My front right coil came out today. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 10-08-2011, 06:16 PM Thread Starter
rdlynch2's Avatar
So out wheeling today, my front right coil came out. For no apparent reason, I was in no way flexing out to the max, has this happened to any of you?
I have a 2.5 inch Rock Krawler stock mod kit. I Installed it a couple months ago. Im wondering if this is a RK coil thing, or simply a freak occurrence, Im gonna guess and hope for the latter.
Thanks....
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #2 of 12 Old 10-08-2011, 06:27 PM
Sounds like your shocks are too long? How do you know it wasn't fully flexing? What were you doing?
...springs just don't come out by surprise.
post #3 of 12 Old 10-08-2011, 06:32 PM
no coil retainers, too much droop
BBirish is offline
post #4 of 12 Old 10-08-2011, 06:56 PM Thread Starter
rdlynch2's Avatar
Well, the coils did just "come out." Thats is exactly what happened. I was going down a pretty easy trail, at a small incline, nothing serious, was not rock crawling, or like I said fully flexed out, at all. And my shocks are the same size recommended by rock krawler. I got the bilstein 5100's.
rdlynch2 is offline
post #5 of 12 Old 10-08-2011, 06:57 PM
maybe they werent seated correctly?
BBirish is offline
post #6 of 12 Old 10-09-2011, 08:09 AM Thread Starter
rdlynch2's Avatar
what exactly is suspension droop by the way anyways?
rdlynch2 is offline
post #7 of 12 Old 10-09-2011, 08:40 AM
Taco08jk's Avatar
Droop in when you flex the suspension, one wheel goes up into the wheel well and the oppisite wheel "droops" or hangs down. Hence the flexing of the suspension.
RK 3.5 X Factor mid arm
PSC BFH trail stinger
PSC narrow fenders
A lot more to come very soon!
Taco08jk is offline
post #8 of 12 Old 10-09-2011, 08:47 AM
Ogie's Avatar
Or they're gay.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #9 of 12 Old 10-09-2011, 09:40 AM
Likely your spring was not seated correctly from some earlier action and then just popped out under compression on this easy trail.
My driver side is drooped in this picture. Common term for extended when talking about shocks and springs.
4x4x4 is offline
post #10 of 12 Old 10-09-2011, 09:43 AM
Sounds like you fully extended the front end and it came out. They still do not just come out. This is mechanical, not smoke and mirrors where "freak" things occur. The suspension drops out further than the spring is long, so either the suspension needs to be limited (shocks seem to do that) or you need to add coil spring retainers to keep the coil where it needs to be.
post #11 of 12 Old 10-09-2011, 10:02 AM
Boosted's Avatar
As previously mentioned....coil springs wont just fall out. Either the spring was never seated properly (highly unlikely) or you flexed the suspension beyond the length of the springs allowing the spring to "fall" out of the spring bucket.
The best solution to preventing this from happening again is to install the spring retaining clips offered by Rock Krawler for the fronts and hose clamps for the rears. I would not recommend going with a shorter shock as that would severely limit your suspension travel.
Simple fix that will retain the flex and prevent future occurance.
Boosted is offline
post #12 of 12 Old 10-09-2011, 12:08 PM Thread Starter
rdlynch2's Avatar
yeah, im gonna get the retainer clips. there only 20 bucks, obviously in my instance it would be a valued investment. Im surprised that this has not occurred to more people....
rdlynch2 is offline
