help with silicone - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 03-08-2011, 10:30 PM Thread Starter
Monster Jk's Avatar
Feedback: 23 reviews
help with silicone
so i recently took of my tire carrier and now need to remove some silicone from the painted body of my jeep. i have tried my finger nail, and also a light solvent and no luck. Does any one know of a good solvent i can use that will take it off and not damage the clear coat or paint underneath?
Monster Jk is offline
post #2 of 20 Old 03-08-2011, 10:36 PM
Acetone. I wouldn't wash the rig in it, but I've used it safely on a number of clear coats with no damage.
zelatore is offline
post #3 of 20 Old 03-08-2011, 10:44 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
I have some stuff called "de-solve-it" that works great. I installed a bathroom sink and got some high powered silicone on the inside of it. I tired acetone and all kinds of other shit that didnt work. When i used the de-solve-it stuff, it came right off. It is some kind of citrus based solvent. It comes in a spray bottle and is orange in color. It smells like oranges too. This shit works. This is exactly what i have:
corey d
2008 JEEP...
STUPIDFACE is offline
post #4 of 20 Old 03-08-2011, 11:03 PM
Hittnthebz's Avatar
Goo-Gone and a little elbow grease usually works for me on stubborn chores like that.
Hittnthebz is offline
post #5 of 20 Old 03-09-2011, 09:52 AM
Jimmy2x's Avatar
If you use that stuff that smells like oranges keep it off anything plastic because you will melt it. 3M makes a similiar product that they call a grease remover. The stuff works great and you can order it from Grainger.
"A government that is big enough to give you everything you want, is strong enough to take everything that you have." - Thomas Jefferson
Jimmy2x is offline
post #6 of 20 Old 03-09-2011, 12:29 PM
I assume this is just plain old silicon, not one of the other products that look like silicon, like polyurethane or polyether? Plain old silicon isn't that hard to get rid of - heck, it pretty much desoves in gas.
Some of the other produts look like silicon but are actually very different and far more tenatious. In the marine world 3M makes a couple of products called 4200 and 5200 that are a real bitch to get rid of. In fact, 5200 is considered a permanant bond. Glue something down with it to a fiberglass boat, and you'll likely tear the 'glass apart removing it before the bond of the 5200 lets go.
If you're dealing with something like this instead of of just plain silicon, head down to a local west marine (or other marine shop, or check it out on-line) and pick up a product called Anti-Bond 2015. It's about the only chemical I know that will help with a polyurethanes. You'll still need a razor blade and a lot of paitence though.
http://www.westmarine.com/webapp/wcs...classNum=10373
zelatore is offline
post #7 of 20 Old 03-09-2011, 04:57 PM
dtcc687's Avatar
I had the same thing. It was a pain in the ass to get off. Took a lot of scrubing
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #8 of 20 Old 03-10-2011, 04:48 AM Thread Starter
Monster Jk's Avatar
Thanks for the ideas, ill let ya know what works the best
post #9 of 20 Old 03-11-2011, 06:58 PM Thread Starter
Monster Jk's Avatar
Gas- didnt work
De-solve-it- didn't work
Goof off- didn't work
WD40- didn't work
Mineral spirits- didn't work
Any other ideas?
post #10 of 20 Old 03-11-2011, 10:04 PM
Hittnthebz's Avatar
Are there large amounts still left on there? If so, I would use a plastic scraper or something that won't gouge the paint to get the majority of the silicone off first. Goo-Gone, the item I suggested, will remove small amounts at a time with elbow grease like I said...I am not sure about the products others recommended. I haven't found anything Goo-Gone won't remove as far as residue left after scraping off most of the material.
post #11 of 20 Old 03-11-2011, 10:17 PM
Originally Posted by Monster Jk View Post
Gas- didnt work
WD40- didn't work
Any other ideas?
Yep. Stop being such a pussy and start scrubbing like you still have a valid man card before someone pulls it.
Elbow grease an some goo gone should be all you need unless you have some sort of supernatural irradiated spider's web holding your shit in place.
Dancin Dan is offline
post #12 of 20 Old 03-12-2011, 06:37 PM Thread Starter
Monster Jk's Avatar
i am impatient and if it looks like its not coming off after scrubbing for 30, i tend to look for other means. I want to find a shop that has that 3M eraser wheel, that thing looks like it works tits and doesnt wreck paint.
post #13 of 20 Old 03-12-2011, 07:16 PM
nlgrav182's Avatar
Methyl Ethyl Ketone (MEK) is a great solvent and evaporates slower than acetone will. Try Mr. Clean Magic Erasers too.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #14 of 20 Old 06-23-2011, 03:50 PM Thread Starter
Monster Jk's Avatar
will the magic eraser scratch the paint?
post #15 of 20 Old 07-05-2011, 03:19 PM
PEEJ's Avatar
Thought something completely different when I read the title
07 Unlimited Rubicon, 4 link rear, 3-link front, 37x12.50x17 BFG KM2's, Dana 60 rear, Warn Powerplant, Icon Perfromance coilovers w/ res in front Icon shocks w/res in back, 5.13Gears, Rubicrawler, RCV axles, WTO hydro assist, Anitrocks front and rear, Black Rock Bead Locks, TF speed bumps on all corners.
PEEJ is offline
post #16 of 20 Old 07-06-2011, 06:43 PM
TG426's Avatar
saw the title, thought breasts but oh-well...
If the silicone is that difficult to remove it may have polyurethane adhesive in it like 3M's 5200 for marine use. West Marine sells this stuff and it says it will not harm certain paints (2-part paints as well as gel coat and certain plastics.
http://www.westmarine.com/webapp/wcs...2295&langId=-1
It is $32 a can but may be worth it if the silicone has the adhesive in it.
Tom
2010 Wrangler Unlimited Sport
TG426 is offline
post #17 of 20 Old 07-06-2011, 08:40 PM
RookieJK's Avatar
should do the trick
Jersey
Crew
RookieJK is offline
post #18 of 20 Old 07-06-2011, 10:26 PM
Comfortably Numb
RubiCajun's Avatar
or you could try this
RubiCajun is offline
post #19 of 20 Old 07-09-2011, 06:42 AM
MichaelMaxim's Avatar
Man I was so hoping this was a poll thread regarding what size implants you were about to buy for your wife.... Lol damn thread titles.
Present - 2009 Rubi Unlimited on 37's -
Present - 2002 Sea Ray 280 Sundancer Sport Cruiser Boat (my other money pit)
Past - 97 XJ, lifted 8", 36" Iroks, locked, D44's, 4:1 case, custom fabbed bumpers, & more
Past - 01 TJ, 4.5 RE SuperFlex Lift, 35" TruXus MT's
MichaelMaxim is offline
post #20 of 20 Old 07-19-2011, 05:20 PM Thread Starter
Monster Jk's Avatar
lol
