Axle/hub help please! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 10-20-2011, 08:40 PM Thread Starter
jrider's Avatar
I'm trying to get a front axle out of the hub on a 44 but it's frozen up pretty good. I pulled the axle and hub out together and soaked it with WD40 then started hitting it with decent sized bronze hammer but it doesn't want to let go. Any tricks?
2007 Rubi Unlimited. Teraflex 2.5 lift + Fox shocks, Nitto Trail Grappler 35s on XD Addicts, 5.38s, Ten Factory rear shafts, Riddler diff covers, Purejeep front axle truss and Teraflex gussets, Tatton front driveline, Rugged Ridge Modular front bumper with XRC8 Comp winch, Superchips programmer, Volant intake, MBRP exhaust, Hella H4 headlight conversion, Body Armor "not so Extreme" Rock Rails, in-cab winch control,Best Top Trek Top.-Sold
jrider is offline
post #2 of 18 Old 10-20-2011, 08:45 PM
Good size air hammer.
post #3 of 18 Old 10-20-2011, 08:58 PM
ronjenx's Avatar
Put it on a press.
ronjenx is offline
post #4 of 18 Old 10-20-2011, 09:00 PM Thread Starter
jrider's Avatar
Air hammer not budging it, have sledge an hit it a couple times pretty good but don't want to ruin threads. No press available right now.
jrider is offline
post #5 of 18 Old 10-20-2011, 09:02 PM
Broncojohn's Avatar
Remove the nut......
Sorry, large vise and a BFH.
Sent from my little magic box.
Broncojohn is offline
post #6 of 18 Old 10-20-2011, 09:06 PM
Little baby-girly air hammer?
Or a "big dog"?
I understand you may not have a SnapOn gun sitting around, but they'll move just about anything that used to move.
post #7 of 18 Old 10-20-2011, 09:39 PM Thread Starter
jrider's Avatar
...girly.
I guess I'll be running one axle to pick the kids up from school for a few days until I figure what to do about my front diff. Planned on replacing the seals anyway. On the bright side, I'll get better fuel mileage!
jrider is offline
post #8 of 18 Old 10-20-2011, 09:42 PM
woomdawg's Avatar
Or a "big dog"?
Put away your baby sister air hammers and get the big brother
http://www.amazon.com/Chicago-Pneuma...ion/B000NP2R26
But really a press sounds like the best answer with out damaging the end of the stub.
2007 unlimited X
rough country 4" lift
18" KMC Rockstars
superchips flashpaq
1 ton Offset TRE's with 1.5" X .25" wall DOM tubing Tie Rod
1.5" X .25" wall DOM tubing Draglink with 7/8" hiem's
Adam's Front Driveshaft
woomdawg is offline
post #9 of 18 Old 10-21-2011, 03:53 PM
Rancho Suspension's Avatar
...girly.
You put the unit bearing/stub back in, I am guessing?
Rancho Suspension is offline
post #10 of 18 Old 10-21-2011, 05:32 PM
tkob1060's Avatar
soak it with PB blaster for a good 30 minutes or even over night then again for 30minutes. I got mine out that way after trying for 2 hours to get it out. WD40 sucks for rust and freeing parts
tkob1060 is offline
post #11 of 18 Old 10-21-2011, 06:37 PM
As others said, without a doubt, an air hammer with a small point chisel at the end. Stick it right at the "port" that the end of the stub has and hammer away. A few seconds later, it'll be out.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #12 of 18 Old 10-21-2011, 06:55 PM
BeerMonkeY's Avatar
make sure you plug up the axle tube or your gonna have gear oil coming out when you drive.
i got nothing for getting the bearing off, mine fell right off when i had it apart.
'92 YJ
'13 WK2
BeerMonkeY is offline
post #13 of 18 Old 10-21-2011, 08:09 PM
Broncojohn's Avatar
How about...find some PVC that will fit over the yoke end and seat against the back of the unit bearing. Then turn it upside-down against the frame and jack against the stud. Just some food for thought.
post #14 of 18 Old 10-21-2011, 08:13 PM
e-jeep's Avatar
Feedback: 12 reviews
Det Cord
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #15 of 18 Old 10-21-2011, 08:28 PM
toymaster's Avatar
The best way is a press. I know you said there is not one available. I would invest in a cheap one. I got a 20 ton a decade ago from one of those mobile tool sales. I have used it countless times. The last time was when I replaced my front axles.
http://www.harborfreight.com/12-ton-...ess-33497.html
http://www.harborfreight.com/20-ton-...ess-32879.html
A hammer will work but many times you wind up causing damage that could have been avoided. If you get one you will use it a lot more than you think and will wonder how you ever lived without one.
JK 2dr rubi
toymaster is offline
post #16 of 18 Old 10-21-2011, 08:29 PM
Originally Posted by e-jeep View Post
Det Cord
I like this option
HOT_DAMN is offline
post #17 of 18 Old 10-21-2011, 08:43 PM
Broncojohn's Avatar
More food:
If can't find PVC and you have a good flat surface to jack against. Pick up a small roll of steel flashing in the roofing section; Let it expand until it is as big as you need then tape it to keep it from unwinding.
post #18 of 18 Old 10-21-2011, 10:11 PM
As to previous findings a stub is not required on JK front hubs. 2wd JKs utilize the same bearings and no stub or the like.
