33's with stock suspension pic - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 04-06-2011, 03:53 PM Thread Starter
i put some 33's on yesterday, looks really good to me. my problem is i have a 2.5 RC coil lift waiting, will that be too much for 33's?
westx is offline
post #2 of 7 Old 04-06-2011, 04:11 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Nope! It'll look just right!
Marcus
RiverCityOffroad is offline
post #3 of 7 Old 04-06-2011, 04:20 PM
sahara mist's Avatar
I have the RC 2.5 coil lift and to be honest they are weak and suck. I will never buy rough contry lifts again.
07 2dr 35s 3.5 spring lift,rear 4.5 front 488s winch, TnTfront stinger bumper,flow master exhaust.
sahara mist is offline
post #4 of 7 Old 04-06-2011, 04:21 PM
nootherride's Avatar
2.5..netted 3.25 front 3.0 back on 33's
nootherride is offline
post #5 of 7 Old 04-06-2011, 04:27 PM
bit of broad statment...RC shocks are garbage is the primary problem ditch em and go with bilsteins or rancho 9000 life will be better as for the amount of tire to lift its about perfect..if you end up adding bumpers/winch you will have a little wiggle room...the problem "As i see it" is you will want more! im going to a 3.5 coil and 35-37's here soon it becomes an addiction
post #6 of 7 Old 04-06-2011, 04:44 PM
Thanks for the info on the shocks. when I put a stubby stinger bumper and winch on it dropped my front about 1.5 inches. put in 2" coil spacers t0 compensate. I also run the RC steering dampner and the u-bolts on the brackets used to loosen up on every run. Now back to the thread I also run 33s
post #7 of 7 Old 04-06-2011, 05:13 PM
your talking about the u bolts on the track bar brackets? they should never come loose..i cant remember what rc uses for front..i went with an adjustable track bar in front (highly reccomended to add) also sway bar disconnects are a must imo...but the trackbar will help center your axle after the lift is done
