Aftermarket door check straps/assemblies? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 04-11-2011, 05:52 AM Thread Starter
I know I've seen them 1,000 times but I cannot figure out where. I am looking to see what aftermarket check straps or I guess "linkage" is available. The corner of my OR-Fab cage floor mount wore through my driver's door check strap. Surely the passenger is not far behind.
Any suggestions?
Thanks-
post #2 of 11 Old 04-11-2011, 06:12 AM Thread Starter
http://www.quadratec.com/products/13029_301X_PG.htm
That is what I was looking for. Has anyone used these? Anyone have them be able to show me some clearance pics? I have the 3/8" cage plate right there on the pinch seam I need to clear. I'd call quadratec, but I question their tech support!
post #3 of 11 Old 04-11-2011, 09:48 AM
yelorubi-EVA's Avatar
Goody... I just installed a set yesterday! Timing is everything.... I have the MORE "dead pedal"; and the "hold-open" works with that in place. I don't have a cage; but i do understand what your concern is. Give me a little time and I'll get you measurements and pics. Just a note.... the doors don't open quite as far a stock; about 3" to 4" less than straps only; however, they open far enough to get in and out without the necessity to learn a new method/sequence to do so! I'll be back... heard that somehere before.
6" FTLA w/HD TB & SS,
JKS spg rets., rr spg mnts.
37" BFG KM2, 17x9 MT clssc II, Blstn 5100,
Finishline West RB, LoD FB, SB XRC10
PP mod'fd boat sldrs, ARB rr DC's, TERA 44 frt xl hsg,
Sup'r CrMo xls, 5.13 R&P, Reel 1310 DS,
Kilby Evap, Bnchmrk KISS, B&M Trans culr,
sPOD; Aeroforce, FlashPac, Airaid CAI, Magnaflow relo,
Cobra 75, 4' Firestik, Woods Hood & TG holds
yelorubi-EVA is offline
post #4 of 11 Old 04-11-2011, 09:55 AM Thread Starter
Thanks for the info. 3-4" seems like a bunch. Just entertaining the thought of something a little better. I'll keep my bungee cord on it until I hear back from you lol. It at least "slows" it down before it smacks the fender because I'm not used to it!
- What part of Santa Clarita? I grew up in Canyon Country-
post #5 of 11 Old 04-11-2011, 10:09 AM
SONIC's Avatar
Why dont you get some stainless steel mesh and some gromets, and make your own?
-Doc Holiday
SONIC is offline
post #6 of 11 Old 04-11-2011, 10:13 AM Thread Starter
Location for SS mesh? Thought about just coated steel cable and some crimp ferrels.
post #7 of 11 Old 04-11-2011, 07:13 PM
LS6TT's Avatar
Send a message via AIM to LS6TT
damnit Mike, I was just going to tell you the exact same with the cable and ferrels and to make your own unstoppable straps.
im even looking at the galvanized wire rope on home depot
-Alex
2010 2dr Sport | 2.5" BB Lift with 4dr Springs | More to come
LS6TT is offline
post #8 of 11 Old 04-12-2011, 09:18 AM
Technically, Saugus... Bouquet Cyn. north of Plum Cyn.; been here for 21yrs.
Note: try 4wp or 4wd warehouse. I saved a few bucks and no shpg if p/u at a local store.
General pics and measurements for ya.... a couple more in next post.
post #9 of 11 Old 04-12-2011, 09:30 AM
More pics and info
Goody; Door open pics:
Max door opening as held by AI stop = 28.5"
Max door opening if pushed past the holder's final detent to it's limit = 32.5"
(as you would do when entering)
Hopes this helps; thanks for your patience. If you would like any add'l info or pics; let me know.
post #10 of 11 Old 04-12-2011, 06:39 PM Thread Starter
Perfect! Thank you very much! I think the 3rd picture tells me that will be right on my cage. However I don't see any issue with shimming the block that goes to the tub out to clear it. The "quick release" for the check strap will probably be right up against the cage, but I never take off my doors anyway. So it's not a big deal to me.
How well do you like them? If you just kinda fling the door open will the first detent catch pretty well?
post #11 of 11 Old 04-13-2011, 04:48 PM
Getting used to them. I have a 20* sloped driveway; so, I don't think it'll take too long to adjust to the benefit. I think my regular passengers will adapt quickly, also. I used to fling the door; but keep my hand on the shell to min. bounce-back. Now, I don't fling so much; rather, just hand-open and let-off when I feel the first detent. The hardware seems to be well designed; and sturdy. We shall see... as long as they last; I'll appreciate them greatly!
Best regards, Bill
