Will a 33" tire, 15" wheel with 3 3/4" BS be OK? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 05-06-2011, 08:16 AM Thread Starter
2010 JK, no lift yet, future 2.5" lift. Will 33 x 12.5 x15, wheel with 3 3/4" back spacing be OK with no problems? I sincerely appreciate everyones advice.
THANKS!!!!!!
FORGOT TO MENTION THAT THE WHEELS WILL BE 10" WIDE
askyellowhawk is offline
post #2 of 11 Old 05-06-2011, 08:23 AM
You may have issues with the 15in wheel and the brake caliper.
GrmnCrsNBr is offline
post #3 of 11 Old 05-06-2011, 08:37 AM
rotcyboi's Avatar
It depends on what wheels you run. I run a cragar 15" with 35"s and had to do minor grinding on the brake caliper. But I would do it again in a heartbeat
Sent via smoke signal
Originally Posted by Mall Krawler View Post
Hocus pocus, Abracadabra and Alakazam - prototypical magic words used by magicians and top jeep Suspension Engineers.
rotcyboi is offline
post #4 of 11 Old 05-06-2011, 08:37 AM
BigMike's Avatar
No issues at all. Been running ProComp steelies and 33's for 18 months.
, Granite,
BigMike is offline
post #5 of 11 Old 05-06-2011, 08:39 AM
redneckjk's Avatar
Send a message via Yahoo to redneckjk
some of the after market wheels in a 15" have issues with the brake caliper, some are fine. i am running a 16" 41/2" B.S. steel with 33" toyos and have no issues. before shelling out the dollars, ask your supplier if you can test fit the wheel, front and back. most on here are gonna suggest 41/2" B.S. or more for when you flex the front axle to avoid scrubbing.
try the search function for 15" wheels and backspacing
all of this is depending on whether you are serious off roading or just for looks. either way, the wider the stance, the bigger it looks.
redneckjk is offline
post #6 of 11 Old 05-06-2011, 08:40 AM
BigMike's Avatar
Cragar has 4" BS and requires grinding of the caliper. ProComp has 3.75" BS and does not require any grinding.
, Granite,
BigMike is offline
post #7 of 11 Old 05-06-2011, 09:59 AM
redneckjk's Avatar
how do the pro comps work with the sway bar discoed and the tire stuffed into the fender flair? any rubbing on the sway bar, shock mount, or the upper spring mount? even with the 4.5"BS at full turn with the tire stuffed i sometimes still get scrubbing. that is with 3.5" of lift and extended bump stops. not disagreeing with you, and freely admit all i know about jeeps, i learned at a holiday inn express. one of the reasons i chose the 16" wheels is because of the brake issues and possible scrubbing with the tighter wheel.
post #8 of 11 Old 05-09-2011, 08:02 AM Thread Starter
THANKS FOR ALL THE ADVICE. ONE MORE THING
I FORGOT TO MENTION THAT THE WHEELS WILL BE 15 X 10" WIDE. IS EVERYTHING STILL GOING TO BE OK?
post #9 of 11 Old 05-09-2011, 09:29 AM Thread Starter
Thanks, what width wheel 8" or 10". I was considering going with the 10" wide wheel
post #10 of 11 Old 05-13-2011, 10:03 PM
I like 8" wheels because they are less likely to break a bead. Been running 10 psi on the trails no issues. I've used this combo with 33 and 35 with great success.
4x4x4 is offline
post #11 of 11 Old 05-13-2011, 10:10 PM
nootherride's Avatar
the rule of thumb on 15's unless it's a rubicon is 3.75 bs
nootherride is offline
