Hardware for Rubicon Rock Rails - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 12-15-2011, 02:55 PM Thread Starter
jku09's Avatar
Guys I have been searching all day for this kit. Called dealer but he said they dont sale together and the bolts are $10 a piece for 12...
Could i go to Home Depot or Lowes and pick this up and what would i be looking for.
Found this link but got kind of confused on the last post. Looking for a solution. Thanks
https://www.jkowners.com/forum/showthread.php?t=4616
jku09 is offline
post #2 of 5 Old 12-15-2011, 03:12 PM Thread Starter
jku09's Avatar
Geez Nevermind I believe i figured it out.
jku09 is offline
post #3 of 5 Old 12-15-2011, 03:14 PM
They will be metric, not sure on the size but lowes or your local bolt store like fastenal will be able to take care of you. Do they mount in the same location as the sahara steps?
post #4 of 5 Old 12-15-2011, 03:38 PM
The Clam's Avatar
I got my hardware from home depot.
~ Clam
The Clam is offline
post #5 of 5 Old 12-15-2011, 06:49 PM
nicholsmf's Avatar
You will need eight 6mm nuts with washers to go on the eight threaded studs on the rails that go through the seam on the bottom of the body.
You will need four bolts and four j-nuts (like these). I don't know the metric size that Jeep lists but I used 5/16". The j-nuts clip into the bottom of the body and the bolts thread through the mounting tabs on the rails into the j-nuts.
If you have a 4 door adjust your quantity accordingly.
I got all my hardware at Lowes. The j-nuts will be in the drawer for specialty hardware or automotive hardware, don't remember which one.
2010 JK - Rock Krawler 2.5 Max Travel Kit - Fox 2.0 IFP Shocks - 37" Nitto Trail Grapplers - Genright Aluminum Tire Carrier - Poison Spyder Front and Rear BFH Bumpers - Warn M8000 - VKS Fab Sliders - Offroad Evolution Full Skids - Teraflex Sleeves - ARTEC Truss - EVO C Gussets - Synergy Bumpstops - JKS Control Arm Skids - Rigid 10" E-Series Light Bar and SRM Backup Lights - ARB Compressor w/ 5 Gallon Viair Tank - Offroad Evolution Half Doors
nicholsmf is offline
