Synthetic Line - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 11-17-2010, 02:12 PM Thread Starter
Cod
Cod's Avatar
Send a message via MSN to Cod
Synthetic Line
Who's got the best prices?
Where did you get yours?
Want a 3/8" x 100' with Safety Thimble
Cod is offline
post #2 of 24 Old 11-17-2010, 03:08 PM
redcat's Avatar
I would go to Off Road Only ( www.offroadonly.com), if I was given a choice.
07 X 2 door
Red Rock Crystal
www.militaryjeepers.com
redcat is offline
post #3 of 24 Old 11-17-2010, 04:10 PM
MannyLx450's Avatar
Feedback: 17 reviews
Send a message via AIM to MannyLx450
Arrow
www.xtorm4wd.com or CLICK HERE TO SEE THE PRODUCT
Let me know so i can give you a CODE OFFER for check out.
Thanks.
Manny
Your Rigid Industries Source
PH: 754-201-58-48
MannyLx450 is offline
post #4 of 24 Old 11-17-2010, 04:11 PM
Rerun's Avatar
Holy shit! That works out to $3.61 per foot for the x-line.
Rerun is offline
post #5 of 24 Old 11-17-2010, 09:31 PM
nlgrav182's Avatar
You can't just put synthetic line on any winch. The drums are either designed for synthetic or they're not.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #6 of 24 Old 11-18-2010, 07:46 AM
redx08's Avatar
Wrong, the fair lead is specific to synthetic line or not.
08 jk unlimited X
1 ton axles
39.5 Iroks
redx08 is offline
post #7 of 24 Old 11-18-2010, 07:47 AM
garner's Avatar
Correct. the drum has nothing to do with it. It is the fairlead.
I am using Viking 100 foot, 3/8 and it was about $350.
2008 Rubicon Unlimited | Rescue Green | OME Long Travel HD Lift | Raceline Monster Beadlocks | 39.5 Irok Bias Tires| 5.13 Gears | PSC BFH Front Bumper | PSC Flares | PCS Crusher Corners |PSC Rock Brawler Rear w/tire carrier | Warn 9.5ti | ARB High Flow On Board Air | sPOD |Rock Hard Sport Cage | Poly High Steer Kit | Poly Front Track Bar Brace | Alloy Chromoly Rear Axle Shafts
garner is offline
post #8 of 24 Old 11-18-2010, 08:31 AM
Jason @ Warrior's Avatar
I swear by Master Pull XD line. But I am excessively abusive on winch rope.
Jason @ Warrior is offline
post #9 of 24 Old 11-18-2010, 08:33 AM
nlgrav182's Avatar
That's not what the Superwinch rep and engineer said.
OKAY FUCKMOUTH.
post #10 of 24 Old 11-18-2010, 08:35 AM
garner's Avatar
Maybe Superwinches do something different to their drums, however I know with Warn it does not matter.
garner is offline
post #11 of 24 Old 11-18-2010, 08:38 AM
That's just absurd data. I've put synthetic rope on just about every type of winch out there.
PS - Many synthetic line companies will tell you that you can run steel rollers with synthetic if they're new and smooth, but in my experience they'll still give you problems. Personally, I've had synth line melt onto steel rollers.
So you can go to poly rollers, delrin rollers, aluminum rollers like we make, or hawse fairleads. I've had poly rollers flat out fail on me and ruin 20-25 feet of line. Delrin, Aluminum, or Hawse all seem like very good options through my experiences so far.
post #12 of 24 Old 11-18-2010, 09:10 AM
bly109's Avatar
Feedback: 9 reviews
Doesnt it have something to do with the placement of the brake in relation to the drum?.. Most winches put the brake inside the drum, while superwinch has it positioned outside the drum. When the brake is inside the drum, it can create alot of heat on the drum. I always thought that if you used a heat resistant rope for your first wrap or so, you would be fine with synth rope on any winch.
Brian
bly109 is offline
post #13 of 24 Old 11-18-2010, 09:16 AM Thread Starter
Cod
Cod's Avatar
Thanks PIG @ PP for the help!
Cod is offline
post #14 of 24 Old 11-18-2010, 09:18 AM
Could be, but most synthetic ropes have a heatshield on the first few feet that cover the first wrap around the drum making this a non-issue.
post #15 of 24 Old 11-18-2010, 09:19 AM
2k2wranglerx's Avatar
http://www.bluehummer.com/syntheticline.html
best bang for buck i've found. Pretty sure it's amsteel too.
2k2wranglerx is offline
post #16 of 24 Old 11-18-2010, 09:20 AM
i thought that sleeve thing was for abrasion... or am i thinking of something different?
post #17 of 24 Old 11-18-2010, 09:26 AM
bly109's Avatar
Feedback: 9 reviews
Yep, thats what I was thinking. Most rope is either heat resistant already or uses a heat resistant section for the first 15-20ft to save some $$. I know mine has enough heat resistant stuff spliced in at the beginning to cover the drum. I think the heat is only an issue when power unspooling under load anyway.
Brian
bly109 is offline
post #18 of 24 Old 11-18-2010, 10:49 AM
tjdriver's Avatar
i put redneck rope on my 8274. i use 3/8 x 100'. i'm told my winch is older than i am.
04 Unlimited
12 JKUS Rock Lobster
tjdriver is offline
post #19 of 24 Old 11-18-2010, 02:10 PM
best winch ever. you can do the 9,000 lb motor conversion like i did OR they have a DUAL MOTOR conversion too! and you went conservative at 100', you can run 150' with that thing!
i had one on my willys. it was awesome.
post #20 of 24 Old 11-19-2010, 04:53 PM
tjdriver's Avatar
9k motor? yikes. i've never heard of that or the dual motor set up. nice flat fender. that's my main project is to find an old flat fender and fix her up.
04 Unlimited
tjdriver is offline
post #21 of 24 Old 11-20-2010, 08:17 AM
Wrong, I went to a synthetic line and haven't had a single problem. You need a plastic roller fairlead or a Hawse fairlead to run a synthetic line. The drum gets hot under releasing tension using the brake to control the load, not under load pulling an object in.
I went with the Viking/Samson 3/8"x100' and safety thimble on my Superwinch Epi9.0. I'd never un anything else but synthetic now.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #22 of 24 Old 11-20-2010, 12:40 PM
I have had a technora synthetic line on my warn HS9500I for 10 years now. When I changed it out, I did smooth over the drum. There were small weld splatters on edges of the drum and any synthetic is more susceptible to abrasion than is steel. Also, make sure you don't use any snatch blocks or other equipement that might have been used with wire rope. Wire will often cause ridges or other areas on the equipment that will abrade the synthetic.
Mine doesnt get tons of use, but it does get used. Dominion Offroad, a JKO vendor (Wood's or Jeepswag are the same company / person) offers a great deal on Technora with a safetey thimble. When I decided on Technora, I had to build my own as everyone was still using amsteel blue. Both have their good / bad and some use a blend of technora for the innermost wraps (it has the best heat resistance) and amsteel outer for better abrasion resistance. Check it out here:
http://www.jeepswag.com/
Wood's prices are really good.
Best,
Ron
Not planning for failure is planning to fail!
ronner is offline
post #23 of 24 Old 12-02-2010, 06:34 PM
MannyLx450's Avatar
PH: 754-201-58-48
post #24 of 24 Old 12-02-2010, 06:40 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
I got my viking winch line from Trail Duty.
corey d
2008 JEEP...
STUPIDFACE is offline
