Lift kit issues - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 05-19-2011, 02:51 PM Thread Starter
wagonguy's Avatar
Lift kit issues
Installed lift on my 07 2 door Wrangler and now have some issues. Steering wheel is off centered as expected but it has some warning lights on and the anti-lock brakes and steering act funny. Lift is a Rough Country 3.5 which include springs,shocks,pitman arm and misc. Will a proper alignment fix these problems? Sorry if I am in the wrong forum.
wagonguy is offline
post #2 of 3 Old 05-19-2011, 03:09 PM
SoK66's Avatar
An alignment is a good idea, but the lights are on because the steering wheel is off center. JK's ESP references off something called the clock spring, which tells the ESP/BAS system when the wheel is on-center. Simple fix, just loosen the 15mm nuts on the drag link adjuster sleeve clamps and turn until the steering wheel is centered. It's got to be reasonably close, so take your time.
SoK66 is offline
post #3 of 3 Old 05-19-2011, 03:19 PM Thread Starter
wagonguy's Avatar
Thanks for the response. I will try that Saturday.
wagonguy is offline
