stupid effin' gascap light!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 10-26-2011, 08:38 PM Thread Starter
Lt. Dan's Avatar
So rock crawling a couple weeks ago, I ripped off the EVAP cannister... Of course, the "gascap" light came on.. Well, new cannister, valve on the cannister, and seal.... Light still on... New gascap... light still on.... Where do I check next?
Where the cool kids in VA hang out!!
Military? Got a Jeep?
Lt. Dan is offline
post #2 of 8 Old 10-26-2011, 08:51 PM
snowbilt's Avatar
Have you cleared the codes?
snowbilt is offline
post #3 of 8 Old 10-26-2011, 09:12 PM
jacktuttle's Avatar
Lightbulb codes
If you do not have a obdII code reader to reset the code then disconnect the negative battery terminal for a couple of minutes. Often times that will reset the codes too.
jacktuttle is offline
post #4 of 8 Old 10-26-2011, 09:23 PM
scrogg's Avatar
I had a similar issue, broke it up pretty good and had it replaced. And the light kept coming on after the new one was installed. It turned out I was missing the o-ring on the littler part that plugs into the canister.
scrogg is offline
post #5 of 8 Old 10-26-2011, 09:48 PM
Check your hoses going into the canister, if any of them are kinked it'll cause the light to come on.
HOT_DAMN is offline
post #6 of 8 Old 10-30-2011, 04:58 PM Thread Starter
Lt. Dan's Avatar
took some time with it today... took apart the lines, cleaned and checked as best I could for leaks... then on all the press fittings I used hose clamps for extra insurance... Re-set the light.. Hopefully that will fix it...
Lt. Dan is offline
post #7 of 8 Old 10-31-2011, 08:14 AM
LILWB's Avatar
I've had a similar problem. Make sure you have the green o-ring between the canister and the white valve thing.
I installed the o-ring and used rvt along with hose clamps to make sure it was all tight and still got the gas cap light.
One thing that has helped so far, believe it or not, I replaced the PCV valve with a NAPA part. This was supposed to help with oil blowing by the rings but my gas cap and general "evap system failure" codes have stopped.
2008 JKUR- 3 Inch Synergy Stage III Lift, PR44, 1310 Shafts, RROR Skids, 37" MTR's, Warn 9.5Ti, Bumpers, Sliders, OBA, Lights... bla bla bla
LILWB is offline
post #8 of 8 Old 11-16-2011, 08:57 PM
SANDBLAST XTREME's Avatar
FYI - my original locking gas cap broke and I replace it with an Autozone cap. Gas light kept coming on, finally went to the stealership and purchased a $25 non-locking cap...problem solved!
2007 Rubicon JKU - Sandstone
SANDBLAST XTREME is offline
