Jeep won't run..... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 05-12-2011, 03:37 PM Thread Starter
Blackr6's Avatar
Jeep won't run.....
Well the JK was towed in this evening. Been having some weird issues....first off when shifting(it's a 6-speed) I noticed an abrupt loss of power, maybe 200-400 RPM's. Then it kicked right back in.
last night, crank it up turns over and as RPM's drop back to the usual 750-1000 RPM range to idle it would suddenly die. Played with it for 5 minutes it fired up and everything was fine.
This morning it wouldn't roll over....strong crank but wouldn't turn all the way over...
Time to sit an ponder now...have any of you experienced similar problems?
Kyle
[email protected]
Blackr6 is offline
post #2 of 10 Old 05-12-2011, 04:23 PM
Sounds like a PCM issue of some sort, then again it could be anything.
I have not recieved your application to use my last name yet I am afraid I am going to have to up the royalty rate to 10% because of this
09rubicon is offline
post #3 of 10 Old 05-12-2011, 04:33 PM
What do you mean it has a strong crank and wont turn all the way over? Is the engine turning while cranking?
post #4 of 10 Old 05-12-2011, 04:52 PM
Poseidon's Avatar
I was thinking it was one of the sensors.
Poseidon is offline
post #5 of 10 Old 05-12-2011, 06:01 PM Thread Starter
Blackr6's Avatar
Well I'm not mechanically inclined, but it's not just clicking or sluggish it's a strong crank. EDIT: girlfriend hates when I play on the forum at dinner.
Kyle
[email protected]
Blackr6 is offline
post #6 of 10 Old 05-12-2011, 08:18 PM
lohchief's Avatar
What your saying then is the engine turns over but doesn't start,right? What year is it,how many miles on it? If it has a fair amount of miles on it I would say it sounds like the crank position sensor.
lohchief is offline
post #7 of 10 Old 05-12-2011, 08:27 PM Thread Starter
Blackr6's Avatar
10-4. 2010 with 13K miles....will find out in the am I guess....
Kyle
[email protected]
Blackr6 is offline
post #8 of 10 Old 05-12-2011, 08:30 PM
Kyle
[email protected]
Do you not have a warranty?!
post #9 of 10 Old 05-12-2011, 11:49 PM
If you had lots of miles on it I would suspect fule filter. But that's probably not it at 13K.
post #10 of 10 Old 05-13-2011, 10:08 AM Thread Starter
Blackr6's Avatar
So dealer calls and says there's a code for an intermittent key. My keys bad.....sounds screwy.
Kyle
[email protected]
Blackr6 is offline
