Breaching the firewall... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 04-03-2011, 05:38 PM Thread Starter
lbh
lbh's Avatar
Where is the best place to run wires through the fire wall? I am installing some switches for lights and cant find the sweet spot!
2007 JK
lbh is offline
post #2 of 9 Old 04-03-2011, 05:41 PM
dtcc687's Avatar
go right through the cowl. you will see some foam right behind the side panel. just poke a screwdriver through first and you can fish wires right through it no problem. if i had pictures id post them. ill post tomorrow if someone doesn't beat me to it
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #3 of 9 Old 04-03-2011, 05:54 PM
zjr
zjr's Avatar
Most of us with auto's use the clutch hole.
zjr is offline
post #4 of 9 Old 04-03-2011, 06:38 PM
cjb321's Avatar
this is from inside the jeep. i used a coat hanger to pull the wires through.
driver side
passenger side
Chris
'09 Rubicon 2dr, Silver
cjb321 is offline
post #5 of 9 Old 04-03-2011, 06:55 PM
RubiRed Unlimited's Avatar
On Both sides of the cowl there is a hole designed for this purpose. In mine, it was covered with a black plastic film. The hole is about 2 inches in diameter and located about 3 inches in andn 4 inches down from the upper corners of the cowl. Look for the circle, and then poke it with something and you will see it is a flexible plastic. You can poke a wire straight through it. Its as easy as can be, just unfortunately disguised. The Drivers side is easier since the passengers side is behind the battery tray.
RubiRed Unlimited
ARB bumpers
Superwinch 9.0i
3.5" AEV premium lift
35" KM2s, OR-Fab tire carrier
Viair on board air
RubiRed Unlimited is offline
post #6 of 9 Old 04-03-2011, 11:10 PM
kenszel's Avatar
If you have an auto you can go through were the clutch would be. I did mine through there.
kenszel is offline
post #7 of 9 Old 04-04-2011, 12:23 AM
kenszel's Avatar
The wire bundle on the left...
kenszel is offline
post #8 of 9 Old 04-04-2011, 01:32 PM Thread Starter
lbh
lbh's Avatar
Thanks for the info! Will complete this tonight!
2007 JK
lbh is offline
post #9 of 9 Old 04-04-2011, 02:12 PM
Iron's Avatar
On the drivers side there is a hole for the washer fluid for the hard top to pass thru! On the passangers side there is the same hole (for RHD jk's) under the black sound deadening materinal behind the battery, it ia large enough to pass a cb antena with the fitting thru, it comes out behind the glove box! I know I ran wire thru it last night!
Mike B
08' Jeep Wrangler
08' Dodge Avenger SXT (winter beater)
64' Plymouth Sport Fury(sold)
58' Triumph TR-3A(in 1,000,000 pieces)
Iron is offline
