Arms ARMS A R M S!!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 10-25-2011, 07:34 PM Thread Starter
mgoony's Avatar
Stock arms, short arms, long arms.
I never ever thought about arms before. What's the benefit? Drawbacks? Do you really need to change the arms?
2011 Jeep Green JKUR
Cincinnati JKOs join our Facebook group
CJKC
Cincy JK Crew - rides only, no BS
mgoony is offline
post #2 of 9 Old 10-25-2011, 07:59 PM
curbsjeep's Avatar
Depends on what you want your end result to be. How will you be using or wheeling? Adjustable arms help to re adjust axle orientation after lifting and can help with flexibility. Long arms again, longer radius to swing, better / easier flex.
Message spread by Paul Revere
Mango Tango Unlimited Mountain
curbsjeep is offline
post #3 of 9 Old 10-25-2011, 08:05 PM
Joneszj's Avatar
JKs are unlike a lot of past jeeps where you needed to long arm them to get a lot of flex. I have the full set of teraflex adjustable control arms and although i wont be setting an RTI record, it flexes great for my uses.
Control arms are an expensive upgrade and I would say you are generally ok to run any lift up to 2.5, maybe 3 inches without having to upgrade the arms. The main issue when you lift the jeep and keep the stock arms is that it may feel a bit flighty. Adjustable short arms help to solve the issue as well as get your pinion angle correct to alleviate driveline vibrations or other related issues. Long arms on the JK will provide a bit more flex and will certainly make the ride more stable as well. Some of the newer kits for the JK have long arms tied in from new cross members which also help to strengthen some of the notoriously weak spots underneath.
There's a lot out there about control arms, but I hope this puts it into real-world terms for you...
1972 Commando on Tons & 40s
Joneszj is offline
post #4 of 9 Old 10-25-2011, 11:32 PM
nlgrav182's Avatar
To add to what's been said, axles like to move in a perfectly vertical motion. Stock height lets that come close to happening. Lifts without arms take away from that and decrease ride quality. Long arms bring the near perfect vertical motion back.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #5 of 9 Old 10-25-2011, 11:45 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Yep, the taller you go on stock arms, the less comfort you have in your ride quality because the arm stops pivoting over changes in terrain and instead try to jam into the arm bracket. Long arm changes the pivot point to restore that quality.
JKCTAZ is offline
post #6 of 9 Old 10-25-2011, 11:53 PM
Stock arms = weak, non adjustable
Short Arms = stronger, adjustable
Long Arms = stronger, adjustable, change of suspension geometry
Miraz is offline
post #7 of 9 Old 10-26-2011, 04:34 AM Thread Starter
mgoony's Avatar
now go into cost and modification needed. long arms neem new mounts welded on and the stock ones cut off right?
sent from my Samsung using tapatalk
CJKC
mgoony is offline
post #8 of 9 Old 10-26-2011, 07:32 AM
curbsjeep's Avatar
You have the general idea.
post #9 of 9 Old 10-26-2011, 08:53 AM
2k2wranglerx's Avatar
if you need to adjust your castor or your wheelbase then yes.
long arms ride better but sacrifice ground clearance (although with some of the kits not by much).
Short arms are stronger (assuming they're aftermarket) but most give you a flex joint in one end and adjustability for setting castor.
the stock arms are fine for mild wheeling as long as your castor isn't too far off.
2k2wranglerx is offline
