stock u-joint??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 05-05-2011, 02:35 PM Thread Starter
azrockzuk's Avatar
stock u-joint???
Where and what part # for a good $$$ on a stock 09 rubi front axle 44 u-joint?
Want to carry a spare or two just in case...
I heard you can't run full c-clips?
Any way I just want a stock one ...
I would rather have a weak(stock) u-joint than brake an axle if I could(instead of a new beefed up u-joint)...
Any help would be good....
Chad
Chad
azrockzuk is offline
post #2 of 14 Old 05-05-2011, 02:43 PM
http://www.quadratec.com/products/52302_05.htm
http://motionoffroad.com/catalog/ind...oducts_id=2446
https://www.jkowners.com/forum/showthread.php?t=27504
Do a search on google for jk rubicon u joint as well. tons of information I found. Didn't want to overload you with stuff.
post #3 of 14 Old 05-05-2011, 02:59 PM
TrailDuty.com
PhilD's Avatar
Tack weld the caps, it will prevent the caps backing out and hitting the upper ball joint and wreaking havoc.
PhilD is offline
post #4 of 14 Old 05-05-2011, 03:10 PM Thread Starter
azrockzuk's Avatar
sweet I'll get the one from quadratec I want stock u joint for a spare...
Chad
Chad
post #5 of 14 Old 05-05-2011, 03:39 PM Thread Starter
azrockzuk's Avatar
I saw a d-30 driver side brake... ujoint, ball joints and axle was all broke... I was like wow!!
Yea I should order some ball joints too...
Who sells the kit for the ball joint puller (for a Jk )?
Chad
post #6 of 14 Old 05-08-2011, 03:46 PM
AdamIsAdam's Avatar
good idea. I ordered one on line for $60+shipping. seems like a smart thing to carry! I'm still not sure I understand what happens when things go wrong there, or how to fix it on the trail. But now I got a spare and, well, parts are harder to find than skilled labor, especially on the trail
Adam
First Jeep:
(heavily modded and wheeled!)
Last Jeep:
Sunburst Orange
Ordered 11/14/08
Shipped 11/25/08
Delivered 11/28/08
Mods:
Wrangler MT/R 35x12.5x15 on Soft 8's for the trails.
Duratrac 35" on Dick Cepek's for DD'ers.
5.13s, TF 2.5" Coil Lift, LCAs, & track bar, Mopar bumpers, WARN 9.5ti, diff covers, lots o' skids, EVAP relocated, breathers extended, ALLGIG, backup cam, Soundcoat Absorbtion Panels, and more...
AdamIsAdam is offline
post #7 of 14 Old 05-08-2011, 09:57 PM
KenB1010's Avatar
It's almost useless to carry a spare Ujoint. A Ujoint failure almost always takes the axle out with it.
Ken
Drivers Training = Fun
07 Rubi 2 Dr. 6-sp, 4" Full traction Long Arm, Dynotrax D60's front and rear, Big brakes, Evo double throwdown front coilovers, Kings on the rear, 38" Toyo's on TrailReady beadlocks, 1350 Coast DS's, Atlas 4sp, PSC extreme ram, High steer, GenRight Aux. Tank, Currie Anti-Rock rear sway, Spod, bunch O'h other stuff.
KenB1010 is offline
post #8 of 14 Old 05-09-2011, 12:25 AM
oz97tj's Avatar
Only when the driver has a hard right foot. If driving carefully, the break is caused by simply overloading the joint usually while turned. As long as the driver stops when the break occurs, there is rarely other damage. However, if a lot of throttle is used then other things tend to get taken out during the process.
Just another reason not to drive like a tard.
Support the sport. GLFWDA.org
oz97tj is offline
post #9 of 14 Old 05-09-2011, 04:07 AM
AdamIsAdam's Avatar
Gotta find one of these, or two next. LoL.
And I already carry a spare rear drive shaft.
Adam
First Jeep:
Last Jeep:
Sunburst Orange
Ordered 11/14/08
Shipped 11/25/08
Delivered 11/28/08
Mods:
post #10 of 14 Old 05-09-2011, 08:11 AM
TrailDuty.com
PhilD's Avatar
One of the most common issues with c-clip axle UJ's is that the caps rotate and spit the c-clip out. The cap is now free to back out, which usually happens sometime later when centrifugal force takes over. As the cap comes out it will hit the stud on the upper ball joint and wreak havoc.
Sometimes the caps will come out on the trail and if it just drops out and you notice it soon enough before you have messed up the ears then you can replace it.
Tack welding the caps in place pretty much solves this issue.
PhilD is offline
post #11 of 14 Old 05-09-2011, 03:47 PM Thread Starter
azrockzuk's Avatar
I agree AWALYS carry spare parts cus is does not hurt!!!
Its was a dana 30 that broke on the crown king run last weekend and it was just the cap was gone... Pulled the axle out and drove out...
Yes on the payson trip Dana 30 broke took out axle, ball joints and u-joint...
Thank god one guy had spare ball joints cus it was not going to move without them
Yea I plan to carry spare u-joint, ball joints, ball joint puller and a file (if I do weld the caps in you will need a file)
Just looking for a cheap ball joint puller kit now...
Has anyone used the ball joint puller kit from harbor fright????
Chad
post #12 of 14 Old 05-09-2011, 03:53 PM
TrailDuty.com
PhilD's Avatar
I use it and it gets the job done. The cups supplied with it are not exactly right for the JK, but with the help of some large sockets it will do the job.
PhilD is offline
post #13 of 14 Old 05-09-2011, 05:00 PM Thread Starter
azrockzuk's Avatar
No one make a ball joint puller just for a jk? They should
It sounds like alot of people change them out....I would like to buy just want I would need .....
Chad
post #14 of 14 Old 05-10-2011, 10:55 AM
TrailDuty.com
PhilD's Avatar
They are ball joint pullers that will work with the JK, the HF is just a cheap alternative for the occasional user.
PhilD is offline
