdemonto is offline
post #8 of 89 Old 02-02-2012, 11:10 PM
jdemonto's Avatar
If you have the coin these guys install the 2.8 VM Panther found in the Euro JK
http://www.dieseltoyz.com/jeep_conversions.html
602-314-5356 or
jdemonto is offline
post #9 of 89 Old 02-02-2012, 11:35 PM
NascarRubicon's Avatar
i worked for a rebuild shop that specialized in ford diesels for 6 years...rebuilding db2 pumps be ae injectors and turbos etc, i will never own a "powerstroke" and discourage anyone from it....yes the 6.0 was horrible...the 7.3 was decent but knocky...the new 6.7 is massive...
that being said
smaller izuzu and hino engines will fit in our jks...duramax is izuzu..,
personally cummins has my vote they are bulletproof...
4bt is a torque monster and an endless supply of parts and it super easy to work on...its a b series so you have plenty of interchangeable parts with ol faithful 12v
"Eat Liquid Gold"
NascarRubicon is offline
post #10 of 89 Old 02-02-2012, 11:51 PM
jeeperak's Avatar
its funny how ppl say the 6.0 was bad...they only issue(and mine never had any issues) was the damn egr shit that would lead to head gaskets..simple fix was an egr cooler and erg valve delete..every diesel has its horror stories and weak points. but i agreen that a smaller td would be best
jeeperak is offline
post #11 of 89 Old 02-02-2012, 11:53 PM
RookieJK's Avatar
HPA is a VW tuning company that has put VW TDI motors in IIRC a YJ and it was pretty damn nice.
Jersey
Crew
RookieJK is offline
post #12 of 89 Old 02-03-2012, 12:00 AM
no that wasnt the only issue...ive rebuilt more 6.0 pumps that i can remember...more than any other pump that came through my shop...even more than the p7100 that was more than a decade older
"Eat Liquid Gold"
post #13 of 89 Old 02-03-2012, 12:01 AM Thread Starter
ezfriday's Avatar
"endless supply of interchangeable parts" ... key ingredient for a trail rig. Like the easy to work on aspect as well. Still looking forward to seeing an actual smog test on the 4bt... Haven't completely negated the "Little Bastard" yet!
Thx 4 the input... the 4bt sounds like the old Chevy 350 of diesels. Too bad we haven't heard something of the smog testing efforts in its' defense. Do you think its possible for the 4bt to pass a diesel smog without Bill Gates backing the build?
Last I spoke with Kenny or Jeff the price tag for a 4bt was around $22k for a well built conversion. More than a gas conversion but that's indicative of a diesel conversion.
Forrest Grumpy
ezfriday is offline
post #14 of 89 Old 02-03-2012, 12:10 AM
jeeperak's Avatar
wow i was reading the other threads..there are a lot of gassers that dont like the idea that a diesel would be a good transplant..maybe if they sat in a rig on 38s that ran a low 13 1/4 mile they would change their minds. ever since i ran my first tune from innovative i was hooked on torque
jeeperak is offline
post #15 of 89 Old 02-03-2012, 12:12 AM
heres your smog test
4BT CUMMINS DIESEL BUGGY 49" IROK ROCKWELL - YouTube
but im sure since youre in ca and you have that whole certified clean idle crap going on youre gonna have to run some sort of filtering system...cummins new filtering system is pretty badass...(the new detroit is even better) but maybe some sort of small scale scr (selective catalyst reduction) system might work...maybe tune the pump back a little lean, whatever needs to be done it can be done...
im no engineer by any stretch of the word but from what ive been seeing just from hino (a toyota group) the shit they come up with is incredible...been doing alot of warranty work for excessive black smoke power complaints etc...what i used to do (up until this MY) is replace injectors, fuel pump, and different controllers....NOW the engineers have figured out the programing so that i can just recalibrate the injectors and fuel pump with a laptop...boom pow trucks back on the road in a few hours vs a day and a half
you can get factory rebuilt 4s straight from cummins now...just got a flyer a few months ago....
