2012 Gear Chart - JKowners.com : Jeep Wrangler JK Forum
post #1 of 38 Old 01-30-2012, 07:19 PM Thread Starter
2012 Gear Chart
Any body seen a gear chart for the new 3.6 with 5 speed auto? I will be going with 35's and wonder how the 3.73's will hold up. Will not see rocks as I live in south Louisiana. Also how do the 3.73's do on the highway with 35's? A lot of downshifting?
sidwall81 is offline
post #2 of 38 Old 01-30-2012, 09:10 PM
oz97tj's Avatar
The final drive is similar to the manual tranny on older JKs so you can go off that.
Support the sport. GLFWDA.org
oz97tj is offline
post #3 of 38 Old 01-31-2012, 12:44 AM
BillyPete's Avatar
here ya go
BillyPete is offline
post #4 of 38 Old 06-04-2012, 05:11 PM
desertdog702's Avatar
Noob here, how do you read that chart? I guess if you in the green your OK?
desertdog702 is offline
post #5 of 38 Old 06-04-2012, 05:17 PM
yes. So to run 37's on a 12 automatic I only need 4.56 gears. WTF over.
post #6 of 38 Old 06-04-2012, 06:15 PM
Dbreakey's Avatar
Agreed
Dbreakey is offline
post #7 of 38 Old 06-04-2012, 06:26 PM
jadkar's Avatar
This chart is dead on and the 3.6 is pretty wicked. I have a 2012 6spd and I still have the crappy 3.21s running 35s!! I'm currently getting 21mpg during my 120 mile / day commute. 70mph leaves me at about 1700rpm. Granted as soon as I need to pass anyone on the highway or go uphill I need to downshift out of 6th but IMO this is what a true over drive should be anyway. In today's cars it sometimes makes no sense, I have a 2012 TL 6spd and I can accelerate uphill in 6th...that's stupid. I always thought a highway overdrive gear should give you the best performance regarding mileage. Anyway, to solve my shitty offroad performance I just swapped in a rock-trac which now gets me low enough off road even with the 3.21s. I think I'm still gonna re-gear when I drop my lockers in but I'm torn between 3.73s or 4.10 (leaning towards 4.10)
jadkar is offline
post #8 of 38 Old 06-04-2012, 10:05 PM
Thanks for all the info and patients with my questions. Im learning thanks to all of you.
post #9 of 38 Old 06-05-2012, 08:43 AM
DustjunkieScott's Avatar
I've got 3.73's and 35's and it's real close to being good enough. I want just a little more so am going with 4.56's. I know that I will lose a little mileage, but want some more bottom end. If it's flat in LA, I wouldn't change them.
DustjunkieScott is offline
post #10 of 38 Old 06-05-2012, 10:04 AM
racinfast002's Avatar
I have 37's, 3.73's and the shitastic 3.8 and my jeep is fine
Justin
2009 Sahara Unlimited-The Saharacon
Just hanging out in the land of the banned
racinfast002 is offline
post #11 of 38 Old 06-13-2012, 11:17 PM
I call BS. That's a horrible combination. That combo kept me out of a JK until 2012.
post #12 of 38 Old 06-14-2012, 12:02 AM
glomb23's Avatar
I'll have to second this notion... Although I do own an 11, but I'm running 5.13's with 37's and I wish I went 5.38. I can't fathom 3.73's....
Greg
glomb23 is offline
post #13 of 38 Old 06-14-2012, 04:34 AM
Here are a couple of links for some good info.
http://www.motorauthority.com/specif...formance-specs
You'll have to choose the right vehicle for the specs on the above link.
http://www.grimmjeeper.com/gears.html This one does all the math for you.
Rtone1583 is offline
post #14 of 38 Old 06-14-2012, 03:27 PM
The chart above is incomplete, at what speed do you get these revs ?????!!!! it should show, but it doesn't.
Should look like this
gohard is offline
post #15 of 38 Old 06-14-2012, 03:56 PM
BullyWagon's Avatar
It says 70mph. Red upper left corner.
BullyWagon is offline
post #16 of 38 Old 06-14-2012, 03:58 PM
sahara mist's Avatar
The chart for the 3.8 is not quite right. I have 35s and 488s. The chart says I should be running 2756 rpm with manuel transmission. I actually run 3200 rpm at 70 mph.
07 2dr 35s 3.5 spring lift,rear 4.5 front 488s winch, TnTfront stinger bumper,flow master exhaust.
sahara mist is offline
post #17 of 38 Old 06-14-2012, 04:21 PM
WranglerSportS's Avatar
I don't get this chart. My jk came with 3.21 and an auto and 32" tires stock. By this reasoning I should not be able to do anything with my gear set.
WranglerSportS is offline
post #18 of 38 Old 06-14-2012, 04:55 PM
loanwolf2005's Avatar
2012. 35's 3.73 Auto and procal for the shift points.....no problems. much better than my old 07. i'd try it first before swapping gears
and no constant downshifting. I do have KM2 35's though so they're more like 34's....or 33.75's....rides perfect for me
loanwolf2005 is offline
post #19 of 38 Old 06-14-2012, 05:04 PM
That's about right imo. I wouldn't want that setup for anything...Certainly get you a trans cooler asap.
post #20 of 38 Old 06-14-2012, 05:14 PM
SubCultureNM's Avatar
You're used to the 3.8L. My wife's '12 with the auto, 3.21s and 33s runs great. The 80 additional h.p. makes a huge difference.
That said, I am going to 3.73s, because I can.
1997 TJ with LOTS of stuff.
2011 2DR Rubicon with stuff.
2012 JK8 with some stuff.
SubCultureNM is offline
post #21 of 38 Old 06-14-2012, 06:37 PM
my 12 with 255's & 3:21's is at 1900 @ 70mph on average I'm at 19mpg roughly ( slightly higher)
I'm going up to a 285 ( 33"s) by years end & should be around the same point I'm at now......I would think by this chart
Pete1971 is offline
post #22 of 38 Old 06-14-2012, 07:18 PM
I was talking about the chart BillyPete posted, not about mine (that was the whole point why I posted)
On a hindsight I just noticed that the first chart refers to 2012 engines (I have to open my eyes better next time)
gohard is offline
post #23 of 38 Old 06-14-2012, 07:22 PM
BullyWagon's Avatar
I was talking about the chart BillyPete posted, not about mine (that was the whole point why I posted the)
Ahh ha! Sorry. :-)
post #24 of 38 Old 06-14-2012, 10:22 PM
Dbreakey's Avatar
I'm just gonna post for fun here. I'm on half tread 35" km2s which are barely 35" when new and on a good day. I've got a stick and 5.38s. I run about 31-3200 at 70.
Dbreakey is offline
post #25 of 38 Old 07-11-2012, 11:46 AM
phmizban's Avatar
wow this chart made my day.. looks like I should be fine w/ 35's and my factory 4.10's
phmizban is offline
