rigid 50" light bar / sPOD hook up question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 10-09-2011, 05:34 PM Thread Starter
have sPOD in. light bar in. I have the light with the POS on driverside and ground on passanger side. I have been looking for how people ran wires and see a few options. I can run POS up through top and out firewall with my sPOD. How and were are people grounding the NEG out of the light? Have not found any instal pics yet. ill keep looking
kidfrompittsburgh is offline
post #2 of 8 Old 10-09-2011, 06:58 PM
curbsjeep's Avatar
What kind of light bar is it? My rigid has both + and - on the drivers side.
Message spread by Paul Revere
Mango Tango Unlimited Mountain
curbsjeep is offline
post #3 of 8 Old 10-09-2011, 07:55 PM Thread Starter
e-series spot/flood. I can run the pos up inside window and through fire wall along side my sPOD wires. but the ground is the wire i want to know were and how people are hooking it up.
post #4 of 8 Old 10-10-2011, 02:07 AM
ibjammin's Avatar
If you have a metal light bar you can ground it to the light bar?
ibjammin is offline
post #5 of 8 Old 10-10-2011, 09:00 AM
07unlimitedx's Avatar
There are lots of grounding studs under the hood, down each side of the engine bay. There are also a few in the footwells both drive and passenger side.
07unlimitedx is offline
post #6 of 8 Old 10-13-2011, 09:50 AM
Got pics of your setup?
Durangoman is offline
post #7 of 8 Old 10-13-2011, 10:31 AM
d'sjk's Avatar
your Rigid bar should have all the wires on the driver side.
I ran mine through the weather seal of the top, down the A-piller, through the firewall, and then into my s-pod
d'sjk is offline
post #8 of 8 Old 10-16-2011, 03:02 PM
MannyLx450's Avatar
Feedback: 17 reviews
Send a message via AIM to MannyLx450
kidfrompittsburgh,
You can run the positive cable directly to the sPOD. (You can turn the light to locate the red cable to the side of the battery on your Jeep) The light will works the same way Then the black one can be plug to any where in the car that has ground (between the windshield and the firewall will be Nice or even between the mount and the windshield screws
What mount for the 50" did you buy ? ? ?
Your Rigid Industries Source
PH: 754-201-58-48
MannyLx450 is offline
