Holy Loose Bolts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 03-31-2011, 10:27 AM Thread Starter
Holy Loose Bolts
So I have been chasing a wobble on my 2010 since I got it in Feb as a new leftover. I installed my 3.5 RK from my 08 and so on. Started today, after many conversations with RK and using PP trackbar braces, checking fastners that I did not have to touch.
-all 4 ball joints nuts loose.
-pitman arm nut finger tight(and with a paint mark on it)
-trackbar bolts loose from the factory-enough to slightly wallow the rear hole on the front frame bracket(discovered when putting the lift on)
Moral of the story is the factory boneheads dont care about your loved ones(or theirs) by the quality of work they put out.
I did not let my wife drive the JK because I knew it just was not right.
So with 667 miles on it I have some slight up and down movement in my ball joints if I pry hard enough-this sucks.
[/LIST]
  1. '10 Rubicon Unlimited
  2. Rock Krawler 3.5 Mid Arm Flex/Bilstein 5100's
  3. Rough Country SS
    4.GDY Duratrac 315/70/17
ejb17 is offline
post #2 of 10 Old 03-31-2011, 10:31 AM
Coonasian
Charlie's Avatar
I think these factory SNAFUs happen to all makes at all plants but it sure doesn't help any when you are the recipient! Did you check this with the dealer? Did they have any input or would they just blame you and the lift?
Charlie is offline
post #3 of 10 Old 03-31-2011, 10:39 AM
gold knight's Avatar
There's a recall for that.
https://www.jkowners.com/forum/showth...ghlight=recall
gold knight is offline
post #4 of 10 Old 03-31-2011, 10:42 AM
Constantine's Avatar
Feedback: 15 reviews
That's crazy but at least they are reconizing the problem.
2014 JK Anvil
"If You Don't Stand For Something, You'll Fall For Anything"
Constantine is offline
post #5 of 10 Old 03-31-2011, 10:54 AM
[/LIST]
If it makes you feel any better, the assemblyline guy on torque duty was HAMMERED that day.
Dancin Dan is offline
post #6 of 10 Old 03-31-2011, 11:43 AM Thread Starter
Yea, I saw that little blurb about the workers. I just found the problem so I have not called the dealer yet.
  3. Rough Country SS
ejb17 is offline
post #7 of 10 Old 03-31-2011, 11:51 AM
Slow and Low
Co4Lo's Avatar
That's actually normal with most solid axle OEM balljoints. So they are probably fine. But they are junk anyway...
Co4Lo is offline
post #8 of 10 Old 03-31-2011, 05:52 PM Thread Starter
Wow, what a difference tight fasteners can make. Drives like it should. Mine was built in May 2010 so anyone with build dates near then may want to go over things very closely.
  3. Rough Country SS
ejb17 is offline
post #9 of 10 Old 03-31-2011, 05:55 PM
BeerMonkeY's Avatar
i found all the bolts missing from my front fender flare on my old 07 bough brand new.
'92 YJ
'13 WK2
BeerMonkeY is offline
post #10 of 10 Old 03-31-2011, 06:21 PM
EMG006's Avatar
I think this was the goose egg option they forgot to let everyone know about. I feel I am lucky mine was built a month before yours.
River City Offroad
Metal Cloak
EMG006 is offline
