Best price on Pro Rock 44?` - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 05-05-2011, 03:35 PM Thread Starter
SONIC's Avatar
Anybody know who has the best price on a pro rock 44?
I need to replace the front axle housing and Insurance is giving me $2433.24 to replace the stock housing.
I figure I should go Pro Rock.
So I need something that is exactly like the stock housing so that the labor on the shops end works out the same and I don't go over my estimate.
Will a Pro Rock do this?
The part I need replaced is 68017174AA
Any advice as well?
-Doc Holiday
SONIC is offline
post #2 of 21 Old 05-05-2011, 03:43 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I'll see what I can do for you.
PM soon.
Marcus
RiverCityOffroad is offline
post #3 of 21 Old 05-05-2011, 04:03 PM Thread Starter
SONIC's Avatar
Heres some questions for you guys
Is there any legal or logical reason why the body shop would refuse to do what I want them to as opposed to doing whats on the estimate exactly?
The money is in my hands, but the estimate is left open to supplement which will be payed directly to the body shop should they go over.
For instance :
For that 2400 bucks I can have a Prorock shipped to them as opposed to them using the stock axle.
And for the rear the estimate says to replace the rear housing, but only the track bar bracket is broken, I'd like to weld on a new bracket and use the remaining money for control arms.
Am I out of line for asking for this stuff?
-Doc Holiday
SONIC is offline
post #4 of 21 Old 05-05-2011, 04:44 PM
Cajun tj's Avatar
I'd go to a different body shop. You'll end up getting what you want and the first body shop can find out what it's like to lose some cash.
Cajun tj is offline
post #5 of 21 Old 05-05-2011, 04:49 PM
No matter what anyone tells you (in terms of the insurance company or body shop) you have the right to refuse anyone doing the work. If you aren't happy with what the final product looks like you can refuse that too.
The insurance company's job is to get your Jeep fixed for the least amount of money possible while keeping you appeased. Don't let them rake you over the coals, but don't get so worked up over it that it consumes your life either.
It's easy to get really really passionate with stuff like this. Just do what makes sense and get the most out of it that you can. There'll be time to fill in the gaps as you go on.
Marcus
post #6 of 21 Old 05-05-2011, 05:37 PM
jeepnick's Avatar
Marcus
Marcus is 100% correct
Personally I'd buy the parts you want, a few cases of beer and have an install party at your garage or a buddy's that has the right tools
jeepnick is offline
post #7 of 21 Old 05-05-2011, 05:45 PM
zjr
zjr's Avatar
And that's what I'm doing next time... Even if it is another engine.
zjr is offline
post #8 of 21 Old 05-05-2011, 06:51 PM
isoyeti's Avatar
I paid $2k delivered for the PR ultimate (1/2" tubes) plus I got the 10 degree additional pinion angle built in (northridge). Not sure what amount of lift you are running but really consider it if you are 4" or greater. Really helps with the DS angle, while keeping the castor near factory specs. You will also want to look at the poly bracket to relocate the track bar, if you are running alot of lift. Be sure to consider the Reid knuckles while you have it apart and maybe the currie steering parts, if there is any $$ left.
'08 Rubi Unlimited - a few mods. (sold)
isoyeti is offline
post #9 of 21 Old 05-05-2011, 07:02 PM
Slippery's Avatar
Maybe I'm missing something, but...
You only need a housing, right? And you want to move up...
But if you change to a Pro Rock 44, from a D30 or a Rubi 44, you'll need more than a housing...
(Sorry, you might have a Rubi but can't tell in the photo and your profile is blank)
You'll need everything that goes in it, depending on what you have now.
For a D30, you'll need..
44 R&P
44 carrier
44 axles
44 Outers..
44 Cover
Slippery is offline
post #10 of 21 Old 05-05-2011, 07:03 PM
jeepnick's Avatar
You only need a housing, right? And you want to change the type...
But if you change to a Pro Rock, you need much more than a housing...
So if you have a D30.... or a Rubi 44, you need a lot more
44 R&P
44 carrier
44 axles
44 Outers..
44 Cover
so you're going to need to spend a lot moire than the cost of a housing.
He has a rubi already
jeepnick is offline
post #11 of 21 Old 05-05-2011, 07:38 PM
D5Fire's Avatar
Send a message via Yahoo to D5Fire
when I got my initial estimate I went through it with the body shop guy and had them not order anything i didnt want, and with the check I got, I ordered some of the things I did want and they have been happy to put them on.
Fortis cadere, cedere non potest
Poison Spyder BFH w/ trail stinger, custom rear BFH, crusher flares, rocker knockers, evap skid, hood louver. Rock Krawler 2.5 Max Travel, Teraflex rear tire carrier, River Raider cowl snorkel,Warn VR 10,000 lbs winch, sPod, Rigid 50"SR.
D5Fire is offline
post #12 of 21 Old 05-05-2011, 08:20 PM
Dynatrac's Avatar
All the Rubi parts are a direct bolt-in into the ProRock 44 housing, Unlimited or standard. If you have lift over 2.5 inches, the Unlimited is the better choice.
Dynatrac is offline
post #13 of 21 Old 05-05-2011, 08:23 PM
SoK66's Avatar
At EJS the Dynatrac rep said they had a 15% off special going. If I called & pleaded for the deal would it still be good?
SoK66 is offline
post #14 of 21 Old 05-06-2011, 02:53 AM
jeepaddons-chris's Avatar
If they offered 15% at EJS, then any vendor here that carried them as a distributor would probably be able to get you an even better deal. Ask Marcus about it.
jeepaddons-chris is offline
post #15 of 21 Old 05-06-2011, 06:10 AM
Any advice as well?
I did the same thing, was very happy with my decision to upgrade. I also changed gears in the rear and added a locker.
rjventrone is offline
post #16 of 21 Old 05-06-2011, 06:25 AM
bubba2u's Avatar
if they got an oem axle it would be set up ready to bolt in. if you upgrade they would have to set up your new axle too. did you offer to pay the additional labor or maybe they would pull the axle for you since it has to come out and you could set up the new housing and they could put it in. get the unlimited
bubba2u is offline
post #17 of 21 Old 05-06-2011, 10:22 AM
Good call Chris...I'm gonna check back today because the initial quote sucked if that's the case. They owe me explanationz! LOL
Marcus
post #18 of 21 Old 05-06-2011, 12:09 PM Thread Starter
SONIC's Avatar
Thanks guys.
Whats happening now is i sent an email to my insurance company and adjuster saying that their estimate was not enough for the amount of damage accrued in the accident. They ONLY quoted me for front and rear housings and labor, nothing else, no control arms, shocks, axles, hubs, no nothing.
I told them I want all that stuff on the estimate. Then ill get a bigger check and probably take it to performance 4x4 (anybody work with them before?) and have them do the work. The guy at the dealership is just too hard to deal with.
-Doc Holiday
SONIC is offline
post #19 of 21 Old 05-06-2011, 01:38 PM
levellinebrad's Avatar
Dude, I am going to send you a pm with phone number. I am a couple of hours up the road in Charlotte and have been through this in Jan. Chris Hanson and some others helped me out with info on the insurance co. Give me a call and we can talk about some options. If they are replacing the housing, there should be a charge in there to swap gears and shafts unless they are replacing those as well. Plus, you can do the labor yourself, I would be happy to help. Give me a call
levellinebrad is offline
post #20 of 21 Old 05-06-2011, 01:44 PM
I love this kind of stuff right here! This is what it's about fawkers!
Marcus
post #21 of 21 Old 05-06-2011, 02:43 PM
Does that mean you're going to come work on my junk?
