Installing Dual Din Navi/DVD/CD player in dash on Infinity System. What is this wire? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 11-03-2011, 06:58 AM Thread Starter
Living_Legend's Avatar
There are 3 connections seen in picture one and two. There is the main pin hookup, Orange/Yellow connection and a white connection. I Hooked up the aftermarket unit to the pin and the antenna to the Orange/Yellow connection and got sound/seemed to work. I have not checked each individual speaker yet and I haven’t installed in into the dash. I just held it up to check the connection.
What is the White connection for? it used to hook to the stock head unit. Is it for the back infinity speaker in the trunk? something else?
Wire Guide for Jeep Radio Replacement Interface:
Wire Guild for VALOR DDN-868W aftermarket unit:
Living_Legend is offline
post #2 of 20 Old 11-03-2011, 11:26 AM
dyaudio's Avatar
I thought white was Ant, but i guess it could be yellow. The other one is for Sirius radio.
dyaudio is offline
post #3 of 20 Old 11-03-2011, 11:28 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
It is.................
Dr.Dirty is offline
post #4 of 20 Old 11-03-2011, 11:30 AM
dyaudio's Avatar
You will also need the remove the upper radio bracket. It's the metal thing above behind the connectors.
dyaudio is offline
post #5 of 20 Old 11-03-2011, 12:12 PM Thread Starter
i realized that yesterday, i plan on it tonight when i get home, i also am getting a bypass so i can play dvds while driving, should be here today or tomorrow, so i am driving without music for 2 more days
post #6 of 20 Old 11-03-2011, 12:13 PM
Dr.Dirty's Avatar
Did you try and ground the Pink wire?
Dr.Dirty is offline
post #7 of 20 Old 11-03-2011, 12:20 PM Thread Starter
are you talking dirty or are you talking about the parking brake wire, which is connected to the other parking break wire.
post #8 of 20 Old 11-03-2011, 12:27 PM
dyaudio's Avatar
you need a 2 wire switch one side to the park break wire, And the other to a ground. When you want to watch a dvd flip the switch and it will trick the unit to think its in park. No bypass needed just a switch.
dyaudio is offline
post #9 of 20 Old 11-03-2011, 12:33 PM Thread Starter
oh well, its on its way so it will always work, no need for a switch
post #10 of 20 Old 11-03-2011, 12:35 PM
Dr.Dirty's Avatar
you shouldnt even need a switch
If you just ground the Pink wire that is supposed to go to your parking break you should be fine.......
Dr.Dirty is offline
post #11 of 20 Old 11-03-2011, 12:37 PM
Dr.Dirty's Avatar
You got my post in your other thread right?
You original question about the antenna. The White is AM fm. the Yellow is sirius
Dr.Dirty is offline
post #12 of 20 Old 11-03-2011, 12:38 PM
derfc's Avatar
Not always. Some newer head units expect the following: ground -> open -> ground. So if you opt for a toggle switch, you'll have to flip it twice within a preset time frame.
I installed a 'microbypass' relay when I added the new HU in mine. It's TINY, works perfectly, and only cost me about $7 (shipped).
derfc is offline
post #13 of 20 Old 11-03-2011, 12:41 PM Thread Starter
yup, when i hooked it up the radio worked when hooked into the yellow, so i guess white is sirius
post #14 of 20 Old 11-03-2011, 12:41 PM
dyaudio's Avatar
I sold Valor in the past i think you are correct.
dyaudio is offline
post #15 of 20 Old 11-03-2011, 12:41 PM
Depending on what your new headunit is some do not even need a ground/switch.
My kenwood in my old blaZeR2 i googled and found the "store display" bypass that went into a hidden menu and was able to turn brake activation off for good.
beedle4 is offline
post #16 of 20 Old 11-03-2011, 12:48 PM
Dr.Dirty's Avatar
Id double check because looking at the cables Sat radio doesnt uses Coax that large.
Dr.Dirty is offline
post #17 of 20 Old 11-03-2011, 12:50 PM
dyaudio's Avatar
the Ant adapter will fit both but am/fm should be white
dyaudio is offline
post #18 of 20 Old 11-03-2011, 12:51 PM
Dr.Dirty's Avatar
Yup this is the factory Sirius Add on
http://www.quadratec.com/products/96083_1100.htm
Dr.Dirty is offline
post #19 of 20 Old 11-03-2011, 12:53 PM Thread Starter
it worked, i dont know.....
post #20 of 20 Old 11-03-2011, 12:53 PM
dyaudio's Avatar
YUP
dyaudio is offline
