Bolt Size & Thread???? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 10-23-2011, 11:29 PM Thread Starter
Tank29's Avatar
Had a diff cover bolt break and need to know what size they are and the thread too...I have to try and drill out the rest of the bolt or maybe an EZ-Out will get it out...Thanks!
2007 JK Unlimited "X"
TF 3" Kit w/4 Arm Flex Kit, TF HD F & R Adj. Track Bars, TF HD Steering Stabilizer, Yukon 5.13 gears, CenterForce II Clutch, Black Rock Soft 8's 16x8, Cooper Discoverer STT 315/75/16, RR XHD Front w/Stinger, SB XRC Rear w/Carrier, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fenders, SB XRC8 Winch
Tank29 is offline
post #2 of 4 Old 10-23-2011, 11:36 PM
jrider's Avatar
5/16x18. Reverse drill bits work great.
2007 Rubi Unlimited. Teraflex 2.5 lift + Fox shocks, Nitto Trail Grappler 35s on XD Addicts, 5.38s, Ten Factory rear shafts, Riddler diff covers, Purejeep front axle truss and Teraflex gussets, Tatton front driveline, Rugged Ridge Modular front bumper with XRC8 Comp winch, Superchips programmer, Volant intake, MBRP exhaust, Hella H4 headlight conversion, Body Armor "not so Extreme" Rock Rails, in-cab winch control,Best Top Trek Top.-Sold
jrider is offline
post #3 of 4 Old 10-23-2011, 11:37 PM
JCKnauer22's Avatar
Send a message via AIM to JCKnauer22
go for the ez-out. it should come out fairly easy since there is no longer any tension on the threads, meaning much less friction. in fact, you may be able to use a nail or a center punch to spin it out far enough to get some pliers or fingers on. good luck!
I met a wild-eyed spinster on the back of a bus
She asked if there was any part of her I'd like to touch
When I told her "Yer nuts!" she got mad at me
And lectured on female anatomy...
JCKnauer22 is offline
post #4 of 4 Old 10-25-2011, 08:34 AM Thread Starter
Tank29's Avatar
Thumbs up
Thank you both for the info...The next time I change my diff oil I will try to get the broken bolt out and hopefully I will not damage the threads...Right now it is not leaking so we will see...Thanks again!
Tank29 is offline
