Defroster Air Re-Direct - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 12-15-2011, 04:44 PM Thread Starter
Butkus34's Avatar
Guys in the colder climates know what I'm talking about, the defrost just doesn't seem to get to the upper corners of the windshield on the JK's. I have been thinking of making some sort of deflector for the air and so far this is what I came up with. It's made out of acrylic and is 15 inches wide by 3 inches tall. It's works great, but I might make a few more mods to it.
Looking through the windshield at the fins
Top view looking down
Backside of fin plate
2007 JK Unlimited Sahara, Blacked Out
3.5 inch lift sitting on 35's
Poly Performance/Synergy Suspension Ball Joints
Smittybilt Oversized Tire Carrier
Butkus34 is offline
post #2 of 5 Old 12-15-2011, 04:46 PM Thread Starter
Butkus34's Avatar
I spray painted it black, but have access to a Laser Etcher so will probably put something stupid on it. I am gonna keep checking how it holds up and what needs to be approved and then will do a write up on how I built it, it's quite simple, I'm sure some have already done this and are fully capable of making something similar.
Also, in the third pic you can see how I bent some flat iron to hold my otterbox clip for my I Phone, it is screwed into the dash under the top plate.
Butkus34 is offline
post #3 of 5 Old 12-15-2011, 04:50 PM
EAD Offroad's Avatar
Does it come off easy? Nice idea for sure
Alec Wallis, Owner |
| 303-918-6167
| 888-521-0170
EAD Offroad is offline
post #4 of 5 Old 12-15-2011, 04:55 PM Thread Starter
Butkus34's Avatar
absolutely, I don't have it stuck down and it lays flat on the dash basically. To move it you just pick it up. I'm looking for ideas to do a simple hook on each front end to clip under one of the factory grid fins to help hold it in place for when the jeep is climbing or somewhat on a lean. might just even do simple patches of velcro as it's pretty light weight.
Butkus34 is offline
post #5 of 5 Old 12-15-2011, 05:20 PM
dtcc687's Avatar
i have been thinking about doing something about this since i bought the jk. i was thinking about just cutting some holes in the corners of the dash. since it only blows from the center. i wanted something a little more lo profile. i haven't looked at the duct under the dash yet but if needed i could run some plastic tubes to the cut outs i make.
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
