My Jeep smells like gear oil... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 05-05-2011, 08:10 PM Thread Starter
saharac's Avatar
My Jeep is smelling like gear oil (Royal Purple 75w90 to be precise....) after my diff fluid change from last week.. and the fumes are giving me a headache...
I had dumped the paper towels in the back of the Jeep from cleaning the spilled diff fluid.. but since then i have cleaned the whole interior, tried air freshners and driven with my windows down...
Now I am starting to wonder if I screwed something up and the diff fluid is spilling into something... I have not felt any change in driving, just wondering how others have taken care of their spilled diff fluid...
saharac is offline
post #2 of 9 Old 05-05-2011, 08:14 PM
StubEXrube's Avatar
Put some dead fish back there for a few days. That'll kill it.
I would remove the carpeting and scrub the hell out of it. Wait until its completely dry......days and days later, before re-installing it. I would also wipe down the interior tub while the carpet is out.
FWIW- Are you sure that the smell isn't coming from an over-filled/ spewing front diff, rather than the paper towels?
StubEXrube is offline
post #3 of 9 Old 05-05-2011, 08:15 PM
x2, check the axle breathers for signs of gear oil.
post #4 of 9 Old 05-05-2011, 08:31 PM Thread Starter
saharac's Avatar
How do i check this?? where is the axle breather located.. i dont see any spill on the outside... how can i check my axle seals??
thanks guys...
saharac is offline
post #5 of 9 Old 05-05-2011, 08:45 PM
StubEXrube's Avatar
thanks guys...
I doubt it's your seals, but with that strong of an odor inside the cab, you would see it pretty obviously by the same smelling liquid all around the end of your axle-shafts or drips on the garage floor.
Axle breather tube is likely still on your axle. Its the tube that comes off the front axle on the drivers side at the differential. Black tube......You'll see it.
Where it's spewing from will be the other end, and there's not much to do about "fixing" it, besides draining some out of the diff to just under fill-hole.
You will see diff-fluid all over the tube and under the Jeep on the frame, control-arms, etc. It will be obvious.
post #6 of 9 Old 05-06-2011, 08:07 AM
mpkelley20's Avatar
I had this issue after I changed my Diff fluid and switched to Riddler covers. I was following directions on how to change diff fluid (directions from "another" forum) and it said use 2 quarts. The driections were for the rear diff but then went on to say, repeat above steps for the front.
Stupid me...I way overfilled the front and did not know. Started getting that rancid smell and thought it was bad exhaust or something. Was very noticeable at a stop and with my vents blowing.
Took it to the dealer and within 2 minutes they started laughing and asked if I changed my own diff fluid recently. It was pouring out of the breather tubes in the front!
Easy enough to fix but now I am very careful about how much I put in.
For the record, it appears that with my covers I can put in about 2 1/4 quarts for the rear and 1 1/4 to 1 1/3 in the front.
Hopefully your issue is just that and not something bigger.
2010 Black Unlimited Rubicon w/NAV
Superior 5.13 gears
2.5" Teraflex coil lift
Bilstein 5100 shocks
JKS front and rear adjustable track bars
LOD Signature series rock sliders
35" Maxxis Bighorn Tires on 16" blackrocks
Terafkex C Gussets and inner sleeves
Rugged Ridge XHD Bumper
Smittybilt XRC10 Comp winch
Rock Hard Evap Skid
Superchips Flashpaq
Smittybilt seat covers (sitting in garage)
Mastercraft Grab Handles
mpkelley20 is offline
post #7 of 9 Old 05-07-2011, 11:27 PM
no return's Avatar
Purple Power or Simple Green will clean it off.
Or you could rub Vomit and Fresh Dog poop on it... At least they smell better than Gear Oil
Not always does the race go to the swift, nor the battle to the strong, but that's the way to bet.
no return is offline
post #8 of 9 Old 05-08-2011, 05:36 PM
tkob1060's Avatar
ok since no one told you were the diff breather tubes are I will. The front runs up the shock tower on the drivers side, you will see a white plastic cap on top. the rear is on the passenger side on top of the frame rail and at base of the inner fender liner. If you over filled the diffs it will stop coming out the breathers once it is low enough.
tkob1060 is offline
post #9 of 9 Old 05-08-2011, 09:07 PM
drew's Avatar
Bellowing
Same thing happened to me last week after I installed Riddlers. When I checked to find the leak, it was coming out the front breather and there were NO breather hoses, front or rear. WTF? Guess I'm gonna have to buy some 5/16"(?) hose or maybe an extension kit. Are any of those kits full replacements or do they just extend the factory hoses? Has anyone used "bellows" instead?
BTW, I used 1.5 quarts front and 2.5 rear on Rubicon Dana 44s. After a couple days the front stopped overflowing.
drew is offline
