One More "Air Down" Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 01-06-2012, 06:51 PM Thread Starter
I have a 2012 Sahara Unlimited, completely stock. I am new to Jeeps and new to off-roading. I bought a portable air compressor and these little brass gadgets to air down. Question: Since I was upplied with four of these brass "deflators" should I set each at a different pressure and use the same deflator on all four wheels, one at a time, or do most people set all four at a desired psi and then place them on all at once on each wheel to hurry the process? Thanks everyone.
tryengel is offline
post #2 of 7 Old 01-06-2012, 06:55 PM
HeloJeff's Avatar
Set them all at the same pressure and go around and put them all on. Will save you some time. Those deflators have a tendancy to loosen up sometimes so tighten them good and check the pressure setting occasionally.
HeloJeff is offline
post #3 of 7 Old 01-06-2012, 10:54 PM
the intent is that you use all 4 to drop the pressure easily. Screw them on, disconnect your swaybar and then go unscrew them. Some people though will only use 2 at a time, basically running 2 sets with different pressures if they do a different config like for a beach vs the trails.
whatevah is offline
post #4 of 7 Old 01-07-2012, 02:24 AM
CeeeJaySeven+JKU's Avatar
What compressor did you buy that had this with it? I've been wanting to buy a portable compressor.
Big B.
2011 4Dr Unlimited... Rubi springs & shocks, Rubi tires, JKS QD's, CoverKing Seat covers, Rugged Ridge trail doors, A.C.E. stubby bumper, A.C.E. Rock Rails, A.C.E. Hi-lift jack mounts, Superwinch LP8500.
1983 CJ7 LAREDO, AMC 360, 5" lift, 33's
CeeeJaySeven+JKU is offline
post #5 of 7 Old 01-07-2012, 05:45 AM
DaK
He stated that he bought the compressor AND these little brass things. Am of the thought that they did not come as a set.
Staun makes deflators, might be the brand he has. Don't know.
DaK is offline
post #6 of 7 Old 01-07-2012, 10:23 AM
HeloJeff's Avatar
Smiitybuilt make simular deflators
HeloJeff is offline
post #7 of 7 Old 01-07-2012, 12:57 PM
SoK66's Avatar
I had nothing but trouble with those little deflators. Minwe were Oasis. They'd either stop before they got to the pressures at which I'd preset them, or they wouldn't stop. I fonally just got a Currie gauge setup, no muss, no fuss. Works perfectly every time. Faster, too. Only thing faster is the secondary vale stems.
SoK66 is offline
