Leak... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 11-23-2010, 04:05 AM Thread Starter
serbNYC's Avatar
Send a message via AIM to serbNYC Send a message via MSN to serbNYC Send a message via Yahoo to serbNYC
Question Leak...
So I started to get that infamous leak on the front drivers side of my 2007 JK...it gets my drivers side carpet pretty wet when it rains heavy, I tried looking for the leat but cant really find it...what should I do??? Went to the dealer and they looked at it and told me they cant do anything about it.
serbNYC is offline
post #2 of 2 Old 11-23-2010, 04:19 AM
jk_techcrash's Avatar
Do a search for leak driver side header or A pillar. Several people have had the same problem both with hard top and soft top. I think there is a seal kit you can get that addresses that problem. You could also take off the plastic molding that surrounds the windshield and A pillars on the inside have someone take a garden hose to the Jeep while you sit inside. Also you could set off a smoke bomb or fog machine on the inside and see where the leak might be. If you do that I will tell you the fog machine solution most likely will create a oily film everywhere on the inside. Good luck.
Póg mo thóin!
jk_techcrash is offline
