Jeep Trailer Advice Wanted. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 41 Old 10-20-2011, 10:31 AM Thread Starter
TheBlackSheep's Avatar
Howdy,
I'm looking for a trailer to haul the occasional landscaping stuff (mulch bags, small trees, bushes) and my gear when I go camping. I'd like it to be a military or military-looking trailer. I can also restore vehicles so the condition isn't much of an issue. I want to do it in flat-black or something. Anyway...
My problem is, the ones I'm finding way anywhere from 1200-2700lbs empty. This is way too much weight for my 2dr to haul on long trips. Are there lighter military trailers? I see one called a Bantum TC3 that looks like it may be lighter.
M332 trailer @ 2700lbs empty!
M101A1 trailer @ 1200 empty!
Bantum TC3 @ ?
What I'm looking for is some trailer advice/models/tips.
-Sheep
also...
O||||O
TheBlackSheep is offline
post #2 of 41 Old 10-20-2011, 10:33 AM
2k2wranglerx's Avatar
Originally Posted by TheBlackSheep View Post
Howdy,
Bantum TC3 @ ?
-Sheep
also...
i had the same issue when looking for one. In the end i just bought a TSC 5x7 and did a SOA and bigger tires/wheels. then added some sides from plywood and stakes to hold what i was hauling.
it only weighed a few hundred lbs... Then again, it wasn't rated for that much either.
2k2wranglerx is offline
post #3 of 41 Old 10-20-2011, 10:41 AM
Bubblegoose1's Avatar
I believe both the Bantams and M416s weight about 800 lbs empty.
I was lucky to find a David Bradley trailer; which only weighs 450 lbs empty but is very heavy duty. Maybe try to locate one.
Bubblegoose1 is offline
post #4 of 41 Old 10-20-2011, 10:45 AM Thread Starter
800 is still a monster. I may have to go with the TSCO trailer and just make it look sweet somehow and not like a lawnmower carrier.
O||||O
post #5 of 41 Old 10-20-2011, 11:09 AM
oz97tj's Avatar
I have a M416 and you hardly notice it back there even behind my 2 dr. Or kust buils your oen trailer to your own specs. When i built my teardrop, the frame was all 2x2 tube with a 2.5 inch backbone that ran from front to back with eecievers at both ends, 3500 lb torsion axle and 32 inch tires that weighed 480 lbs. It didnt have a deck or sides though so add nother couple hundred for that.
Support the sport. GLFWDA.org
oz97tj is offline
post #6 of 41 Old 10-20-2011, 02:48 PM
Loki646's Avatar
A loaded M416 is definitely noticeable with the stock V6, not unbearable just noticeable. I'm working on a new design to be built off a used EZ-Loader boat trailer with an empty weight of 350#s.
Loki646 is offline
post #7 of 41 Old 10-20-2011, 07:18 PM
venom's Avatar
Pretty sure the M416 empty weight is ~500 lbs
I dont even notice it back there unless its loaded.
Originally Posted by My Wife
venom is offline
post #8 of 41 Old 10-20-2011, 07:30 PM Thread Starter
awesome - looks like what i want is a 1/4 ton military trailer like the m416. now to find one...
can anyone identify this?
O||||O
post #9 of 41 Old 10-20-2011, 07:38 PM
frenchlayer's Avatar
Looks like an m101 or 105
Dirty Minion for life™.:the finger:
frenchlayer is offline
post #10 of 41 Old 10-20-2011, 07:47 PM
oz97tj's Avatar
It is a 101 or 105. Much larger and heavier than a 416. Even loaded for a week of wheeling and camping, it pulls easy. Unless you're hauling gold bricks around, you'll be find with one. The issue will be finding one and then paying the large sum of money that they command. It's pretty common to see them in the 7 to 800 range in semi rough condition. For that amount of money, you could build a badass trailer to fit your needs exactly.
For reference, the trailer I mentioned earlier I only had about $400 into it. Again, it didn't have a deck or sides so add a little more coin for that but then you have a brand new no rust built to your specs trailer. You could probably save some money and weight by changing up materials here and there too.
oz97tj is offline
post #11 of 41 Old 10-20-2011, 07:59 PM Thread Starter
youre saying the 101 @ 1340lbs empty will pull easily?
O||||O
post #12 of 41 Old 10-20-2011, 08:12 PM
oz97tj's Avatar
Sorry, but no. I meant my 416 loaded pulls easily. That's what happens when you try to type a reply and are talking with someone at the same time. You leave a sentence or two out. lol
oz97tj is offline
post #13 of 41 Old 10-20-2011, 08:36 PM
Fklein6768's Avatar
Jersey is a little too far of a road trip for u but there was a bradley trailer not too long ago in fs section.
