Hard top leaking - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 12-30-2011, 01:25 AM Thread Starter
Grunt's Avatar
Hard top leaking
I have heard several reports of the hard tops leaking anyone have this problem?
Grunt is offline
post #2 of 15 Old 12-30-2011, 01:32 AM
Most seem to. And for a short while that I had a hard top (Jeep are made to have a soft top) I had this issue but learned a few things from trial and error....
First of all, its important to keep the rubber gaskets clean. Dust can prevent them from creating a tight seal. Second. When tighting them, use the same basic star pattren to lock the dog latches and hand screws as you do when mounting a wheel on your rig. That little bit of info made my hard top leak go away. Good luck!
post #3 of 15 Old 12-30-2011, 11:05 AM
Only when it rains...
3.5" Rock Krawler Mid-Arm Flex, Bilstein 5100s, Smittybuilt XRC Rear Bumper & Tire Carrier, AEV ProCal, 37" Nitto TrailGrappler MTs, MB 72s, 5.38s, C Gussets
RoachJeep is offline
post #4 of 15 Old 12-30-2011, 11:59 AM
jkron's Avatar
Syl glyde works magic stopped all of my leaks
jkron is offline
post #5 of 15 Old 01-01-2012, 05:37 PM
On my '08 I had a minor leak the first rain. I cleaned the seals with a damp rag and have not had an issue since. Was it dirty or just alignment, who knows.
2008 JK Rubicon
86ish Formula Toyota
OlMan is offline
post #6 of 15 Old 01-01-2012, 07:07 PM
RyanJKU12's Avatar
not mine
Ryan
BAM. Me, "wonder what that was?" Tom, "pretty sure it was the top of something coming into contact with the bottom of your Jeep."
Jersey
Crew
RyanJKU12 is offline
post #7 of 15 Old 01-02-2012, 10:21 AM
RINGO's Avatar
Also a good idea after cleaning the rubber seals to hit them with Silicone.
RINGO is offline
post #8 of 15 Old 01-02-2012, 10:43 AM
dyaudio's Avatar
Yes i had a bad leak problem at the top corners of my front doors. I went to home depot and purchased foam rubber weather strip. Now no more leaks
dyaudio is offline
post #9 of 15 Old 01-02-2012, 11:30 AM
BigLig's Avatar
I have an 08' Unlimited and actually had water inside my passenger side top. I removed the top, drained it, then put the top back on. I haven't had any problems since.
2008 Sahara Unlimited Rescue Green
RockKrawler 2.5" Flex System
Bilstein 5100 Shocks
SpiderWeb SW1 JK-4D Top
Smittybilt Grab Handles
AntennaX 13" Off-Road Antenna
Smittybilt SRC Front Bumper (Chopped)
More to come
Find and Sell Your Used Parts on
BigLig is offline
post #10 of 15 Old 01-02-2012, 12:38 PM
V8 dreams
jvandy50's Avatar
I had warranty left so I let dealership replace the door seals. I had standing water after removing my passenger carpets. This was with trektop or hardtop. I can find a drop or two now but not an inch of water in the floorboard. Probably gonna bedliner tub soon anyway
Vandy
2010 Silver JKU
jvandy50 is offline
post #11 of 15 Old 09-12-2014, 02:13 PM
hello I have a 2013 jk 2 door with the freedom hard top and a few weeks a go they started filling up with water took it to the dealer they didn't know why hear is what I have found out the tops are separating at the seems just a lil fyi
curtis008 is offline
post #12 of 15 Old 09-19-2014, 07:50 AM
soonerfan85's Avatar
My hardtop will sometimes leak a little just above the rear view mirror. Doesn't leak while driving, but water seems to pool up in there somewhere and then first time I stop the water (think less than half an ounce) will pour onto my dash and radio. Now I keep a paper towel or two stuffed between the latch and roof and it catches any uninvited water. Need to clean my seals as we had the top off most of the summer, and judging by the looks of my interior, we drove some pretty dusty roads.
soonerfan85 is offline
post #13 of 15 Old 09-19-2014, 09:22 PM
Minewas fine last winter but just put the roof back on and its leaking above the mirror
ivantate is offline
post #14 of 15 Old 09-20-2014, 09:33 AM
SoK66's Avatar
Rock Hard 4x4's crap roll cage pulled my side bars inward and hosed my tops formerly perfect alignment. The side bars have index holes that set the alignment and thus the sealing. They anchor on the windshield frame and can be moved via an adjustment screw, which is accessed through the upper hole on the "A" pillar trim cover. The other two bolts are the large ones on either side of the sunvisor mounts. With the tops installed and latched down loosen the front two bolts on each side and see if the tops settle into the seals. If the need to be pulled to the sides, tighten the bolts through the upper "A" pillar hole a bit. If they're too far to the sides, have someone push them in, or ratchet strap them a bit.
Rock Hard's overhead bar was too short and pulled my side bars in too far. I had to clearance the indexing hole on the driver side to get the top to seal.
SoK66 is offline
post #15 of 15 Old 09-20-2014, 11:32 AM
ratchettt's Avatar
Mine has leaked from day-1. Drips on right rear front passenger seat. Gave up on warranty and live with it.
2013 JKR, Auto, Yukon 4.56, Nitto Trail Grappler 35/12.5/17 on XD222 KMC Enduro Beadlocks,Teraflex Big Brakes & Spare Carrier, Warn RC Winch, Metalcloak Front & Rear Bumpers, Metalcloak Overliner Flares & Front Inner Fenders w/ Corner Guards/Tail Lamps, Metalcloak Game Changer 2.5" w/6-Pac's, ARB Diff Covers & Onboard Air, AFE High Tuck Muffler, Front Lower Control Arm Skids, Artec Aluminum Skid System, Poison Spyder Hood Vents, Ripp SC.
There are no winners here; just beguiled participants
ratchettt is offline
