Fueling issue - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 01-04-2012, 02:49 AM Thread Starter
Fueling issue
Let me preface this by saying that I am sure I will be getting many technical terms wrong.
When I refuel (buy gas), I cannot dispense more than .250 gallons at a time without getting that annoying clicl/stoppage of the fuel pump as if the tank is full. HAs anyone else experienced?
2008 Unlimited, 2" Basic lift from Rusty's, JK quick disconnects,
Firestone MT 285 75 16 mounted to
Cragar Soft 8's 16x8 w/5" backspacing
ChatterBox is offline
post #2 of 11 Old 01-04-2012, 03:28 AM
I get this all the time and it really pisses me off.
08 Detonator Yellow Rubicon-RE Arms-37" Mt/R's with Kevlar-Riddler Diff Cover-LoD stubby with Stinger-LoD stubby tire carrier-Warn M8000 Winch-Rigid D2's-20" Rigid Light Bar-SPOD-PS Rocker Knockers-PS Body Armor-5.13s-hydro assist-RCV shafts-IPF-Corbeau LG1 seats-12" King coilovers-AEV Hood-AEV Snorkel-5.7L VVT Hemi-AEV hemi Install Kit-4.5" AEV Springs-ProRock 44-AlloyUSA Rear shafts-Spyntech Hubs-Raceline Monters-
Fishyguy is offline
post #3 of 11 Old 01-04-2012, 04:05 AM
Does it happen at any gas station that you try? I've noticed that some of the stations in my area do this.
Most likely there's something wrong with your evap canister. When I relocated mine to over my rear axle one of the hard plastic lines got kinked. When ever I would go to fill up the fumes would build up in the fill tube and cause the fuel pump to shut off.
Take a look at you evap canister and all the tubing that goes to your fuel tank, make sure that none of it is cracked.
By any chance do you get the "gas cap" message on your dash whenever you start your Jeep?
HOT_DAMN is offline
post #4 of 11 Old 01-04-2012, 11:13 PM
lbh
lbh's Avatar
Check for the recall. Mine did this and always pissed me off, not to mention burped fuel. I received a recall, something about the valve, but to replace the valve they needed to replace the entire tank! Had the recall done and have no issues since. I have a 2007.
2007 JK
lbh is offline
post #5 of 11 Old 01-05-2012, 08:00 AM
jkx0778's Avatar
I get the same thing. I have to refuel very VERY slowly for about 5 gal. Then I can usually bump it up a little. It's always "fun" trying to find the right balance to keep the pump to stopping
I got the recall to replace the entire tank... but since my skid is beat to sh!t they wanna change me for a new skid too. They won't wrestle with it to try to get it back on.
________________
jkx0778 is offline
post #6 of 11 Old 01-06-2012, 12:31 AM
lbh
lbh's Avatar
Is that really an option for them on a recall?
2007 JK
lbh is offline
post #7 of 11 Old 01-07-2012, 06:30 AM
Monster Jk's Avatar
Feedback: 23 reviews
Mine did that and had the fuel spillage. Chrystler is replacing mine today!!! Have you tried that Sean?
Monster Jk is offline
post #8 of 11 Old 01-07-2012, 06:51 AM
Well trying to get Lithia Jeep here in FOCO to do anything is like pulling teeth so Im going to try another stealership soon
Fishyguy is offline
post #9 of 11 Old 01-07-2012, 06:57 AM
lineman's Avatar
Mine would over glow all the time I let the dealer look at it they said there was a recall on the tank, all good now.Hope you find the problem soon
BUY AMERICAN MADE STUFF THE JOB YOU SAVE MIGHT BE YOUR OWN
AEV 4.5 Lift , Black Rock rims with 35''Goodyear MT/R , Viair compressor , 2 ARB's , 5.13 gears and RCV front axle.
lineman is offline
post #10 of 11 Old 01-07-2012, 07:13 PM
I have a 2010 and mine doesn't do it.
jchurch is offline
post #11 of 11 Old 01-08-2012, 11:27 AM
Monster Jk's Avatar
I'd try John elway jeep in greeley, it's right off hwy 34. But first, I'd call jeep and create a case. They will contact the dealer and get every thing worked out.
