Leaking Coolant Temp. Sensors - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 11-16-2010, 05:40 PM Thread Starter
afoulk's Avatar
Well, I figured out where my coolant was leaking from, it was the coolant temp. sensor. I just wanted to let you guys know because when I removed it, there was absolutely no sealant on the threads what so ever from the factory, so this might be a problem area on other jeeps as well. Just be careful if you ever have to remove it as the whole thing is plastic and i can picture them snapping off in the intake. Mine didn't leak when hot, but you could see it leaking on really cold mornings after sitting overnight.
SOLD-08 Unlimited X, "jeep green", auto, limited slip, hushpower muffler, Aerotech Interceptor gauge,Powerstroke tranny cooler, skidrow evap skid, AFE Pro 7 filter, Teraflex leveling kit, EVO control arm skids, 15x8 Black Rock 909's, 33" KM2's
afoulk is offline
post #2 of 4 Old 11-16-2010, 05:43 PM
No oring on it?
post #3 of 4 Old 11-16-2010, 06:22 PM
tkob1060's Avatar
mine does the same thing, I keep forgetting to order one
tkob1060 is offline
post #4 of 4 Old 11-17-2010, 04:50 AM Thread Starter
afoulk's Avatar
They use pipe thread, so theres no oring on it. And if yours is leaking, you don't need to order a new one, just drain your coolant, remove the sensor, clean the threads off and put some thread sealant on.
afoulk is offline
