Engine vibration at idle - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 04-08-2011, 05:47 AM Thread Starter
aldo90731's Avatar
I have a 2009 JK 4-door with 24k miles and manual transmission, and loved how smooth the engine idled.
The engine started to show a vibration at idle. The tach remains stable at about 600/750 rpms, but I can feel a harsh vibration through the steering wheel --and the rest of the vehicle.
Elsewhere I found a thread about this recommending to checking engine fluids. Strangely enough, oil was 1-1/2 quarts low. I filled up the missing motor oil but the vibration remains.
Any thoughts?
Thanks.
2013 Jeep Wrangler Rubicon
Warn 9.5ti winch
2.5-inch Teraflex lift
35-inch General Grabbers
2014 Jeep Wrangler Unlimited Sahara
Rubicon Wheels and Tires
aldo90731 is offline
post #2 of 6 Old 04-09-2011, 03:23 AM
I have been noticing the same problem, mainly when the engines warm. I only have 8000 miles on my 2010
It started happening right after my last fill up so I think I may have gotten some bad fuel, going to try a bottle of gas treatment and fill up at a different station. Maybe I have some water in fuel or could be the blend of fuel they are using now that the weather is getting warmer. at least thats what I'm hoping!
PmedicJ is offline
post #3 of 6 Old 04-09-2011, 04:25 AM
Send a message via AIM to armedsks
Any Check engine lights??? Could be fuel related. Id get under and make sure your motor mounts and transmission mounts are intact. Fill up with a name brand fuel and run it out.
armedsks is offline
post #4 of 6 Old 04-09-2011, 09:17 AM Thread Starter
aldo90731's Avatar
Found a thread at another forum: someone describes a similar engine vibration after a "fender bender" --see thread here: http://www.jk-forum.com/archive/index.php/t-81503.html
I was rear ended five weeks ago --see thread here https://jkowners.com/forum/showthread...ighlight=prius
Coincidence?
The body shop is now checking the engine/trans mounts...
Warn 9.5ti winch
post #5 of 6 Old 04-09-2011, 10:28 AM Thread Starter
aldo90731's Avatar
Yup...body shop found a bent transmission mount.
Looks like the mystery is solved...
Warn 9.5ti winch
post #6 of 6 Old 01-24-2019, 06:13 PM
How bad was the repair??
libordemise is offline
