Benchmark Designs oil pan OR RROR oil pan/tranny skid? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 27 Old 10-23-2011, 05:09 PM Thread Starter
rdlynch2's Avatar
Which one you guys think would be the better option? I mean the RROR one protect the oil pan and transmission, but how necessary is it to cover your transmission anyways? I have never personally heard of anyone damaging their transmission on anything, I may be completely misinformed, but I wanted to get some opinions.....Plus the RROR adds a lot more weight/loss of clearance.
What do you think? Is the RROR a better route? Or will replacing the oil pan with a heavy duty one offer sufficient protection?
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #2 of 27 Old 10-24-2011, 04:16 PM
Rancho Suspension's Avatar
Another one to consider is ours. Most people will only run one skid and that is for the oil pan. Check around, yes it is held on by an adhesive, but it works!
Check around.
http://www.gorancho.com/jkrockgear/oilpan.php
Rancho Suspension is offline
post #3 of 27 Old 10-24-2011, 04:18 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
I like the benchmark pan....
combined with the RK tranny pan
Dr.Dirty is offline
post #4 of 27 Old 10-24-2011, 04:24 PM
Check around.
No Offense, tougher than it looks, but I have seen several fail. Most of them fell off after taking the impact (they did their job), others just crumpled up taking the oil pan with them.
Ding ding ding we have a weiner....err....winner!
09rubicon is offline
post #5 of 27 Old 10-24-2011, 04:28 PM Thread Starter
rdlynch2's Avatar
So you guys dont think its necessary to protect your transmission? Has anyone here actually heard of anyone seriously damaging their transmission offroad?i sure havent.....
rdlynch2 is offline
post #6 of 27 Old 10-24-2011, 04:29 PM Thread Starter
rdlynch2's Avatar
So you know of someone who has ripped off their oil pan?
rdlynch2 is offline
post #7 of 27 Old 10-24-2011, 04:30 PM
Dr.Dirty's Avatar
I havent ran an engine or tranny skid in years becaus ethey wont work with my lift.... My oil pan took lots of abuse before failing and my tranny pan is hammer dogshit..... skids are a great idea and the smoother you keep the belly of the jeep the easier it will slide over obstacles...
Dr.Dirty is offline
post #8 of 27 Old 10-24-2011, 04:30 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
If it can be protected, I'd protect it. Especially if you're going to be bouncing around in a lot of rock garden type scenarios.
Marcus
RiverCityOffroad is offline
post #9 of 27 Old 10-24-2011, 04:31 PM
I truly haven't heard of one falling off if installed properly nor of one crumbling either. Not saying you are wrong or you didn't see this. But I know many running these and they have done what they are supposed to. Simple install, simple insurance. ( I hope this doesn't sound jerky, I haven't heard of any crumbling up, I have heard of people not giving it time to cure and falling off though.)
If Mel from ORE says for the 07-11 JK you only need one skid and that is for the oil pan, I believe him.
post #10 of 27 Old 10-24-2011, 04:45 PM Thread Starter
rdlynch2's Avatar
Im just trying to figure out if the rror skid is overkill or not considering the fact that the oil pan is what really needs protection the most. Anyone who has/had heard of/or seen anyone tear up their transmission our wheeling, please chime in.
rdlynch2 is offline
post #11 of 27 Old 10-24-2011, 04:50 PM
I just did a full M.O.R.E. engine skid. covers oil and trans.
UncleB is offline
post #12 of 27 Old 10-24-2011, 04:56 PM
toymaster's Avatar
My personal choice is a skid; RiverRaider in aluminum to be exact. The heavy oil pan is not a bad idea at all, I just do not like the idea of transferring the shock from a hit to the oil pan mounting bolts and engine block.
As far as protecting the transmission pan a rock or tree branch can jump up from any where. I have a manual so I'm not worried about hitting the trans the extra protection of the RR skid is just a bonus.
JK 2dr rubi
toymaster is offline
post #13 of 27 Old 10-24-2011, 05:18 PM
Bubblegoose1's Avatar
Yup. Nice setup.
Bubblegoose1 is offline
post #14 of 27 Old 10-24-2011, 05:24 PM
enigmaverse's Avatar
My only issue with the RROR skid set up is the cross pipe for the exhaust rub... even after bending the closest pins. I need to flatten part of the exhaust pipe for clearance. I like the benchmark pan, but I chose the RROR simply because I didnt want the pan itself to be taking the hit... or to be getting pushed on
Joe -
enigmaverse is offline
post #15 of 27 Old 10-24-2011, 05:31 PM
fftri's Avatar
I have RROR steel oil/tranny and transfer case skids.
The oil pan has a few minor rock scratches. THe tranny skid has more than paid for itself! It has protected my tranny when sliding off rocks on wet trails.
I do not have any recent pictures but these skids take a beating and do their job.
I must be honest and relay my one complaint. I have the first generation and since I purchased mine the oil pan and tranny skids mate up differently.
Rubber bushings are supplied to use when attaching the oil and tranny skid to isolate engine vibes. Due to the oil pan skid being directly attached to the motor, vibes get transfered through the skids to the cross member. For me this seems to be btw 1500 and 2000 rpms. It is not alot of vibe but enough to be annoying to me. THe bushings do not like road salt/etc and do not last through a winter. I do not fault RROR at all for this, just it is what it is. Road salt sucks. Speaking with Kenny, and directions, say not to tighten the three bolts too tight that connect the oil pan/tranny skids. I found the happy medium for a bit and then the salt ate the bushings.....
