EGR TUBES? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 03-27-2011, 06:54 AM Thread Starter
EGR TUBES?
Im a noob, can someone take a pic of these EGR tubes? I heard these are tubes that make that rattling noise but im not sure what they look like besides matallic
beachjeeplove is offline
post #2 of 16 Old 03-27-2011, 07:18 AM
Is that what that sound is? I thought I had a cat. conv. going bad or something. Low speed on acceleration is when I hear it.
I'm guessing its the corrugated heat shields on the egr tubes.
Am I correct?
xmikedentx is offline
post #3 of 16 Old 03-27-2011, 07:23 AM Thread Starter
thats what people are saying it is, and if it is, it will sound like its comming from the trans.
post #4 of 16 Old 03-27-2011, 08:12 AM
tkob1060's Avatar
Whom are these people saying this? I've never seen or heard that before and there is only one egr tube, it runs from the top of your intake to the passenger side of your block, its the hard metal tube on top of the engine. I cant see how thats making noise.
tkob1060 is offline
post #5 of 16 Old 03-27-2011, 08:23 AM
paramaniac's Avatar
Uh, tim... He told you... People. People are saying this. And if PEOPLE are saying this then it must be true!
Sent by carrier pigeon
paramaniac is offline
post #6 of 16 Old 03-27-2011, 08:34 AM
I must be the 'People" but yes the metallic tubes covering the EGR pipes will rattle at various RPM's ( mine happened above 3k rpm's when hot under acceleration, It must have been just enough vibration to make this sound) I spent months and many trips to the dealer only to be told my "Rattle" was normal and they could not find anything wrong with my Jeep! I knew something was making this noise and upon tapping on everything and moving things around I found these coverings were not clamped down and if they are loose you could flick them with your finger and they would make a metallic sound. I clamped them and NO MORE NOISE!
There are 2 pipes and the one that runs straight down the back of the engine and firewall was the culprit, it sounds like it comes from the transmission or bell housing housing area or possible bad catalytic converter. after messing around with it for a while before clamping it I tried pinching it tighter and the sound just got different but after clamping it, it was gone.
PmedicJ is offline
post #7 of 16 Old 03-27-2011, 08:59 AM
paramaniac's Avatar
I was just fucking around... I find it humorous when people tell me "they told me..."
Can u snap a pic of where you clamped the tubing?
post #8 of 16 Old 03-27-2011, 01:33 PM
I can try but it will be tough, It wasn't easy getting my hand down behind there to clamp it
PmedicJ is offline
post #9 of 16 Old 03-27-2011, 07:39 PM
paramaniac's Avatar
How about a pic from up top pointing or highlighting which one it is? And a pretty good description as to where you clamped it up?
I'm interested because I have a rattle that one dealership said was my CF clutch and another said my catalytic converters are bad but were baffled as to why I had no emissions issues
post #10 of 16 Old 03-27-2011, 09:53 PM
I can't get a pic uploaded right now but you can't miss them, Start from the very top center of the engine right where it says 3.8l and the intake runs into throttle body (very top)and look at the metal tube and the metal tube covering it and then trace it to the back of the engine and look for the other metal tube covering running behind engine with it's covering on it neither are clamped.
PmedicJ is offline
post #11 of 16 Old 03-27-2011, 09:55 PM
rcul8r's Avatar
I'm joining in on this, not because mine rattles (yet), but if it does I want to remember this thread and see some pics or get the updated replies!
Artificial intelligence is no match for natural stupidity
rcul8r is offline
post #12 of 16 Old 03-28-2011, 10:47 AM
Comfortably Numb
RubiCajun's Avatar
RubiCajun is offline
post #13 of 16 Old 03-28-2011, 11:41 AM
paramaniac's Avatar
Nicely done!
post #14 of 16 Old 03-29-2011, 09:46 AM
paramaniac's Avatar
Well I do believe that "they" are right about this...
I had a rattle on acceleration that I couldn't pinpoint. I took a hose clamp and tightened it down on one of the metal looms that covers the EGR valve piping and voila! No more rattle.
Edit: I took a pic but it's not uploading via tapatalk for some reason. I'll try again later
post #15 of 16 Old 03-29-2011, 10:17 AM
paramaniac's Avatar
Here's the pic of what I did
post #16 of 16 Old 03-29-2011, 10:57 AM
Bingo, Thats the one!
Glad "They" could help
P.S. How many paramedics does it take to fix a rattle? Obviously 2, I guess thats why we work in pairs!
PmedicJ is offline
