Error Code...Need Help... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-25-2011, 07:40 PM Thread Starter
Tank29's Avatar
Check engine light came on on my way home from work tonight...I had 2 error codes...
P0455 Large EVAP Leak
C107D ??????
I need to find out what this code is (C107D)...Any help would be greatly appreciate it!!!!
2007 JK Unlimited "X"
TF 3" Kit w/4 Arm Flex Kit, TF HD F & R Adj. Track Bars, TF HD Steering Stabilizer, Yukon 5.13 gears, CenterForce II Clutch, Black Rock Soft 8's 16x8, Cooper Discoverer STT 315/75/16, RR XHD Front w/Stinger, SB XRC Rear w/Carrier, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fenders, SB XRC8 Winch
Tank29 is offline
post #2 of 5 Old 10-25-2011, 07:49 PM
MoTech's Avatar
P0455 Be sure your gas cap is on tight, check EVAP hoses and be sure your EVAP canister has not fallen off.
C107D Brake pedal switch 1/2 correlation. Different modules monitor high and low brake switch data, do the brake lights and cruise work?
MoTech
725-502-8507
MoTech is offline
post #3 of 5 Old 10-25-2011, 07:54 PM
TheBlackSheep's Avatar
I'm looking up that code...ah, here it is: "Danger Will Robinson, Danger!"
O||||O
TheBlackSheep is offline
post #4 of 5 Old 10-26-2011, 11:38 AM Thread Starter
Tank29's Avatar
Bot sure why I got these codes...Everything is working...I cleared the codes and drove almost 140 miles today and no error codes so I'm not sure?????
Tank29 is offline
post #5 of 5 Old 10-26-2011, 11:39 AM Thread Starter
Tank29's Avatar
LMAO...Funny!!!
Tank29 is offline
