Doing some welding on the jeep - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 12-23-2011, 03:37 PM Thread Starter
JKRubicon90's Avatar
Looking to do some welding on the jeep tommarrow, and I was wondering is their anything I should know before I start welding?
-Dan
JKRubicon90 is offline
post #2 of 18 Old 12-23-2011, 03:39 PM
Do a good job, we're all watching you.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #3 of 18 Old 12-23-2011, 03:48 PM
Disconnect the battery!!
adaygeorge is offline
post #4 of 18 Old 12-23-2011, 03:55 PM
samuelrclark's Avatar
Hahaha... really good tip.
2008 JKU, ProComps, 35 Kevlar MT/R's, Dana 44s, locked, 5.13, Artic Trusses, RCVs, all types of OR-Fab stuff, PIAA's, 2.5in Suspension lift, Adams driveshaft, Teraflex SpeedBumps, Warn Winch and some other goodies...
Originally Posted by larry0071 View Post
Old shit needs fixed. Facts.
Shit run off-road needs fixed. Fact.
Old shit run off-road needs fixed more often yet. Fact.
samuelrclark is offline
post #5 of 18 Old 12-23-2011, 04:03 PM
Apt
I Put the FU in FUN
Apt's Avatar
Ground good and solid close to the work area. gloves, mask, bare skin covered.
enough wire, gas to finish.
Apt is offline
post #6 of 18 Old 12-23-2011, 04:39 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
If you're welding near bushings, seals, or other critical things like wiring, wrap those items with wet terry towels to keep the heat down.
Wear long sleeves, pants, and close toed shoes.
Have cold beer on hand but drink those after you weld so the beads come out straight.
JKCTAZ is offline
post #7 of 18 Old 12-23-2011, 07:18 PM
quaylefarmer's Avatar
Make sure everything is clean before you start (no paint, coatings, grease, etc...)
Tack it at each corner before you start burning it all in (be aware that heat = warpage)
Take your time.
Get comfortable before you start.
If you get frustrated just stop and take a break.
Dial in your heat and wire speed on some test pieces before you are welding on the final goods.
Watch a few YouTube how to videos to get you started.
quaylefarmer is offline
post #8 of 18 Old 12-23-2011, 07:29 PM
Don't clean anything you plan on welding with brake clean
+ I've never disconnected my battery, for my whole rear cage...no issues.
post #9 of 18 Old 12-23-2011, 07:43 PM
brokenleaf's Avatar
Word... That stuff puts off poison fumes if heated.
I never disconnected my battery either.
-Jeff
KG6VPY
brokenleaf is offline
post #10 of 18 Old 12-23-2011, 08:06 PM
ADDICTION II build begins....
TXROCK's Avatar
Take a welding class?
U.S. Army
TXROCK is offline
post #11 of 18 Old 12-23-2011, 09:55 PM
Ditch55's Avatar
Guy's he is using JB weld
Ditch55 is offline
post #12 of 18 Old 12-23-2011, 10:06 PM
TXROCK's Avatar
U.S. Army
TXROCK is offline
post #13 of 18 Old 12-23-2011, 11:28 PM
Ive never disconnected my battery either, never had a problem but I can see where it could cause some issues.
If your welding on the frame make sure its clean, I always have trouble with frame penetration.
HOT_DAMN is offline
post #14 of 18 Old 12-23-2011, 11:42 PM
Oh, and you HAVE to post some pics of the welds
post #15 of 18 Old 12-24-2011, 06:21 AM Thread Starter
Now your just setting me up for some torture
I have to fix my shittybilt tire carrier, the latch vibrated so much it wore the metal down and it doesnt keep close anymore. So I might have to extend the latch end a little farther then put on one of those 90 degree latchs. Also my piece of tubing that goes over the shaft is starting to crack.
I have to put one of these at the one end since my latch is broke
This is where my tubing is cracking.
***Cant do it today I have other plans that are going on now.
post #16 of 18 Old 12-24-2011, 07:03 AM
Broncojohn's Avatar
Ground to the frame of the rack and not the bumper. It rare but you can spot weld the bearings in the hinge. I've only seen it happen when welding the Jesus nut on the old CJ two piece axle with an arc welder, but you never no.
Sent from my little magic box.
Broncojohn is offline
post #17 of 18 Old 12-24-2011, 02:35 PM
cfpd1724's Avatar
Take a grinder and "v" the crack out a bit then fill that do not just do a cover pass there is way less strength in a cover and if you dont take it off and do it on a bench in position start at the bottom and work up its also a much stronger weld than going from top to bottom even know top to bottom is much easier. If you mess up drink a beer then try again by the end of the night with enough beers you wont care and it will be perfect
Can't say
cfpd1724 is offline
post #18 of 18 Old 12-24-2011, 06:14 PM
You don't have to disco the battery. Tons of welding on the JK and zero issues.
NOVA4x4