Sent from the bat phone!
www.4x4s-pod.com
Fklein6768 is offline
post #14 of 41 Old 10-20-2011, 09:00 PM
Check out this build thread...if it goes as planned you should be able to build a sweet trailer for under a grand. This guys fab skills are out of this world.
http://www.expeditionportal.com/foru...ub-trailer-kit
Espo78 is offline
post #15 of 41 Old 10-21-2011, 12:50 AM
Settle's Avatar
Saw this out there.....had it advertised at $750 but he wants offers
http://columbus.craigslist.org/atq/2603779446.html
2008 Unlimited Rubicon
3" BDS Lift
40" Nitto Mud Grapplers
DIY Beadlocks
Lots of things to come
Settle is offline
post #16 of 41 Old 10-21-2011, 02:24 AM Thread Starter
ya, it was sold when i called. thanks man.
Espo - ya, as long as it comes with leaf springs and a decent stud pattern for some real tires - i can make it work.
O||||O
post #17 of 41 Old 10-21-2011, 07:27 PM
He is basing the design components on the typical harbor freight or northern tool utility trailers, which are leaf sprung and have a Jeep bolt pattern, but not the JK pattern I don't think. You can always build a beefier base trailer to use as well.
Espo78 is offline
post #18 of 41 Old 10-21-2011, 07:39 PM Thread Starter
i saw a little 250lb trailer at lowes for 400$ prob can find one used - bolt pattern doesnt matter to me much as long as it can have real vehicle sized tires.
O||||O
post #19 of 41 Old 10-21-2011, 07:54 PM
M101A2s
badpunkin is offline
post #20 of 41 Old 10-21-2011, 08:01 PM
M416 is what you want. The 101s will be too heavy by the time you get them loaded up. 1/4 ton is a great match for the JK. Mine ways in at 1100 lbs fully loaded with a lid, tanks, and 35's
Vince1 is offline
post #21 of 41 Old 10-22-2011, 01:56 PM
venom's Avatar
Another critter you may potentially encounter in your quest for a jeep trailer is the G518 - also called a Ben-hur because it looks like like a chariot and was made by the Ben-Hur MFG. co.
The G518 is a lot rarer than M101s, M105s and eve M416s.
It's bigger and heavier than a 416, listed as a 1-ton capacity with a 4x8 bed, 18" sides, 20" wheels off of a deuce and a half but it still pulls ok behind my unlimited.
I did take a couple of leaves out of the springs to soften it up some.
I snagged mine in fairly decent shape for $250
great thing about TX - rust isn't usually a problem!
The main problem is the wheels - theyre the old 2 piece split ring wheels - also called widowmakers because if the ring isnt seated just right when you goto air up the tire, it will pop off and potentially decapitate you.
Stockton will make modern wheels for it, just havent had the extra cash to throw at it yet.
I turned mine into a camping deal - military indestructibility, parking brake etc made it a good base to work from.
https://www.jkowners.com/forum/showthread.php?t=25988
venom is offline
post #22 of 41 Old 10-22-2011, 02:21 PM Thread Starter
if i find a good deal on a military 1/4 ton ill scoop it up for sure. but im impatient - so ill probably make my own. i appreciate the enthusiasm so far and good info.
badpunkin - thats a monster man. i like those but they are too heavy for the 2dr x imo. esp w/ the 3.73 gearing. the trailer itself is almost my max towing cap. ALSO - if u see any for sale or on CL up your way give me a shout.
_________----- EDIT----_________
Dude wtf - all of this talk of trailers reminded me of an old trailer frame i never paid any mind to in the back acres of my property in the woods - i just went and checked it out - its pretty f*cking hefty... ill post some pics and see what u guys think it is. it was covered in an old tarp which has pretty much rotted away - it had a wooden floor and rails at some point - it has around 5-7 leafs on each side tho and what look like normal road tires - the metal is only superficially rusted. score!!! i saw it when i was practicing tracking with my dog in the winter last year and forgot all about it.
going to put my old 2dr X springs on it. booya. omg winning!
O||||O
post #23 of 41 Old 10-22-2011, 05:11 PM
I just scored an m116a3 with humv wheels, in excellent shape with the bows and tarp. pics from the ad
Thing tows great, better than my 5x8 enclosed, can't tell it's there unless I stop or go, with the pintle play. Surge brake and parking brakes all work well. It is not any wider than the jk. 800#s empty.
post #24 of 41 Old 10-23-2011, 12:21 AM
toymaster's Avatar
https://www.jkowners.com/forum/showthread.php?t=62086
JK 2dr rubi
toymaster is offline
post #25 of 41 Old 10-23-2011, 02:16 AM
Comfortably Numb
RubiCajun's Avatar
i built an aluminum trailer using on of those big racks that the big rigs use to hang their chains on behind the truck. it's about 4x8 feet. the support in the front for the coupler is made out of 2 " aluminum schedule 40 pipe. the axle is 2' square bar welded to old volkswagen spindles. it has leaf springs and the whole suspension is attached to carbon steel angle iron and bolted through the side of the trailer. I had 4 foot tall sides welded on it and a roof but removed
them to pull my Polaris 4 wheeler. Need pictures PM me. This trailer is super light. picked up the base a semi junk yard for 90 bucks.
RubiCajun is offline
