Exhaust Manifold leak? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 12-12-2011, 06:39 PM Thread Starter
Dittman2564's Avatar
anyone having issue with exhaust system leaks.Particularly at the manifold? My 09 was on the drivers side. i found loose bolts at the pipe flange /manifold. The nut keepers were spread way out on one and useless when bent back. I tightened both sides as needed but still hear a leak. Got to pull heat shield and check manifold at the head. raining...damn.
Dittman2564 is offline
post #2 of 9 Old 12-12-2011, 06:44 PM
It's not uncommon for the driver's side exhaust manifold to crack.
post #3 of 9 Old 12-13-2011, 06:24 AM
UGET IT's Avatar
Has anyone welded this as a repair...........headers are not an option for me at this time.
Method Motorsports
Email:
UGET IT is offline
post #4 of 9 Old 12-13-2011, 06:26 AM
Welding a crack in something cast usually isn't the most successful method. Another manifold probably isn't too expensive?
post #5 of 9 Old 12-14-2011, 06:42 AM
UGET IT's Avatar
I have no idea what replacements cost......? Welding this up can ben done by the right welder with skills.....just do not know any here in the MD or PA area......Nickel Rod would do it.
KC
Method Motorsports
Email:
UGET IT is offline
post #6 of 9 Old 12-14-2011, 06:55 AM
Fklein6768's Avatar
Believe the ds manifold is less than $100 last time I priced it.
Sent from my MB860 using Tapatalk
www.4x4s-pod.com
Fklein6768 is offline
post #7 of 9 Old 12-14-2011, 07:43 AM
UGET IT's Avatar
From Jeep?
Method Motorsports
Email:
UGET IT is offline
post #8 of 9 Old 12-14-2011, 01:35 PM
gold knight's Avatar
From Jeep?
mopardirect something something... whatever that place Tim (Tkob) uses all the time for parts. The dealer is probably still around 100ish.
Just got mine done under lifetime powertrain warranty.
Here's one place: www.moparonlineparts.com
https://www.jkowners.com/forum/showth...haust+manifold
And here's the mac daddy of exhaust manifold poll threads.... be sure to add yours to the list, I updated with my vote just now.
https://www.jkowners.com/forum/showthread.php?t=32058
gold knight is offline
post #9 of 9 Old 12-14-2011, 01:56 PM
sixty5vdub's Avatar
You might try to contact a shop or an individual that has recently done a Hemi swap, and get theirs'.
I gave mine away to a fellow JKer that had the same problem with his driver's side manifold cracking.
AMP
AMP
sixty5vdub is offline
