15 inch rims, what's the verdict? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 04-02-2011, 12:49 AM Thread Starter
cardenasrc51's Avatar
Hey everyone, I have an 08 Rubi Unlimited rolling the stock Rubi 17" rims with some worn, rock rash, 285/70/17 KM2. I want to downgrade to some black 15 rims and slap on some 35" KM2. I'll feel better about thrashing a $200 tire than a $300 tire. Also I would be ditching my Spidertracks(which have been trouble free for about 20,000 miles). Any thoughts? Are the 15" rims problematic? I know I'll be losing my pressure sensor, but how's handling? My jeep has a 2.5" BB from teraflex. Can I see some pictures? And why does a 17" tire cost more than a 15" tire when you are getting more rubber on the 15 incher??
2008 Unlimited Rubicon automatic with 35" KM2
15" black procomp 8069
Swag Offroad tailgate conversion
OR-Fab Tire carrier with Amo can for straps & tools
K&N cold air intake
Magnaflow exhaust
Alpine iDA-X305S
MB Quart 4 channel amp
MB Quart 6" Components
Pollk Audio 6" components
cardenasrc51 is offline
post #2 of 12 Old 04-02-2011, 12:59 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Do it.
You might have to grind a little bit its not that big of a deal.
I run 15x8 cragar soft 8s with 4" of backspacing. I didn't have to grind but the wheels did a little scrubbing on the calipers.
Its a Jeep...its gonna handle like a Jeep no matter what size the wheel IMO.
35/15 Km2s are in stock.
Let me know if I can help with your purchase.
Marcus
Sent from my cellular communication device.
RiverCityOffroad is offline
post #3 of 12 Old 04-02-2011, 01:04 AM Thread Starter
Cool, what I mean about handling is I read on another forum that a member could not run a higher air pressure than 25psi cause it made his jeep handle weird. I forgot the exact terminology he used but it made me wonder. I don't mind grinding at all either.
K&N cold air intake
Magnaflow exhaust
Alpine iDA-X305S
post #4 of 12 Old 04-02-2011, 01:47 AM
MKTJK's Avatar
I am running 15" soft 8's with 35" km2's. I love it! Not squirly at all! No clearance issues either but I'm also running spydertracs.
I run mine at 30-32psi, rotate every 3k and have a perect wear pattern. (or lack of pattern I guess)
I say rock that shit and never look back!!
MKTJK is offline
post #5 of 12 Old 04-02-2011, 01:48 AM
wralston89's Avatar
ive read that with 15 inch rims you just need to make sure the style of rim will clear the breaks some are a little thicker on the inside (best way i can think to put it) like the guy above said it scrubbed his calipers ... also if your going to do a tie rod upgrade some will not fit with a 15inch rim .... I wanted to do the same thing but read about some complications running 15's on the rubi ... so just went with 16's and 35's ... rock krawler tie rod clears everything great and no grinding ... can air down to 8 psi and do just fine wiht 16x8 and 4.25 backspacing wouldnt go much more than that unless your going to a 37 or 40
wralston89 is offline
post #6 of 12 Old 04-02-2011, 02:17 AM
casaintsfan's Avatar
Send a message via AIM to casaintsfan
Pro comps 15x8 w/ 3 3/4" back spacing clear the calipers but you gotta be careful where they put the wheel weights. I run 27psi and the tire wear is good and it rides pretty good too.
casaintsfan is offline
post #7 of 12 Old 04-02-2011, 03:02 AM
I run 15" wheels and it works very well. One issue is if you want to step up to 37's then the tire companies have you very limited. My cost with this rim choice saves money on every tire replacement. It really adds up over time. Check out my trail pics in my signature to see performance off road.
Wheel- Procomp 8179 15x8 3.75 BS $100 BFG KM2 35x12.5x15 - $190-$200
Before chopped fenders
4x4x4 is offline
post #8 of 12 Old 04-02-2011, 04:08 AM
snowbilt's Avatar
I was going this way, but having second thoughts over a couple issues I just read about.
Rocks have the potential to get stuck in the brakes easier due tight clearance
If you are planning on upgrading to beefier suspension like drag links and tie rods you have the potential of running into problems as well.
If anybody has any thoughts on mays to mitigate these issues I want to hear them.
snowbilt is offline
post #9 of 12 Old 04-02-2011, 05:35 AM
toymaster's Avatar
^^^^^ He pretty much nailed it. For example, the extremely beefy Currie tie-rod will not fit with a 15" rim.
I have no idea why 15" are so much less than larger sizes. Many people run the 15"s so, it can be done. You just have to be aware it may affect other mods.
JK 2dr rubi
toymaster is offline
post #10 of 12 Old 04-02-2011, 06:02 AM
AdamIsAdam's Avatar
I have pro comp 1069 with 3.75" BS and I have the Rock krawler tire rod. No problems. no grinding. All is good.
But you all have me worried that my steelies in storage won't clear my new tire rod! I better check that before my next run! They have 4" BS.
Oh, and either way make sure you are careful with wheel weight placement if you use stick ons. Again, I did this with good results.
Sent from my EVO using Tapatalk
Adam
First Jeep:
(heavily modded and wheeled!)
Last Jeep:
Sunburst Orange
Ordered 11/14/08
Shipped 11/25/08
Delivered 11/28/08
Mods:
Wrangler MT/R 35x12.5x15 on Soft 8's for the trails.
Duratrac 35" on Dick Cepek's for DD'ers.
5.13s, TF 2.5" Coil Lift, LCAs, & track bar, Mopar bumpers, WARN 9.5ti, diff covers, lots o' skids, EVAP relocated, breathers extended, ALLGIG, backup cam, Soundcoat Absorbtion Panels, and more...
AdamIsAdam is offline
post #11 of 12 Old 04-02-2011, 07:57 AM
I run the poly performance tie rod and no clearance issues at all
post #12 of 12 Old 04-02-2011, 01:14 PM
Thantos's Avatar
I've got 15" MB172's w/ 33" duratracs and love it. The ride is soo much better then the stock 18's my sahara came with.
Thantos is offline
