Pic Request... 3.5 Lift, Flat Fenders, and 35s - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 11-18-2010, 05:44 PM Thread Starter
MannyLedezma's Avatar
I Have the 3.5 X Factor Pro Mid Arm System coming in and am looking to get the Gen Right flats. Want to make sure it doesn't look like a roller skate on 35s.
MannyLedezma is offline
post #2 of 10 Old 11-18-2010, 06:15 PM
blake's Avatar
Imho u will want 37s with flat flares, 35 will look tiny i got 3.5 and 37s and never looked back
"Any day above ground is a good one "
blake is offline
post #3 of 10 Old 11-18-2010, 06:16 PM
blake's Avatar
blake is offline
post #4 of 10 Old 11-18-2010, 06:33 PM Thread Starter
You are right. The 37s do look nice and balanced. Just worried about my wimpy little D30.
I plan to get gussets, inner and outer sleeves, axles, and knuckles. But not sure if that will even be enough.
post #5 of 10 Old 11-18-2010, 06:42 PM
blake's Avatar
Well im sure there are more knowledgable on the topic than me but if i were you i would invest that money on a set of 44s and build my ride around the tire size u wanna run
blake is offline
post #6 of 10 Old 11-19-2010, 02:07 AM
I had the stock rubicon 44 with sleeve and gussets added for strength. I ran 37's and wheeled the heck out of it and it held up. I just upgraded to prorock 44 and longfield axle. Do you have the stock 44 or are you in a non rubicon.
beerdraft is offline
post #7 of 10 Old 11-19-2010, 03:12 AM
jvalason's Avatar
If you go with flats it will def make the 35s looks small. Atleast go with 37s. I had 35s with flat fenders and upgraded to 40s to fill the wheel gap.
jvalason is offline
post #8 of 10 Old 11-19-2010, 02:58 PM
Jason @ Warrior's Avatar
35" with flat fenders and 3" looked decent on our shop 2 door, but looked small on our shop 4 door.
Our newest shop 4 door looks ideal with 37's and the same 3" with flat fenders
Jason @ Warrior is offline
post #9 of 10 Old 11-19-2010, 02:59 PM Thread Starter
Yeah I definitely would like 37s. Just worried about my D30 and it being my DD. I drive all day for work. Not to mention the $$ factor. My wife is going to flip if I have to spend all that additional money on axles. I wonder how long the 30 could handle the 37s before giving?
post #10 of 10 Old 11-19-2010, 03:00 PM
gusset the c's, truss or sleeve it to keep the housing strong...and keep it open diff to keep stress reduced on the ring and pinion and shafts...you will probably be able to hold it together if you're a gentle wheeler.
