5.13 gears w/ 6 speed - JKowners.com : Jeep Wrangler JK Forum
 4Likes
post #1 of 143 Old 12-18-2011, 08:50 AM Thread Starter
rdlynch2's Avatar
Im curious as to how the daily driveability is with this set up. I have read a few places that some people have to start out in 2nd gear....why would that be?
I have been debating 4.88 and 5.13 for a while now. Dont want to end up making the wrong decision. I am on 35s.
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #2 of 143 Old 12-18-2011, 08:57 AM
lbeato's Avatar
I had 5.13 on 37's on my 08. I liked the set up but I took a hit on gas mileage. And yes 1st was really short. If yours is more of a daily driver especially with 35's I would look more at the 4.88's JMHO. Now with my 12 when I do get my lift and tires (which will be 37's again) I am going to go with 4.88's. I think the 5.13's will be too much.
2012 SLV JK Unlimited Rubicon
lbeato is offline
post #3 of 143 Old 12-18-2011, 09:55 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I have 37s, 5.13s, and a six speed in my Jeep and I would only recommend 4.88s if your highway speeds are 70+.
There is a small difference in RPMs between 4.88 and 5.13s at about 70 but it's enough to keep you down under 3k rpms.
If your highway speeds average 55-60 then just go 5.13. First will be similar to your Jeep stock. I still use it on mine but you're shifting quick, as in before you get through the intersection.
Why you ask? Because you are tremendously increasing your gear ratio which makes the engine's RPMs climb much quicker.
Marcus
RiverCityOffroad is offline
post #4 of 143 Old 12-18-2011, 10:20 AM Thread Starter
rdlynch2's Avatar
Marcus
Yeah I don't do much highway driving as is. And if I do it is in the 55-65 range. I drive it back and forth to work/school/appointments, etc. usually all within 15 miles of each other. I would say I put about 10K on a yeah. Lots of stop and go city driving. Usually once a month weekend wheeling adventure. The 5.13s off road I can only imagine how big of an improvement it will make.
rdlynch2 is offline
post #5 of 143 Old 12-18-2011, 03:04 PM
2007 2 door 5.13 37" mtr/k 6 speed I don't do a lot of highway driving, get around 15mpg, great off road. I think it is fine driving around town. 1st to 2nd is a quick shift.
post #6 of 143 Old 12-18-2011, 05:36 PM
Gearing thread #5? by the OP. Oy, they say repetition is the best way to learn I guess.
post #7 of 143 Old 12-18-2011, 05:48 PM Thread Starter
rdlynch2's Avatar
dude, settle down. does it really bother you that much? i simply want to hear from people who have this gear set, and if they are happy with it, or wished they had gone with something else, for on road purposes at least. this is not something that was debated in my previous threads, the few others i had created before were on transfer case, low end gearing.
rdlynch2 is offline
post #8 of 143 Old 12-18-2011, 06:58 PM
SubCultureNM's Avatar
I'm running 5.13s with 35-inch KM2s (more like 33.5 inches) in my 6 speed 2011 Rubicon. It took some getting used to, but I like the combination a lot now. I'm turning 3,000 RPM at about 74 mph, so I generally try to keep it at 70 mph. I had them installed in September, I believe, and already have 10,000 miles on them.
Reddogracing likes this.
1997 TJ with LOTS of stuff.
2011 2DR Rubicon with stuff.
2012 JK8 with some stuff.
SubCultureNM is offline
post #9 of 143 Old 12-18-2011, 07:29 PM Thread Starter
rdlynch2's Avatar
Is it the fact that the rpms go up so high, so quickly, that results in it taking some getting used to?
rdlynch2 is offline
post #10 of 143 Old 12-18-2011, 07:37 PM
The higher average RPMs took some getting used to. With stock 4.10s and the 35s my sixth gear was virtually unusable. I don't recall what my RPMs were at 75 with stock gears, but they're a hell of a lot higher now (of course). I probably would have been OK with 4.56s or 4.88s, but I wanted to do it once and once only. I may eventually run 37s.
post #11 of 143 Old 12-18-2011, 07:50 PM Thread Starter
rdlynch2's Avatar
True dat, thats what my thinking has been. I don't want to re-gear and end up regretting not going lower. And, 37s one day, are in my future (hopefully, as long as I can get rid of the turd I have up front).
rdlynch2 is offline
post #12 of 143 Old 12-18-2011, 08:00 PM
e-jeep's Avatar
Feedback: 12 reviews
37s; 5.13s; 6 speed ...love it!!
