Rock Krawler Trans Pan - Feedback Please - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 10-31-2011, 08:32 AM Thread Starter
ALASHA's Avatar
Who is running one of these?
Long term review?
How much extra fluid does it hold/have you added?
Any issues?
Crawled under the JK this weekend and noticed the trans pan was leaking a little. 30K is coming up so I was thinking of swaping one of these in.
Any feedback is appreciated
ALASHA is offline
post #2 of 4 Old 10-31-2011, 05:53 PM
GKR
I've been running one for the better part of a year at least. Well made and no leaks. I 've bashed it pretty hard a couple of times. Once hard enough to gouge the corner weld a little and remove some powdercoating. Still no leaks. I don't remember how much more I added but I know RockKrawler list the actual amount.
Give it two thumbs up for sure.
GKR is offline
post #3 of 4 Old 10-31-2011, 08:32 PM
Ruskin's Avatar
Running mine for a yr. no drawbacks. I got it because the trans would run dry and stall on extreme angles, hasn't don't it since.
- Ruskin
Ruskin is offline
post #4 of 4 Old 10-31-2011, 09:08 PM
Cbass122's Avatar
No issues with the trans pan. It is stout and well made.
I can tell you is that if you are already running a skid system, such as the RROR in my case, some minor modification may be necessary to the skid system. Also it is a pain to install back by the exhaust. I used some longer bolts per another thread to help it seal up tight with the lube locker. Still no leaks after 12K miles. Don't remember how much more fluid it actually took though?
Cbass122 is offline
