Decent fogs under $100? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 11-18-2010, 01:07 PM Thread Starter
Taxx's Avatar
Losing the factory fogs with a new bumper, while they aren't the greatest anyway I do use them a lot. Anybody have a suggestion for some decent round lights for fairly cheap with a fog beam? It needs to be something that will take some abuse without the filament breaking.
Taxx is offline
post #2 of 19 Old 11-18-2010, 01:24 PM
Jason @ Warrior's Avatar
Typically, good lights don't come cheap.
That said, my fogs are PIAA 520's. The 510 and 540 are also nice. If you get the part # for just the lamp from the PIAA website, and skip getting their big wiring kit and all the fancy packaging, you might save some $$
Jason @ Warrior is offline
post #3 of 19 Old 11-18-2010, 01:27 PM
StubEXrube's Avatar
I have used the Delta 150 Series fogs for over 3 years now. They have an abs plastic housing and lens guard, wiring kit with switch and relay, and are around $100. I had "sealed" KC's that were more expensive before these and the seals became cracked and one of the lenses became fogged.
No doubt they aren't the best but they illuminate very well, and have thus far proved reliable- no fogging behind the lenses and no cracks in the lenses or housings. I also like that they have a somewhat low-profile design.
StubEXrube is offline
post #4 of 19 Old 11-18-2010, 01:57 PM
salt life's Avatar
I just installed Warn's new fogs. They are $119, a little over the $100 mark, but they are very bright. So far I am pleased with them. Plus they're small, I think 3.5" round.
salt life is offline
post #5 of 19 Old 11-18-2010, 02:00 PM Thread Starter
Taxx's Avatar
That's all I care about.
I don't need hard core offroad lights, heck the factory fogs work well enough for what I use them for around town in the rain and such, so I could probably get away with Walmart lights but I want something that will last. And I have wiring and relays out the you know where so I am not worried about that. I'll just slap a relay on the stock wires to control it and run new power feeds, since in my price range I'm not going to get low power LEDs or HIDs.
Taxx is offline
post #6 of 19 Old 11-18-2010, 02:07 PM
2k2wranglerx's Avatar
i ran these on my brother's JK and my JK. they have a 100% fog pattern. very similar to a stock TJ fog pattern. there's a very sharp cut off. they were excellent in heavy snow/fog. the quality is just ok, but the price is cheap.
http://www.4wd.com/productdetails.as...0&partID=12258
there are way better lights out there. but for the $ these delivered fine for 2 years.
2k2wranglerx is offline
post #7 of 19 Old 11-18-2010, 02:17 PM
kenszel's Avatar
I have run the hella 500s on 3 of my jeeps and never had an issue. They are around the $70 mark.
kenszel is offline
post #8 of 19 Old 11-18-2010, 02:55 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
For the money I'm going to give these a shot:
http://www.4wd.com/productdetails.aspx?partID=12347
Let me know what you pick out and I'll save you some money!
RiverCityOffroad is offline
post #9 of 19 Old 11-18-2010, 03:16 PM
Are all these lights suggested legal to drive with 'on' like the factory fog lights? I haven't looked into the legality of having an "off-road" light operating on street conditions. I'd imagine a factory, or DOT approved light would be necessary to run on the street regularly?
post #10 of 19 Old 11-18-2010, 04:25 PM
Taco08jk's Avatar
I figure as long as its a fog beam pattern and pointed at the road you should be fine, they let us get away with it in my neck of the woods anyway. Everywhere is different though.
RK 3.5 X Factor mid arm
PSC BFH trail stinger
PSC narrow fenders
A lot more to come very soon!
Taco08jk is online now
post #11 of 19 Old 11-18-2010, 07:52 PM
BenFoo's Avatar
depends on local laws really.
i believe in PA you're allowed to run a fog lamp only when you have your low beams on. How ever you can have aux lights installed that can be turned on while you have the high beams on, it just cant be a fog pattern....or something like that. we have a lot of laws that don't quite make sense sometimes...
BenFoo is offline
post #12 of 19 Old 11-18-2010, 08:12 PM
HOOLIGAN's Avatar
I just finished looking on ebay. I'm trying to replace my fogs that I took off 3 years ago. My problem is I want 35w that way I can just hook right back into the factory harness and not deal with relays and stuff.
HOOLIGAN is offline
post #13 of 19 Old 11-18-2010, 10:42 PM
I will have a set of factory fogs for sale in the coming weeks. I just got my PSC stuff today.
post #14 of 19 Old 11-19-2010, 08:44 AM Thread Starter
Taxx's Avatar
PIAA does make a nice light.
Another one to look into.....
I was wondering about the warns. Do they have a nice sharp cutoff to keep them low? I like the size of them, though they are a bit more $$ than I want to spend since all I find are the wireless ones. (I haven't looked that hard yet)
For that price they don't have to last
Another to look at...
Will do.
Same here, you can put just about anything on the road here.
You might have to go LED or HID for that.
Thanks for all the ideas!
Taxx is offline
post #15 of 19 Old 11-19-2010, 08:54 AM
but you only get one or the other. You can only have 1 pair of uncovered aux lights at any time and they must be below the headlights.
post #16 of 19 Old 11-19-2010, 11:32 AM
MannyLx450's Avatar
Feedback: 17 reviews
Send a message via AIM to MannyLx450
You may also use dually Rigid Industries LED compact 2x2 package that can be used for anything. Dont worry about the abuse on this lights
CLick HERE to SEE the Lights.
Manny
Your Rigid Industries Source
PH: 754-201-58-48
MannyLx450 is offline
post #17 of 19 Old 11-19-2010, 12:30 PM
I picked up a set of these off of Amazon. They are H3 fogs from Pilot. They have an aluminum housing with a clear smooth glass lens.
I won't get a chance to do the install for 2-3 weeks, but I'll do a write-up with pictures. Needless to say, I have no comment on their performance yet, but I figured they're cheap enough to play with.
I've seen some other posts where people are wiring in a different part number 55W H3 Pilot driving light directly without freaking out the CANBus driver?
I plan on LaminX'ing them yellow.
More to follow.
http://www.pilotautomotive.com/Produ...roductID=27130
J_Westy is offline
post #18 of 19 Old 11-20-2010, 08:53 AM
pizzaman's Avatar
FWIW i drive with my long range KCs up by the windshield turned on when I am driving very late at night on some of these GA 2 lane highways when there are hardly any cars out. i dont do it often, but just when it's really dark (especially during deer season). my finger rests on the switch all the time and theyre off as soon as i see head lights. often times the only i ppl i pass are state patrol cars and i know several of them have seen the lights on before i switched them off. never had a problem.
im sure fog lights pointed at the ground will be fine.
pizzaman is offline
post #19 of 19 Old 11-20-2010, 06:18 PM
Originally Posted by J_Westy View Post
More to follow.
The install went pretty well.
Write up here: http://www.wranglerforum.com/f33/pil...all-69648.html
Much better than stock.
J_Westy is offline