"Eat Liquid Gold"
post #16 of 89 Old 02-03-2012, 12:17 AM
jeeperak's Avatar
nuttin wrong with a little coal lol
jeeperak is offline
post #17 of 89 Old 02-03-2012, 12:18 AM
yea i know what you mean...i have the same feeling towards gas that they have to diesel...to me diesel is so much easier and easier to make real power...not just a bump in 15-20 hp/ft lbs but 100 ft/lb boosts with one hx 60...not to mention water/propane injection
"Eat Liquid Gold"
post #18 of 89 Old 02-03-2012, 12:22 AM
jeeperak's Avatar
yeah without digging into the internals.. big stix a snow kit maybe a set of headstuds and a smoking tune...will bring some impressive numbers
jeeperak is offline
post #19 of 89 Old 02-03-2012, 12:25 AM
then go 30 over....
"Eat Liquid Gold"
post #20 of 89 Old 02-03-2012, 12:27 AM
jeeperak's Avatar
jeeperak is offline
post #21 of 89 Old 02-03-2012, 12:46 AM Thread Starter
ezfriday's Avatar
That HPA TDI Volkswagen is looking pretty sweet as well!
http://www.youtube.com/watch?feature...&v=_4VrOgCHzSc
How does it face off with the Bruiser ?
Why aren't my videos showing up in playback window!
Forrest Grumpy
ezfriday is offline
post #22 of 89 Old 02-03-2012, 01:22 AM
SCOUT37JK's Avatar
Canada IS America, just not the united states.
Second
I'm all about the 4bt. Or other 4cyl turbo diesels. In 2004 I had an '85 Pajero 4cyl TD (mitsubishi montero) while in Australia and it was fantastic. The thing I enjoyed most was putting it into 1st gear 4lo and letting out the clutch (yup it was a 5 spd) and crawling up sandy banks after crossing a river. All torque right from the get. Easy to manage power without high revs. Then you get the economy... I drove the entire east coast of Aus and averaged 34/36 mpg some hwy lots of dirt, fantastic. When I came home I was talking to buddy about putting a 4bt into a yj. Jeff beat me to it.
22k is expensive for an engine swap but it is worth it for a complete shakedown turnkey swap.
I had the opportunity to checkout Jeff's personal Bruiser 4bt while I was in FL. It is a beast. Though I wasn't able to take it off road you could tell the power was there. It's not fast but it was turned for economy and will go 75 all day long on 37's without breaking a sweat. It is awesome to feel the power at 1k rpm, the ability to pass on the hwy and still not have to run the rpm's above 3.5k. Easily controllable power that is usable without stressing the drivetrain. If you are going to EJS take the time to go check it out. It has made the short list for my JK once I've paid it off.
I did the math and at the current cost of diesel in CO it would take 13 years to pay back the cost of the conversion with fuel savings. That's if you run regular diesel, if you run waste veggie oil you'll pay yourself back even quicker. I have an 05 dodge 2500 with the 6.7L cummins with just over 50k miles on it and I only get 24mpg out of it when I'm not towing the horses.
Sorry for rambling. If you aren't sold on the 4bt cummins, Do find a 4cyl TD engine of someone's. The power vs weight and mpg is undeniably fantastic.
Does HPA have and vids of their jeep actually moving?
homebuilt JK - blood, sweat, lemonade. renamed LOOSE NUTS
SCOUT37JK is offline
post #23 of 89 Old 02-03-2012, 03:08 AM
The Mitsubishi 4M41 motor would work well.... (it is the current day 3.2 liter version of the motor that you had in that old Pajero)
Miraz is offline
post #24 of 89 Old 02-03-2012, 04:54 AM
What about the 5 cyl Mercedes motors in the Sprinter vans? With as many as are out there, there has to be a supply of wrecked ones.
DudeAbides is offline
post #25 of 89 Old 02-03-2012, 08:32 AM Thread Starter
ezfriday's Avatar
Keep in mind, the goal here is not to simply find a diesel engine that is awesome powerful; but to find one that also has low enough emissions to pass that portion of the smog test when running on everyday diesel.
As I've mentioned in several replies, it would sure be nice to see some tests on the Bruiser.
Same goes for the TDI.
Sent from my C771 using Xparent Blue Tapatalk
Forrest Grumpy
ezfriday is offline
