Welding on the Jeep..... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 03-26-2011, 01:06 PM Thread Starter
chainboy1's Avatar
I am planning on doing a little welding on the frame of the Jeep. Is there anything special I need to do to keep from damaging the electrical system or is it not a problem? I just want to make sure I don't screw anything up. Thanks
Banned from that "other" site.
Let's go find some rocks! =)
chainboy1 is offline
post #2 of 7 Old 03-26-2011, 01:38 PM
steve&2jc's's Avatar
I would just disconnect the ground from the battery to be on the safe side.
07 Rubi Unlimited , 4.5 clayton longarm, 37" Maxxis treps, AtoZ fabrication, Genright, and Polyperformance
steve&2jc's is offline
post #3 of 7 Old 03-26-2011, 01:39 PM
SONIC's Avatar
Yeah disconnect the ground.
But i have welded on my jeep a few times without disconnecting anything and have never had a problem.
But to be safe...
-Doc Holiday
SONIC is offline
post #4 of 7 Old 03-26-2011, 02:05 PM Thread Starter
chainboy1's Avatar
post #5 of 7 Old 03-26-2011, 04:44 PM
austinjeepr's Avatar
So.......whatcha welding???????
Welding on the frame....has to be something good!
austinjeepr is offline
post #6 of 7 Old 03-26-2011, 05:47 PM Thread Starter
chainboy1's Avatar
Lol, I wish.....actually it's something totally stupid and very temporary.
I am panning on rigging something up similar to Teraflex's removable mudflaps. I am going to weld the pieces on to the frame that will hold the rods. I will have one in front and behind each wheel. I am using some thin sheet to cover the front and back of each tire so I can pass WV's stupid state inspection. The tires have to be covered from 15 degrees above center in front to 15 degrees above center in the back. The tires also can't stick out past the fenders which mine do a little bit. Basically I am making crappy fenders out of thin sheeting that I can just slide in and pin once a year and as soon as inspection is over I pull the pins and remove them. I made a little picture to show what they require to be covered. I am just welding the bases to the frame with the plans of having to do this for a while. =)
post #7 of 7 Old 03-26-2011, 08:52 PM
Well that sucks!
Small square tube would work good.
