I got the Steering Sway??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 10-07-2011, 09:04 AM Thread Starter
azrockzuk's Avatar
So I had some front end sterring sway.... just put in new ball joints...
09 JK tera flew 4inch short arm kit with 37 inch tires 27,000miles
It did not fix it....
My steering stabilizer was toast... so I replaced that as well... It drove better but still have the sway....
I still have the sway= When driving it sways to the left(or right) then I steer to the right but it seems like it takes a few seconds the goes right fast...Almost like the is a tooth or two missing in the sterring box...
Any way I am looking into replacing some of the bushings ect.
So I saw this looks like a spacer? it is on the drivers side lower link..
What do you think?
This is a picture of drivers side then passenger side
Chad
azrockzuk is offline
post #2 of 17 Old 10-07-2011, 09:09 AM
BenDrinken's Avatar
Did you do a drag link flip?
BenDrinken is offline
post #3 of 17 Old 10-07-2011, 09:21 AM Thread Starter
azrockzuk's Avatar
Nope... Should I??
Also how do I tell if I have sheared the sector shaft in my steering gear box?
Chad
post #4 of 17 Old 10-07-2011, 09:25 AM Thread Starter
azrockzuk's Avatar
Looks like a small leak on steeing box.....
Chad
post #5 of 17 Old 10-07-2011, 10:24 AM
Chris Hansen's Avatar
If you went up 4" you need to take a look at the angle of your drag link compared to your track bar. Odds are you need to flip the drag link or get a drop pitman arm (I would suggest the former).
Also, check the toe if you went up to 37s. Could be any combination of things.
Dirty's Minions don't officially exist. They are a myth, a bedtime story, a whispered rumor. They are ghosts.
Chris Hansen is offline
post #6 of 17 Old 10-07-2011, 10:35 AM
Boosted's Avatar
I see the bushing coming apart on the drivers side lower link....
Boosted is offline
post #7 of 17 Old 10-07-2011, 10:42 AM Thread Starter
azrockzuk's Avatar
(I would suggest the former)???
Who makes a good or best drag link flip kit??? I will buy one today!!!!
I will order a new bushing for lower drivers side.... it looks like it need a spacer ??? Its wider on drivers side than passenger What's up with that????
Chad
post #8 of 17 Old 10-07-2011, 10:45 AM
I like Poly's, but most of my stuff is Poly.
You've got a Tera lift....so take a look at their stuff, too.
The former, as opposed to the latter (flip rather than drop pitman).
post #9 of 17 Old 10-07-2011, 10:53 AM Thread Starter
azrockzuk's Avatar
Copy that!!!
Chad
post #10 of 17 Old 10-07-2011, 11:10 AM
Boosted's Avatar
No spacer....looks like the mount is bent. I would "massage" the mount close to where it "should" be and then install the lower link with the new bushing and torque it down.
Boosted is offline
post #11 of 17 Old 10-07-2011, 02:14 PM
oz97tj's Avatar
Hold on with that drag link flip. It could give better geometry if done correctly, but to do correctly will also need the trackbar moved. The drag link and the track bar need to be parallel to each other or you will just be causing more issues.
First thing would be to check your toe. If running a stock tie rod like the photo suggests, then it bends easily. I've been mine without even going offroad with large tires.
Support the sport. GLFWDA.org
oz97tj is offline
post #12 of 17 Old 10-07-2011, 07:42 PM
austinjeepr's Avatar
It's the balljoints, grease them again.
Mine did the same thing, there were very stiff at first.
I asked poly about it but never got a reply.
Does it feel like your steering wheel doesn't recenter itself?
Also your bushing is completely shot and you might check the arm too.
austinjeepr is offline
post #13 of 17 Old 10-07-2011, 08:04 PM
Fishtale's Avatar
You can't steer and your drag link falls to the ground!
2008 Silver 4dr Rubi - 4.5" Rubicon Express Longarm, 37x13.5x17 Toyo M/T's, Dick Cepek DC-1(blk) 17x9, Prorock 44, ARB frt locker, RCV's (frt), Superior Chromoly Axle shafts (rear), Prosteer ball joints, 5.38 Yukon gears, RR Hydro-Assist, etc, etc, etc......
Wheeling Trips:
Fishtale is offline
post #14 of 17 Old 10-11-2011, 11:05 PM Thread Starter
azrockzuk's Avatar
Replacing steering box as well !!! sector shaft is toast....
Chad
post #15 of 17 Old 10-12-2011, 06:58 AM
josh_jacklyn's Avatar
there are many drag link kits that you could go with. on here it seems like the best for the money is poly...
2011 MANGO TANGO sahara jku....bone stock.
r.i.p.08 jk x steel blue
CALL MARCUS.. NUFF' SAID..
josh_jacklyn is offline
post #16 of 17 Old 10-12-2011, 07:04 AM
peanut's Avatar
Looks like you have more than one control arm issue... What is the deal with your upper passenger side? What about the bushing on the driver side? I would start with fixing your current set up before changing anything.
Just my .02
peanut is offline
post #17 of 17 Old 10-13-2011, 12:28 AM Thread Starter
azrockzuk's Avatar
So I borrowed and installed Lazy moose's steering box (he had a new-ish one on the shelf) and I replaced the drivers side lower bushing...also massaged the link mount back to where it should be too...
It drives way better I am still going to replace the upper drivers side heim as well...
To buy a new steering box was pretty $$$ so for the same $$$ I am sending it red neck ram guyz to rebuild my stock steering box I just took off...adding the Hydraulic Assist and then giving Lazy moose his steering box back!!!
Chad
