Looking for some specific MOAB rims... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 05-12-2011, 12:22 AM Thread Starter
Im trying to find some rims and seem to be running into some walls. A guy at my work has a Liberty that has some really nice looking MOABs on it. I am not sure if they are a smaller diameter than the ones that typically come with a JK but they are deeper. There seems to be a larger offset between the rim and the hub of the wheel. I am not sure how else to explain it. I think they are 15" rims and the JK ones are a 17" if I am not mistaken. Either way I think they would look sweet on a JK with 33's. Anybody have some pics of these rims on a JK or even a site that sells them or a model number for them?
Vertisce is offline
post #2 of 4 Old 05-12-2011, 12:50 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Are you talking about a TJ Moab? They are 16 x 8 with about 4" of back spacing if I'm not mistaken (on the back spacing).
http://www.dragtimes.com/parts/Jeep-...539438149.html
http://www.google.com/search?hl=en&c...w=1406&bih=802
If that's what you're referring to, they are 5 on 4.5" bolt pattern so they won't bolt right up on your Jeep.
However - I can get you these:
http://mambawheels.com/Mamba_Wheel_L...a_Type_MR1.htm
Marcus
RiverCityOffroad is offline
post #3 of 4 Old 05-12-2011, 12:53 AM Thread Starter
Yep...thats them. So they are the wrong bolt pattern. I take it the Mamba ones are the same offset and size but with the 5 on 5 bolt pattern? I also assume I can replace the Mamba center cap with a Jeep one right?
Edit: I read some of the info on the page and pretty much answered my own questions. So I guess I would have to get the 17x8 5.5 with the 4.75 backspacing. There is also an offset I see there with a pretty big difference between the 5 on 4.5 and the 5 on 5 wheels...what is that exactly?
Vertisce is offline
post #4 of 4 Old 05-12-2011, 12:57 AM
The Mamba would have 4.75" of backspace which will work with oversize or stock tires. The bore hole should be exactly the same as your stock wheels so yes, you could use Jeep center caps if you'd like.
I'll be back tomorrow! Shoot me a PM if you've got any more questions so I don't miss it.
Marcus