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #13 of 143 Old 12-18-2011, 08:29 PM
Jbsmith44's Avatar
37's mtr kevlars with 5:13 6speed on 3.5 lift 15mpg and love it. 1st gear I only use offroad now though.
Jbsmith44 is offline
post #14 of 143 Old 12-18-2011, 09:03 PM Thread Starter
rdlynch2's Avatar
1st gear sucks anyways. Haha. Except in 4lo
rdlynch2 is offline
post #15 of 143 Old 12-18-2011, 09:13 PM
Jbsmith44's Avatar
Looks like we are on the same page then LOL
post #16 of 143 Old 04-18-2012, 11:21 PM
rballman's Avatar
I know, old thread but hell I am in the same boat! Got a 2dr 6 speed too and need to decide between 4.88s and 5.13s...eventually moving to 37s too. I originally wanted 5.13s but now am thinking about going with 4.88s because the teeth are bigger and stronger? Is this right? Thoughts on the teeth side of things?
And yes I have seen the chart...more interested in the teeth question.
Thanks.
2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s
rballman is offline
post #17 of 143 Old 04-18-2012, 11:28 PM
I wouldn't run 5.13s on any smaller tire than a 37 with the 6 speed. First gear is extremely short with the 5.13s and you have to really work the clutch to get it rolling in 2nd on 37s. I do anyway.
post #18 of 143 Old 04-19-2012, 04:01 AM
toymaster's Avatar
Its all about your altitude.
I have 35" 6 sd 5.13s In the Rockies 5,000ft. and above I say go 5.13s. If you are mostly at sea level 5.13s are too short. This winter I spent months at the AZ/Mexico border and have to say I started out in 2nd then went to 4th then 6th gear often.
In the rockies it is a whole different story I have to start off in 1st most of the time or give it a lot of fuel to not go dead.
JK 2dr rubi
toymaster is offline
post #19 of 143 Old 04-19-2012, 05:58 AM Thread Starter
rdlynch2's Avatar
So engaging first gear with this ratio takes longer or takes less time? And instead of starting out in second couldnt you just immediately shift from first to second gear once its engaged?
The difference btw 5.13 and 4.88 is pretty small as is so with both ratios first gear would be pretty short
rdlynch2 is offline
post #20 of 143 Old 04-19-2012, 06:01 AM
So engaging first gear with this ratio takes longer or takes less time? And instead of starting out in second couldnt you just immediately shift to second gear once its engaged?
1st is very short, takes very little time to wind through first. And yes you can immediately shift, however...that gets pretty old.
post #21 of 143 Old 04-19-2012, 06:02 AM
You will rev up faster in 1st and will need to shift a bit sooner that is it. Those gears are pretty close (4.88 vs 5.13) If you run the mountains 5.13 would be a better choice to hold speed on steep grades. If you run a lot of highway speeds on flat ground then 4.88 would be a better choice for a bit better mpg and a little bit quieter ride from fewer rpms at speed.
post #22 of 143 Old 04-19-2012, 06:05 AM Thread Starter
rdlynch2's Avatar
Are the lower gears harder on the stock clutch?
rdlynch2 is offline
post #23 of 143 Old 04-19-2012, 06:06 AM
Should make it easier on the clutch, driveshafts, and engine.
post #24 of 143 Old 04-19-2012, 06:06 AM Thread Starter
rdlynch2's Avatar
Either way, im getting 5.13s installed this weekend and I have a 6 speed on 35s so I will be able to let you know how it is very soon!
rdlynch2 is offline
post #25 of 143 Old 04-19-2012, 06:10 AM
I hope you are planning on bigger tires, you will be spinning some pretty good rpms at highway speed.
