Axle gusset question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 05-27-2011, 09:23 AM Thread Starter
D5Fire's Avatar
Send a message via Yahoo to D5Fire
]When my jeep got hit last month I ordered a set of Poly's Synergy Suspension C gussets for my Dana 30. Once they have been installed I noticed the coil springs are contacting the gussets. The first pic should be the passenger side at flex, if you look you can notice the rub spot is kinda shiny. The 2nd pic is the driver side stuffed due to the passenger side being flexed. Is anybody else running into this, and is it a problem? The springer are seated properly with the ends being in the channel on the mount. I Pm'd Pig a couple days ago to see what he had to say, but Im still waiting on a response.
Fortis cadere, cedere non potest
Poison Spyder BFH w/ trail stinger, custom rear BFH, crusher flares, rocker knockers, evap skid, hood louver. Rock Krawler 2.5 Max Travel, Teraflex rear tire carrier, River Raider cowl snorkel,Warn VR 10,000 lbs winch, sPod, Rigid 50"SR.
D5Fire is offline
post #2 of 9 Old 05-27-2011, 09:32 AM
Yes I have had my stock coil springs hit my Poly c-gussets since I installed them almost two years ago.
post #3 of 9 Old 05-27-2011, 09:40 AM
racinfast002's Avatar
I'm pretty sure mine are going to hit, but no worries
Justin
2009 Sahara Unlimited-The Saharacon
Just hanging out in the land of the banned
racinfast002 is offline
post #4 of 9 Old 05-27-2011, 10:06 AM
VKS Fab
JK Vick's Avatar
Mine hit too. Its not anything to worry about.
Vick
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #5 of 9 Old 05-27-2011, 10:18 AM Thread Starter
D5Fire's Avatar
ok I didnt notice any difference in the way it drives, I was just curious if it would lead to issues down the road.
D5Fire is offline
post #6 of 9 Old 05-27-2011, 10:25 AM
TrailDuty.com
PhilD's Avatar
Will be just fine and cause no issues.
PhilD is offline
post #7 of 9 Old 05-27-2011, 12:12 PM
Owl
Owl's Avatar
Was planning to do this (and the axle sleeves) soon. Good info.
Thanks.
Owl is offline
post #8 of 9 Old 05-27-2011, 09:32 PM
don't mean to hijack but seems like knowledgeable people in here, does the axle have to come off or apart to have gussets welded on? or could i just drive on down to the welding shop with a jack and jack stand to get the wheel off and have them welder it up?
jpiker is offline
post #9 of 9 Old 05-27-2011, 09:37 PM
You can do it this way but you do need to be mindful of the heat on your balljoints. I used wet rags on my joints and moved to different areas to prevent too much heat on the balljoints. They have plastic sleeves inside them so you just need to take proper precautions. Many of us have done it this way. I have done it twice on different JK's.
4x4x4 is offline
