What kind of tranny fluid? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 05-11-2011, 07:54 AM Thread Starter
BeerMonkeY's Avatar
ill be putting in a tranny cooler this week and figured id flush the fluid at the same time (52k miles) but i cant find in the owners book what kind of fluid to put in, but im also missing pages of it to. will atf+4 from my old auto tj work?
'92 YJ
'13 WK2
BeerMonkeY is offline
post #2 of 11 Old 05-11-2011, 07:58 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
ATF4 x 5qts you will need more with a cooler
Dr.Dirty is offline
post #3 of 11 Old 05-11-2011, 08:02 AM
SoK66's Avatar
FWIW, when I installed my trans cooler last summer it didn't need any fluid afterwards. I think it may have been over-filled to begin with. There's actually not much fluid in the lines & cooler, and not much will run out when you cut the line.
SoK66 is offline
post #4 of 11 Old 05-11-2011, 08:07 AM Thread Starter
BeerMonkeY's Avatar
im going to flush out the old fluid when i do the cooler install.
'92 YJ
'13 WK2
post #5 of 11 Old 05-11-2011, 08:20 AM
Breaker of nice things
merlin4979's Avatar
On a somewhat related note, if you go to the Amsoil site, it will list every fluid and filter that you'll need for your vehicle.
http://www.amsoil.com/mygarage/Produ...EEP+WRANGLER+1
merlin4979 is offline
post #6 of 11 Old 05-11-2011, 08:22 AM
Dr.Dirty's Avatar
I am running amsoil and the tranny shifts smoother and the temps have droped around 8 deg from normal drving temps
Dr.Dirty is offline
post #7 of 11 Old 05-11-2011, 08:47 AM
TrailDuty.com
PhilD's Avatar
If you just drop the pan and change the filter you'll only need 1-1/2 qts, which is almost not worth doing. If you do the complete system you will need 6 qts.
This is what I do:
https://www.jkowners.com/forum/showthread.php?t=28958
I just run it through until it is coming out clean, which usually uses a few mores qts, but that way I know it is just fresh fluid in the trans.
PhilD is offline
post #8 of 11 Old 05-11-2011, 08:51 AM Thread Starter
BeerMonkeY's Avatar
thats what i planned on doing, used to do it on my old tj that way. think i need to change the filter??? i would just do it but then i need to pull my skids off and i didnt really want to to that right now
'92 YJ
'13 WK2
post #9 of 11 Old 05-11-2011, 08:54 AM
TrailDuty.com
PhilD's Avatar
At 52k miles I'd be tempted to change it, although it is most probably fine. What I did was add an external filter (changed the trans pan filter at the same time), change the external filter annually and just leave the pan filter alone.
PhilD is offline
post #10 of 11 Old 05-11-2011, 09:02 AM
SFCCotton's Avatar
Just burn your shit up and let the dealership put a new tranny in under warranty. They put new fluid in that way too!
SFCCotton is offline
post #11 of 11 Old 05-14-2011, 06:05 PM Thread Starter
BeerMonkeY's Avatar
id love to do that, BUT my warranty ran out about 20k miles ago, and i wouldnt trust my local dealer to install a transmission
'92 YJ
'13 WK2