08 Unlimited born 1/08
Flame Red, Dual Tops
3.5" Clayton Lift
35" Cooper Discovery STs Cragar Soft 8s
5:38s, ARBs F/R, RCVs 35 spline front axle,
Nitto rear 35 spline axle
ProRock 44
Shrokworks sliders
Clayton Offroad skids/crossmember
Tom Woods F/R driveshafts
Mr Fister Fab Front Bumper
VIAR OBA
fftri is offline
post #16 of 27 Old 10-24-2011, 05:50 PM
e-jeep's Avatar
Feedback: 12 reviews
This is all great, but try to get Benchmark to answer any form of communication. I would love to pick-up a BD oil pan, and have tried to e-mail and call them repeatedly to no avail. I am beginning to think the company does not exist anymore.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #17 of 27 Old 10-24-2011, 05:58 PM
Mall Krawler's Avatar
I too am looking at the RROR skids the RK will protect and looks like a good option but the RROR will protect and give a smooth belly to slide on and protect. The last thing you want on the trail is to lose your trans or oil fluid and have to be towed out.
Sent by signal flare
Mall Krawler is offline
post #18 of 27 Old 10-24-2011, 06:00 PM
BumpInTheRoad's Avatar
If you are bouncing off rocks you want to replace the weak OEM trans and transfer case skids AND the cross-member, as well as add an oil pan skid. I'd even recommend replacing the OEM gas tank skid.
I use my skids a lot. I have the River Raider full package plus a Poison Spyder cross member. The only complaint I have is the rear of the transfer-case skid needs some extra support; I added a bracket.
Mine are scratched, dented and malformed after 18 months worth of hard abuse. The heads of many of the bolts were ground down and needed to be cut off with a torch. Imagine what my transmission and transfer case would look like without them. A little work with a press and a BFH, some new paint and mounting hardware, and I'm ready for another year wheeling.
I'm a JKO Reject
BumpInTheRoad is offline
post #19 of 27 Old 10-24-2011, 06:05 PM
red_man22's Avatar
Im with him I tryed for weeks to get ahold of him. I finally Found one used to replace the oil pan I crushed.
The stock pan was still holding oil and I did not hit the pickup tube but it would only hold about 5 qts not the original 6. As for the tranny pan I have crushed that too. right under that is the tranny filter and when that cracks it sucks air and it makes you dead on the trail not moving. Been there done that. got towed home.
My .02 get a full belly pan skid plate and not just one or the other. I have personally crushed both and replaced both
Build it! Run it! Break it! Repeat!
red_man22 is offline
post #20 of 27 Old 10-24-2011, 06:52 PM Thread Starter
rdlynch2's Avatar
I have a manual as well, is there really no concern for hitting the transmission? Im just curious as to why, because it sits so high?
rdlynch2 is offline
post #21 of 27 Old 11-01-2011, 09:11 PM
toymaster's Avatar
Sorry just noticed the question. An automatic has an fluid pan that if pierced will stop you on the trail. The pan is just as thin as the oil pan. On the other hand, the manual does not have a pan and the case is a lot thicker and tougher than the auto's pan.
The reason for a skid on a manual is to have a flat bottom so rocks or other items can slide upon.
JK 2dr rubi
post #22 of 27 Old 11-01-2011, 09:24 PM
nc_fjizzle's Avatar
I'm going with the same setup as Dr. Dirty after Christmas...Dirty's my role model.
ΣX
Order from River City Offroad
nc_fjizzle is offline
post #23 of 27 Old 11-02-2011, 07:21 AM Thread Starter
rdlynch2's Avatar
Yeah im convinced there is no need to armor your transmission if you have a manual. Plus the weight saving with the benchmark, its a no brainer. I hopeI do not regreat not going with a full skid. I figure for now an evap skid, rocker guards, the stock skids and the benchmark will provide enough protection.
rdlynch2 is offline
post #24 of 27 Old 11-02-2011, 07:24 AM
Dr.Dirty's Avatar
So after your rant the other day you still chose to go with BMD?
Agreed, there is no justification for that at all. Regardless of how good their products are, or how "nice of a guy John is" I hope he reads this thread and gets it together,......or at least responds to a fucking email or phone call every once in a blue moon. No, actually I would prefer another company to step up and make another heavy duty oil pan so we can all forget about Benchmark as a company.
Dr.Dirty is offline
post #25 of 27 Old 11-02-2011, 09:12 AM
Ripped off their oil-pan no...ripped off their glue on oil-pan skid, yes.
Crumpled their stock oil pan...yes, I did! That is why I ended up with the benchmark on my last JK. For the cost of a stock replacement pan and a skid it just made sense. Then after abusing the benchmark pan and being forced to use it as a jacking point to lift the front end (it is plenty strong enough!) I am sold.
To clarify for all: I was not knocking Rancho (at least not intentionaly), I have seen their skid hold up to some brutal hits. The catastrophic failure I witnessed was the fault of the driver. Bad line, bad spotting and way to much throttle. The skid did crumple as well as the oil pan. The other half a dozen or so "failures" that I have seen were simply the skid coming off at an inopertune time, usually after having done its job and taking several hard hits. Maybe it was a bad install, prep etc. My point being a bolt on item will come unglued a lot less than a glue on item.
Rancho: For as simple a design as it is, why haven't you guys made a full replacement pan, especially for those that have already damaged their pan eliminating the ability to use your skid??
