Oil burning 3.8? Has anyone tried MOPAR CCC? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 10-11-2011, 06:21 PM Thread Starter
I bought a 07 Rubicon Unlimited with 39k about 1.5 years ago. During oil changes I did notice that I would be about a quart down, every 5k. About 8 week ago I noticed increased consumption, about 1 quart every 2k. I started to do some research... noticed lots of complaints about this issue. Obviously a trend with the 3.8 in the JK's (or in general). I tried a new PCV valve... quick easy thing to try... but It didn't seem to help my oil consumption issue (I still noticed consumption after 500 miles). I kept digging....
I found a thread out there about the issue and one possible fix that I didn't read about in these forums... MOPAR CCC (Combustion Chamber Cleaner). about 9$ at the dealer. I read a few different ways to use it (seems everyone has their own version)... I used 2 cans (two applications, not 2 cans at once).
I don't want to be premature, but after 2000k miles, I have 0 quarts of oil consumption. My gut tells me I will find some oil consumption after 5000k if I let it go that long.....
Either way, the MOPAR CCC seems to have solved my oil consumption issue on my 3.8 so far! After 1500k, I changed my plugs, the stock plugs looked ashy, gray-white. No oil on the plugs, but they did look old (glad I replaced them before the 100k mark).
Lots of you-tube vids of people using the CCC on other vehicles. Someone else should give this a try to see if the results are reproducible.
bmacauto is offline
post #2 of 12 Old 10-11-2011, 06:42 PM
Did you just follow the directions on the can? I'm having some oil consumption issues like yours but no visible leak anywhere.
Sent via Pony Express
JaysJK is offline
post #3 of 12 Old 10-11-2011, 06:48 PM
That sounds good, but I cannot see why it would fix any sort of oil consumption issues. Shouldn't affect the sealing of your rings, it's intention should be to remove carbon from the piston/back of the valves. Unless it somehow treated a potential valve seal problem that was causing consumption.
Hope it works out for the long run, keep us posted.
post #4 of 12 Old 10-11-2011, 06:53 PM Thread Starter
I put the whole can into the throttle body and then let it sit for a few hours. After that, I started it up (had to try a few times) and then reved it up to about 3 and back down again.. over and over... once it heated back up, it blew out some smoke (gray-white).. after it stopped smoking I took it for a drive.
If you do some searching, there are many many ways which people tell you to use it... some even say to change the oil after, and some say to use a 2nd can in the pistons directly..... I went the simple approach 1st.
bmacauto is offline
post #5 of 12 Old 10-11-2011, 08:52 PM Thread Starter
I'll try to find the link... it was something about carbon buildup on the oil channel or oil guide... nothing about seals at all from what I was reading. I know I don't drive my JK all that hard... trying to get better MPG.. I think being so lean on the gas might accumulate carbon buildup. I've been better about putting my foot in the throttle a bit now and then, maybe help keep some of the buildup down. I'll see if I can dig that link up.
bmacauto is offline
post #6 of 12 Old 10-11-2011, 10:02 PM
willypapooh's Avatar
im interested, i did a engine flush with 40,000 miles and added some lucas oil stabilizer and gained some mpg. my jeep is burning about a quart ever 3000 miles
willypapooh is offline
post #7 of 12 Old 10-11-2011, 10:33 PM
NascarRubicon's Avatar
ive seen oil consumption caused by worn valve guides...
"Eat Liquid Gold"
NascarRubicon is offline
post #8 of 12 Old 10-12-2011, 09:16 PM
mikejwil's Avatar
do you have the part # handy? i found 4318001AD after a quick google search... wondering if that's the same thing you used.
http://www.factorymoparparts.com/4318001ad.html
no pic or description other than "Mopar Part 4318001AD COMBUSTION CHAMBER CLEANER".
i believe i'll try this too... it's cheap enough
thanks for the heads up!
CURRENT - ordered 10/26, home 1/142008 JK Unlimited,3.8L,6-spd,limited slip,dual tops,tow pkg,all power
SOLD1999 XJ 4.0L,AX15,NP231,D30HP,C8.25
STOLEN1993 XJ 4.0L,AW4 ,NP231,D30HP,C8.25:::C4X4 THB:GDI 3row:K&N:JKS QD: Dynomax#17340:MagnaflowCat#23221:Surco 45x60
mikejwil is offline
post #9 of 12 Old 10-12-2011, 09:19 PM
austinjeepr's Avatar
I used 5w30 had no oil consumption at 4,000 miles
Next oil change I used 5w20 and at 4,000 miles I was a quart low.
austinjeepr is offline
post #10 of 12 Old 10-12-2011, 09:57 PM
mikejwil's Avatar
FYI... Found a write-up on jeepsunlimited.com:
http://www.jeepsunlimited.com/forums...hamber+Cleaner
...and several other threads referencing the same 4318001xx part number, so must be it
I really need to try this. Been pinging pretty bad on the last 3 fill-ups. Tried different gas station last time, but still pinging. Oil consumption increased recently as well (1 quart low @ 3,700 miles - was only 1/2 quart low @ the previous two 5,500 mile oil changes). Coincidence???
mikejwil is offline
post #11 of 12 Old 10-13-2011, 05:49 AM
Sees like you use it the same way you would Sea Foam and it gives the same results. Blows smoke out for a few minutes then all is well.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #12 of 12 Old 10-13-2011, 06:57 AM Thread Starter
Yep, that's the part number. I saw that write up as well... the one I was trying to find again actually had a service bulletin on the 3.8 and carbon build up (side effect was oil consumption)... I've read a few places that the MOPAR CCC is better than Seafoam... I have had used seafoam on all my 2-cycle boats.
I still can't find that link to the service-tech write up. It was interesting. I also run 5w30.... I wonder if my oil consumption would return if I switched to the OEM 5w20.
bmacauto is offline
